Magnuson Supercharger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brostjoe, Jul 20, 2017.
  1. Oct 18, 2019 at 4:44 PM
    #261
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    meh, we will have to compare dynos but if they are saying an extra 100 hp then they should be running around 7-8 psi of boost and thats right in the wheelhouse of a roots SC.
    the Roots will provide more linear power which is what most want. Turbos depending on the setup can do that but at the extra cost parts of that type of set up make me weary.
    Your turbo kit wont be 6500 dollars. i would double that cost. (not sure you are getting an efficient hp/$$ ratio)
    GreyBaldTaco likes this.
  2. Oct 18, 2019 at 5:05 PM
    #262
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Nope. Definitely won't be double. Per OVT, will likely be similarly priced to the SC kits but I can't say with any certainty since I am not involved in producing the kit. The twin BorgWarner K03 Turbochargers are actually cheaper than one Rotrex supercharger.
    Agreed. the roots is a more simpler system with less parts. But the added HP/TQ gains of the TT kit compared to the roots SC kit will offset the of potential headaches of additional parts and installation.
    Skydvrr likes this.
  3. Oct 19, 2019 at 8:03 AM
    #263
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Wow. More bullshit disinformation just on these two pages than any other page on this entire forum. I wonder, just how many of you guys have ever retro-fitted a supercharger or turbo setup on anything? If you haven't you need to go on and get back on the porch and just watch and listen. First, right out of the box...did the Toyota engineers have the forethought and vision to equip the taco's engine block with enough excess crankshaft support to deal with the destructive loads it surely will see under WOT, considering all of the boost scenarios described above? Probably not. This ain't an LS or LT block. It is a block that was, at best, built by committee, with an eye to price point. At best it will require a girdle, as yet undeveloped. We also know that Toyota never intended for the Taco to really go off-road, don't we? Shouldn't it follow that we could also deduce from this that they didn't have the vision or intent to service factor the block for off-road duty or boosted service? Add in to the calculus that we suffer through the TCM's excessive shift programming. Then factor in that Magnason-type superchargers are known for their brutally instant production of torque that has been widely described as a hammer-effect of instant torque, ESPECIALLY down low at tip-off. No way to mitigate it. It is either hammering on, or off. Couple the two together and what you have is an already terrible driving experience that has been put on SC steroids as the TCM orders a two-gear downshift with attendant instant higher rpm, and in response the SC hammers in instant and brutal excessive torque to match that rpm increase. Oh, you gonna' love that. The drivetrain is gonna' love it too. And only 100hp for about $10K? OH YEAH! Have you ever seen a SC or turbo install that didn't necessarily require another $2-4K in ancillary parts to make it work right and last? At the very least, requires upgrading the fuel pump, (Lucky if it is just a fuel pump, if not controller, and then maybe even have to add a boost-a-pump bandaid over that to keep up with fuel pressure demand. Otherwise you are going to run it lean. You're talking $1500 at least to do the fuel right the first time.) Then, how you gonna monitor everything? With $1,000-$1,200 in gauging: A/F ratio, boost, fuel pressure just to name the basics. So, conservatively, $10K for 100hp. Madness. You can buy a UTV for that, trailer it with the Taco and when you get there, have a whole lot more fun.
    When, what month was this tested, and what were the ambient air temps when this was tested? What was the air temp post supercharger? 110, 145, or 195? Was it tested in everyday driving, say, in southern Florida in the summer? Or Arizona? Or SoCal stop-and-go freeway driving? Or in Houston's 3-season heat? Any larger intercooler options for these locales and others that will see massive heat soak? Using the larger intercoolers, how much timing had to be pulled in the heat to prevent detonation, and what was the hp with that much timing pulled? $, and more $. Ultimately, will we need to include an alcohol system to make this work? The problem is not with the supercharger, but with our truck design, and how and where we use them.
    Yeah, you can force-induct it, but remember, the candle that burns the brightest also burns the shortest. Guys, you can get a base Mustang GT with a Roush supercharger on it WITH A FACTORY WARRANTY, WITH A COYOTE BLOCK for less than $40K. 700hp. Now that's a real SC setup. WITH a FORD FACTORY warranty. So to contrast these two choices: As a Soviet super-heavyweight Olympic weightlifter once replied to the press when asked about a Turkish lightweight weightlifter who was lifting, pound for bodyweight pound, MORE than the superheavyweight, the big guy replied, "Who wants to watch little men lift little weights." About the second or third time you get your ass stomped leaving a red light by a grey-headed old fucker like me you are going to wish you had heeded the advice above. Ask me how I know...
    Insert mic-drop here.
  4. Oct 19, 2019 at 8:34 AM
    #264
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
  5. Oct 19, 2019 at 8:39 AM
    #265
    auskip07
    Skip
    Atlanta, Ga
    its almost like someone didnt read that Magnuson offers a 3year/36k warranty with the purchase of their kit.
    Dustin.K96 and GreyBaldTaco like this.
  6. Oct 19, 2019 at 8:40 AM
    #266
    GreyBaldTaco
    2019 F150 5.0
    Aren't our engines fairly over built. ie a forged crank?
  7. Oct 19, 2019 at 8:41 AM
    #267
    auskip07
    Skip
    Atlanta, Ga
    Thats what they say and OVT stated that the trans handled 450 hp fine on the dyno. (not much of an endorsement for DD but its a good start)
    i dont plan to be the first inline to get the kit i would rather wait a year and let others test it out.
  8. Oct 19, 2019 at 8:47 AM
    #268
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    That just sounds like an untested hypothesis to me...
    chincheezy and GreyBaldTaco like this.
  9. Oct 19, 2019 at 8:52 AM
    #269
    tonykarter
    Snuff Gully, Texas
    Does ANY COMPANY'S warranty wording include coverage for legal expenses incurred in making them honor that warranty, to also include summary judgement and a directed verdict? No, nobody's does. Does it say that if you blow a hole the size of a crank or piston anywhere in your motor that they will replace you motor, unconditionally, without charge to you for labor and new Toyota parts? I'm fairly sure it doesn't say that, but it does say something to the effect that if their product fails, yada yada yada, and we know that their product is not going to fail. They build among the finest superchargers in the world. So it is not their product that is going to fail. It's what it is attached to that is going to fail.
    BlkTaco47 likes this.
  10. Oct 19, 2019 at 8:55 AM
    #270
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    U know Toyota builds a TT variant of the 2gr right? Read through the OVtune thread. All your "points" are laid out.
    Thegenerik1 likes this.
  11. Oct 19, 2019 at 9:20 AM
    #271
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Definitely!
  12. Oct 19, 2019 at 9:33 AM
    #272
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    Only on TW would a vender offering a 3 year warranty be belittled.
  13. Oct 19, 2019 at 9:42 AM
    #273
    auskip07
    Skip
    Atlanta, Ga
    how many tundras have had issues with magnuson? and of those with issues how many were denied warranty claim? unless you're talking out your ass you must have some basis for this distrust of the company.
    GreyBaldTaco and Inferno! like this.
  14. Oct 19, 2019 at 10:02 AM
    #274
    tonykarter
    Snuff Gully, Texas
    I have no distrust of any company. Well, except Spectrum. And Dish. And HughesNet. And AT&T. And Verizon. Fuck, you're right. I don't trust any sons-a-bitches'. What I have is fifty years of learn-it-the-hard-way performance knowledge, engine building know how and in-car racing experience. Which qualifies me to evaluate this with more perspective and wisdom that most of the "all-in" participants of this thread. More than anything, I know from experience how to spend a shitload of money with blind enthusiasm, money that I really didn't have, or that I should have paid down my mortgage with, or saved for retirement, and later regret it deeply. All it takes is once and you learn quickly. Only trying to get some of you to better consider your choices, fully spreadsheet the costs of forced induction against the returns and chart the unseen but inevitable landmines these projects always produce. It's not the bolt-on that's going to break. It's the bolt-on-to. Speed and hp costs. Hand-grenading your daily driver will cost even more.
    https://www.tacomaworld.com/threads/3-4l-supercharger.629337/page-29
  15. Oct 19, 2019 at 2:06 PM
    #275
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Inferno![QUOTED] likes this.
  16. Oct 19, 2019 at 3:35 PM
    #276
    Inferno!
    El Dorado Hills
    auskip07 likes this.
  17. Oct 19, 2019 at 4:25 PM
    #277
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I called your mom. She says she’s sorry.
    rdpoe, RushT, TS7xTaco and 2 others like this.
  18. Oct 19, 2019 at 9:10 PM
    #278
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    LOL
  19. Oct 20, 2019 at 6:56 AM
    #279
    tonykarter
    Snuff Gully, Texas
    That IS funny, but you didn't find my mom. Orphaned at birth. I bet you are right though: She is sorry. If I could find her I'd tell her that there is no reason to be sorry, that she did the right thing. She set my path to a wonderful, blessed life.
    Now, back to the fray...
    BlkTaco47 and Stocklocker like this.
  20. Oct 20, 2019 at 7:54 AM
    #280
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Pretty much every modern engine has a stout block and crank due to nvh standards. Show me a modern block failing under low boost (not a rod windowing it either). I'm sure a rod or piston will give way long before the block or crank.
    And the blown mustangs power train isn't covered by Ford's warranty. It's covered by rousch. Just like other aftermarket supercharger.
