Maintanance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chicken lips, Jan 19, 2009.
  1. Jan 19, 2009 at 3:48 PM
    chicken lips
    chicken lips [OP] Well-Known Member
    Jose Garcia
    riverside
    07 tacoma
    bone stock for now
    hey guys i want to know at what milage should i service my truck, im talking about flushing the tranny, radiator, diff pretty much everything, and how much lube it takes
    add more things that should be service regurly
  2. Jan 19, 2009 at 3:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    My truck came with a maintenance log along with the manual. Do you have that? It tells you what mileage you should change out your fluids. Every things pretty simple until you hit the 30,000 mile marker like me in 6,000 more miles.
  3. Jan 19, 2009 at 4:00 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Really with all of the tranny and diff......Never. unless you have a leak, Very rare on a Taco.
    I service my truck (oil, and check coolant) every 10,000- 15,000 take or give a few
  4. Jan 19, 2009 at 4:00 PM
    chicken lips
    Jose Garcia
    riverside
    07 tacoma
    bone stock for now
    i dont have the manual, i bought the truck off my uncle and he didnt know he told me it didnt have one(yea right he threw it out) and im over 30k
  5. Jan 19, 2009 at 4:02 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I think some of that data is in the owner's manual as well... but I'm not sure.
    EDIT: nevermind -- just saw that you don't have the manual
  6. Jan 19, 2009 at 4:03 PM
    Lentsnh
    best bet go ahead and change out all fluids. you'll be fine with the tranny and diff. im at 65,839 miles still in the same factory fluids
  7. Jan 19, 2009 at 4:17 PM
    Stangman
    Stangman Active Member
    Edgewood,MD
    06 Tacoma SR5
    2.5 " lift,32 " tires, Black taillights, Trd Sport seats, Smitybilt side steps and bull bar, CCFL Black Headlights, Overhead compass console, Auto Dimming Rear View Mirror
    Hey Chicken Lips...you can go to toyotaownersonline.com-click on the scheduled maintence tab and input your info. On my taco, I changed the diffs and transfer fluid every 30k. At 60k, I put Amsoil gear oil in so I wouldn't have to change it for 100k. I also flushed the trans at 60k. It's WS fluid and doesn't need to be, but I work at a dealer and have access to fluid and the machine to flush it. At 60k I also put in Irredium plugs so I am good for another 120k on them. Hope this helps.
  8. Jan 19, 2009 at 4:25 PM
    Snyperx
    Snyperx Seniore Marcos
    I was just going to post the same thing. All the documents are available for download. YOu can also get a full copy of the repair manual if you know where to look. I can get you that link if you want. It's a 200+ megabyte download.
  9. Jan 19, 2009 at 4:29 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Do you worry about getting them out after 120k? Do you use Never Seeze?
  10. Jan 19, 2009 at 4:35 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You should not have to change your engines coolant. Make sure to either check it with a refractometer or hydrometer before wasting the money on new coolant.
  11. Jan 19, 2009 at 4:47 PM
    SC4333
    Grant
    FL
    I just remembered something that is very important to take into account. Propylene-glycol coolants cannot be measured accurately with a hydrometer due to there high specific gravity. A refractometer will measure both propylene, and ethylene-glycol coolants very accurately and measurements are not drastically altered due to temperature, as hydrometers are. Just something to think about. Its probably not worth buying unless you do quite a bit of automotive work. Test strips are the next best thing.
    http://www.sjdiscounttools.com/rob75240.html
  12. Jan 19, 2009 at 5:17 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah the biggest things on the 30,000 mile maintenance is changing out the differential oil, spark plugs, air filter, in-cab air filter and then your regular engine oil + filter and a tire rotation. I bought all the stuff before hand so I can do the job myself.:D
  13. Jan 19, 2009 at 5:35 PM
    Snyperx
    What is the best way to change out the front diff oil? It seems almost impossible to get access to the front diff. fill hole.
  14. Jan 19, 2009 at 5:46 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Which engine do you have? The 4 cyl comes with the iridium spark plugs already installed, so they are good for 100k. The 6 cyl doesn't, and many people switch them over to the iridiums around the 30k mark.
  15. Jan 19, 2009 at 6:19 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I have the v6. I was told to stay away from the iridiums and stick with OEM so I did. Got some Denso's.
  16. Jan 19, 2009 at 6:21 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ummm see if you can find tacomaman06. He's the one that helped me out with the diff oil stuff before I bought everything.
  17. Jan 19, 2009 at 6:22 PM
    red06toy
    red06toy Well-Known Member
    Worcester MA
    Impulse red OR, 2.5 lift
    2.5 toytec, bilstein 5100 black grille, black lights, partially shaved decals remaning ones black, , trd fj wheels, sirius, Ipod interface, pre-filter delete
    I go by the book in the truck, except for oil. I change that (filter too) every 3000, not 5000 like the book says.
  18. Jan 19, 2009 at 6:25 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Do you use synthetic or regular. See i switched to synthetic shortly after I got my truck and would change it every 3,000 but lots of people said it was a waste and not to worry about it until 5,000 so that's what I'm going to start to do.;)
  19. Jan 19, 2009 at 9:35 PM
    wawireguy
    wawireguy Well-Known Member
    I'd check your diff fluids if you 4x4 in deep water. My old chevy used to get contanimated diff fluid from off roading. Most vehicles won't have that problem though.
  20. Jan 20, 2009 at 4:43 PM
    Stangman
    Edgewood,MD
    06 Tacoma SR5
    Ok guys....this is the only problem I have with going by the book. It tells you to change driveline fluids only if you tow. I work at a dealer and have seen plenty of Taco's and FJ's the have diff problems with no history of changing fluids. It's not hard to do even at home and is not expensive. As for the 120k plugs, I haven't had what I would call alot of problems with them sticking in the head or pulling the threads. JMO
