Maint. req. light
Discussion in 'Technical Chat' started by JATaco, Aug 15, 2008.
  1. Aug 15, 2008 at 8:22 AM
    JATaco
    JATaco [OP] Well-Known Member
    Las Vegas
    tacoma prerunner
    I have a 07 v6 prerunner dc w/ 29,200 miles. Today i was driving hm. right when i pulled in my driveway the maint. req. light came on. I know im getting close to 30k service. What do u guys think i need done? Is it still ok to drive? I was going to take it to dealer @ 30k to have them change plugs & diff oil. I do oil changes myself w/ mobil 1. What should i pay for this service at dealer? How do reset the maint. req. light? I know i have alot of questions, but i know there are alot of good info on this site.Pls hlp. thanks
  2. Aug 15, 2008 at 11:55 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    follow this to reset the maintenance light after you change your oil......
    http://www.tacomaworld.com/forum/2n...neration-tacoma-s-reset-maint-reqd-light.html
    for the 30k service...........if you have the tools, do it yourself and save money. the dealer wants too much for it, and its mostly checking stuff. you need to change the plugs if you have the v6, change the diff oil(real easy), then check the air filter, rotate tires and adj. air in them, and the rest is basic visual checking of things, topping off fluids,etc.
  3. Aug 15, 2008 at 12:22 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    FYI, the maintenance light is strictly a mileage counter.
  4. Aug 15, 2008 at 12:43 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I have a question about that, that light on my 05 came on last year, when I took it to the dealer I found out I had cracked the gas cap, something to do with a pressure seal? they of course replace it at no charge.
    Never had any issues since that.
  5. Aug 15, 2008 at 12:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, there are 2 lights......service engine soon light, and the check engine light.
  6. Aug 15, 2008 at 12:53 PM
    longbow
    Bill
    Indiana
    well crap, never seen the other come on, at least i'm doing something right.
  7. Aug 15, 2008 at 4:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :D
  8. Dec 5, 2008 at 8:18 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Was looking for an answer and this was close, so I'll just use this thread instead of starting a new one...
    My 30k mile maint. is coming up. I plan to change the oil, spark plugs, clean the AFE filter in the engine and replace the cabin air filter all myself. I have a lifetime rotate and balance at the Goodyear place by my house, too.
    Other than what's noted above and the inspections, the manual also suggests replacing the LSD oil (if equipped). I have the rear locker, not the LSD. There's no need for me to change any fluid, right?
    Also, how much do you think the dealership will charge me to "re-torque the propeller shaft bolt"? Is it necessary? Can I do it myself?
    Thanks!
  9. Dec 5, 2008 at 12:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the rear locker diff needs the fluid changed also at 30k. just go with some mobil1 75w90.......3 quarts will do it.....good stuff. as far as retorquing the prop shaft...............i seriously doubt that any "tech" at the dealership would even look at it, even though they are supposed to. just take a wrench under the truck and make sure all the bolts on all parts of the driveshaft are tight and call it a day. thats what i have done on my 06 and now on my 04 also.
