maintenance cost question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RollTideRN, Jun 19, 2012.
  1. Jun 19, 2012 at 12:42 AM
    RollTideRN
    RollTideRN [OP] Well-Known Member
    Barrett
    Robertsdale,AL Sacramento,CA
    08 TRD Sport Speedway Blue
    custom billet grill, behind grill light bar, 4 hella 500's, custom ham radio install.
    Hi all,
    Need some advice on costs. I went to a local shop here in town and they quuoted me some prices. I would do some of this myself however I am traveling right now and all my tools and such are 3000 miles away. So with that being said here are the prices quoted. Let me know if I am getting robbed.
    Plugs and pcv valve- $143.50
    tranny $134.00 not a complete flush
    rear diff $80
    Coolant flush $104
    Any advice is appreciated.
    Barrett
  2. Jun 19, 2012 at 12:46 AM
    evanwile
    evanwile Canadian Pomp
    Evan
    Canada
    2018 TRD Sport 6M
    All of those seem high to me.
    Ill check my last invoice that I had those same items done when i get home, but ill try to remember off the top of my head:
    Plugs (no PCV) was $115
    Tranny Drain and fill was $53
    Rear diff was $33
    Didnt have the coolant done.
    These prices were done at the toyota dealer and are in Canadian Dollars..
    Good luck!
  3. Jun 19, 2012 at 1:10 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    yeah those prices seem high to me.
    you could buy the tools and do it yourself for a lot cheaper
  4. Jun 19, 2012 at 7:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you referring to your 2008 AUTO? How many miles on your truck?
    The AUTO transmission doesn't need servicing for like 100,000 miles. We don't even have dipsticks on these trucks to see the fluid levels.
    Your radiator fluid doesn't need servicing or changed for 100,000 miles.
    You can look up your maintenance schedules in your owners manual or look here:
    http://www.toyota.com/owners/web/pages/resources/owners-manuals
    Other than that....you should change rear diff & front diff oils at the same time. The front diff is spinning just as much as the rear diff is. If you're not at home, costs may vary depending where you are. The best bet is to call around and get quotes from different shops/dealers. But always remember - you get what you pay for.
  5. Jun 19, 2012 at 7:53 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not true, 100 000 miles on factory fluid in Auto is pure BS. If people dotn do maintenance around 60-80 000 miles they will most likely need new transmission.
  6. Jun 19, 2012 at 8:13 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had a drain and fill done at the 5 year mark...truck had 18,500 miles.
  7. Jun 19, 2012 at 8:48 AM
    Janster
    Jandy
    Lancaster, PA
    That's what TOYOTA recommends..... and the only reason I mentioned it. It's a factory recommendation.
    Whatever you do with your maintenance, is completely up to you.
  8. Jun 19, 2012 at 11:01 AM
    OffroadToy
    They also recommend that it be changed out every 60,000 miles or 72 months (whichever comes first) under special operating conditions like towing/offroad use.
  9. Jun 19, 2012 at 11:50 AM
    RollTideRN
    Barrett
    yes, it is a 2008 with 95000 on the odometer.No front diff.
