maint light flashes 6 times then goes off.
Discussion in '4 Cylinder' started by silverback, Mar 30, 2010.
  1. Mar 30, 2010 at 8:11 PM
    silverback
    silverback [OP] Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    When I turn the key to the on position without starting the engine, I noticed that the main required light blinks six times then goes off. I also noticed the my oil light , battery light and check engine light stay lit until I start the truck then everything turns off. Is this normal and what could be the reason. I have searched google for the answer but to no avail.
  2. Mar 30, 2010 at 8:15 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    That light blinking is to.remind you its getting time to change your engine oil via your mileage you have travelled. In 1000 more miles it will come on and stay on. Check your manual for more info and how to reset it.
  3. Mar 30, 2010 at 8:17 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    to reset, turn key to acc, press odometer trip button and hold till you see 0's across the display.
    pretty sure thats it, ive only had to do it once on mine i may have left out a step
  4. Mar 30, 2010 at 8:18 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    when it comes on you've hit 5000 miles since it was last cleared and you just hold down the odo button with the key off then turn the key on while still holding it down and wait for it to stop flashing
  5. Mar 30, 2010 at 8:18 PM
    efmugen
    efmugen Well-Known Member
    Pasadena,CA
    06 4-banger
    time to change the oil bro....
  6. Mar 30, 2010 at 8:19 PM
    revhappyleon
    Manny
    Tampa near macdill
    damn! posted out from under me . . . that makes sense right
  7. Mar 31, 2010 at 10:31 AM
    silverback
    central CA
    2006 Prerunner SR5
    I checked the oil and it is slightly brown, not too bad. Thanks fellas I'll do that and change the oil screw it. Its my baby.
  8. Apr 1, 2015 at 12:44 PM
    Amy A. Oakeley
    Amy A. Oakeley New Member
    Oil light, brake light and seat belt light stay on when truck is turned off. WHY?
