Maine
Discussion in 'North East' started by BSP4x4, Oct 27, 2009.
  1. Mar 11, 2015 at 9:48 AM
    #881
    20vmki
    20vmki Well-Known Member
    Eric
    Florida
    '03 PreRunner Limited
    OME 3in lift, Spidertrax 1.25in spacers
    Would the atlas/gazetter show the logging roads?
  2. Mar 11, 2015 at 9:59 AM
    #882
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
  3. Mar 11, 2015 at 10:04 AM
    #883
    20vmki
    Eric
    Florida
    Awesome, ordered!
  4. Mar 11, 2015 at 10:28 AM
    #884
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Can't go wrong with that atlas. As long as it is less than five years old it will be as accurate as Noelie says. Everything is on there. Sandy pond is maybe ten minutes from my house. If I was going to be around I would take some time to show you a few places.
  5. Mar 11, 2015 at 8:14 PM
    #885
    NH13LTD
    NH13LTD Member
    Scott
    Seacoats NH
    13 DCSB Limited 4x4 V6
    Elka 2.0s up front, 5100's in the rear, Toytec TSB 1.5" AAL, 265/65/18 Duratracs, StealthTaco grill, tonneau cover, color matched running boards, OEM bed mat, OEM All-Weather floor mats, OEM door sill protectors, thule roof rack
    I'm not sure exactly what the logging roads are like up in the North Maine Woods or how far north you are thinking about going, but this thread might help you out: http://www.tacomaworld.com/forum/north-east/58297-maine-45.html#post9987936
    I saw this thread a few months ago and am planning on heading up that way for a long weekend of camping with some friends this summer. Maybe something you can check out while you're in Maine.
  6. Mar 11, 2015 at 8:15 PM
    #886
    NH13LTD
    NH13LTD Member
    Scott
    Seacoats NH
  7. Mar 11, 2015 at 11:26 PM
    #887
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
  8. Mar 12, 2015 at 4:49 AM
    #888
    Noelie84
    Noel
    Wales, Maine
    That's WAY North. From the Anson area to Chamberlain lake it's about a 4 hour trip one way. The trains are definitely worth a visit, but they'd be better saved for a different vacation when you could spend the whole time exploring up that way.
  9. Mar 13, 2015 at 4:40 AM
    #889
    MuddyTRD
    MuddyTRD Active Member
    Maine
    14 TRD Offroad
    Ok, I can't find a good way to make a map for you at the moment. But the ones that come to mind would be the Gold Brook road, which goes from Chain of Ponds above Eustis all the way over to Parlin Pond, above the forks. It can be done as a 40-some odd mile dirt road straight shot through, or you can spend DAYS exploring the offshoots. This is about as far north as you would probably want to go as a day trip.
    The next that I usually go on is the Lincoln Pond road, which goes from Aziscohos Lake to Eustis, near Flagstaff lake. Same idea, shorter but lots of side roads. Both roads cross/pass miles of water. I do most of my fall fishing in this area. Also some good wilderness camping spots you can book on this road.
    Bemis Road is a good short dirt road, but the views you miss using it instead of the main road isn't always worth it. If you get a chance drive up quill hill just above Rangeley. I'm right in Farmington and depending on my work schedule I might be able to play tour guide a little.
    The things to keep in mind: Every body of water has different rules for fishing. Lots of artificial lure/fly fishing only in this part of the state. Get your law book and know where you are fishing. Whereever you get your license should have the law book available for free.
    Now the 2 big things: These are active logging areas. The trucks have the right of way. They are coming through loaded and fast, and they aren't stopping. Best bet is having a CB radio tuned to their channel, for the most part they do a good job of letting you know where they are. Return the favor and stay out of the way and you will have a good day.
    The other thing is that these are big woods. Roads can be poorly marked. Little/no cell signal. I've had the best luck with a Maine Atlas and a mapping GPS. Typically the combination gets you back on track. Make sure people know where you are and when you are returning, and try not to travel alone.
  10. Mar 13, 2015 at 7:20 AM
    #890
    Tacoma Mike
    Southern Maine
    great advise right here.....:thumbsup:
  11. Mar 13, 2015 at 7:57 AM
    #891
    BRUIN8124
    Mark
    A+ sir!!!! +1. I want to go now! I love it up there!
  12. Mar 14, 2015 at 4:59 AM
    #892
    newenglandjim
    newenglandjim Active Member
    jim
    northeast
    08 tacoma 4drsb 4x4
    pinstripe, bullbar and best topper.
    Great job muddy! I have a camp in Sangerville and am just learning some of the logging roads. Imcan't wait to get my fly rod out this year and go after some brookies.
  13. Mar 17, 2015 at 11:59 AM
    #893
    BRUIN8124
    Mark
    ugh...
    Can anyone recommend a good, honest and reasonably priced mechanic in the Bowdoin/Sagadahoc County area? (If that exists...)
    Thanks all!
  14. Mar 17, 2015 at 12:13 PM
    #894
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    What are you having done?
  15. Mar 17, 2015 at 12:22 PM
    #895
    BRUIN8124
    Mark
  16. Mar 17, 2015 at 12:58 PM
    #896
    ACEkraut
    Aaron
    Durham, Maine
  17. Mar 17, 2015 at 1:08 PM
    #897
    BRUIN8124
    Mark
    Pretty much brand new, replaced it about 2 months ago.
  18. Mar 17, 2015 at 1:37 PM
    #898
    ACEkraut
    Aaron
    Durham, Maine
    Is your 4Runner used everyday and run for a good half hour or so?
  19. Mar 17, 2015 at 1:41 PM
    #899
    ACEkraut
    Aaron
    Durham, Maine
    I use Lee's Tire in Topsham quite a bit. Not the cheapest, but the are reasonable and a pretty straight shooter. Worth a call to explain your problem and see if they can help you. Ask for Peter if you call.
  20. Mar 17, 2015 at 1:41 PM
    #900
    BRUIN8124
    Mark
    It is. At the very least, it is run 20 minutes to work, 20 minutes home 4 out of 7 days a week. Commute is mostly highway.
