Maintenance question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Feb 12, 2024.
  1. Feb 12, 2024 at 6:31 AM
    Hauser94
    Hauser94 [OP] Well-Known Member
    2016 Black Tacoma SR5 DCSB
    Couple maintenance questions got my 16 at the dealership for oil change, got their little text report of the inspection they do. There were 3 things on there that they recommended. And I think they’re money grabs but wanted opinions on it.
    1 was alignment, truck couldn’t drive any straighter and I’ve never noticed any pull whatsoever but it said failed laser test. $142
    2 was clean throttle body? I don’t see it on the maintenance map $127
    3 clean fuel injectors, again dont see it on the maintenance map $214
    what do ya’ll think? Dealership looking for free money?
  2. Feb 12, 2024 at 6:40 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It honestly wouldn't hurt to get an alignment, especially if it hasn't been done in a while. While you might not feel it, you'll notice it in your tires. Not sure on the price the dealer is charging. Independent shop here is $99. If you live in a rust belt state be prepared to spend some money if the lower cam bolts are seized.
    Throttle bodies do carbon up after a while and do benefit from an occasional cleaning. However that price is absurd. A can of throttle body cleaner is under $10 if you can DIY.
    That fuel injection cleaning is a cash grab thing. Grab a couple bottle of Techron and throw in a couple full tanks of gas. They probably have one of those BG machines.
    rndsommer40, joba27n, Chew and 2 others like this.
  3. Feb 12, 2024 at 6:42 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It never hurts to get an occasional alignment to improve tire wear. As far as the other stuff; if she is running fine then I would skip it. You can run a bottle or two of Techron through your engine and probably get the same results.
    Stevie17, Hauser94[OP] and Delta09 like this.
  4. Feb 12, 2024 at 6:43 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Throttle body clean should probably be done every 50k to stave off any issues. If you are mechanically inclined it is fairly easy to do.
    Junkhead and Stevie17 like this.
  5. Feb 12, 2024 at 7:15 AM
    Uninformed83
    Uninformed83 Member
    Brian
    2020 TRD OR
    Fox 2.5” w/res, 17” RRW RR7-s w/ Toyo at3s, OTT tune
    Driving straight doesn’t mean it’s aligned properly, you could be toed in or have bad camber wearing the out side of the tire unevenly but still track straight. TB cleaning and injector cleaning is pure profit for them. Skip it and do it yourself if you are worried about it.
    ToyoTaco25, Stevie17 and Hauser94[OP] like this.
  6. Feb 12, 2024 at 7:19 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I have no idea where information like this starts, but it is false. Unless someone is running an oiled foam air filer (a misnomer if there ever was one), you should never need to clean the throttle body for the life of the vehicle.
  7. Feb 12, 2024 at 7:34 AM
    Hauser94
    Decided to do the alignment, gona do techron next gas refill and not even worried about the throttle body
    Smacky2020, JG1980 and Stevie17 like this.
  8. Feb 12, 2024 at 7:41 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    It's all dependent on the operating environment of the vehicle. But to say one should never clean their TB is very strange statement to begin with.
    Wessty, swdockter, TheWildMan and 5 others like this.
  9. Feb 12, 2024 at 7:47 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id look at the tires, do they look worn irregular? Just the same look at the throttle body. If it looks clean leave it alone, techron is good like said above in previous post.
    shakerhood, TacoSR523 and Stevie17 like this.
  10. Feb 12, 2024 at 8:36 AM
    Horseshoez
    Dale
    Maryland
    I stand by what I said, one should never have to clean the throttle body for the life of a vehicle.
    ToyoTaco25 likes this.
  11. Feb 12, 2024 at 8:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    See that large crankcase vent hose connected to the intake tube upstream of the throttle body?
    PTSDTherapy likes this.
  12. Feb 12, 2024 at 8:43 AM
    Horseshoez
    Dale
    Maryland
    LOL, upstream of the throttle body? Seriously? Do you understand which direction the gasses flow through that tube?
  13. Feb 12, 2024 at 8:56 AM
    JG1980
    JG1980 Well-Known Member
    Whitinsville, MA
    2023 TRD Off-Road Access Cab
    As was mentioned before, you might not always feel the mis-alignment, probably not a bad idea. But I'd consider having an independent shop do it. You can ask around your area who does a good job. Typically it's around $100, and a quality independent shop will likely do a better quality job.
  14. Feb 12, 2024 at 9:02 AM
    wilcam47
    Will
    Bourbon state
    never is a long time. Just depends on environment. Doesnt hurt to take a look. If its dirty clean it, if its not leave it alone.
    https://mechanicbase.com/maintenance/throttle-body-service/
    Junkhead and Squirt like this.
  15. Feb 12, 2024 at 9:06 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    $483 is a lot of money for those three jobs. IMO, if the tires are wearing normally/evenly, you don't need an alignment. The throttle body is a fairly simple job but watch a couple videos on how it's done and what is involved. Stick with Top Tier Gas stations (it will say it on the pump) and you shouldn't need to have the injectors cleaned. I add a bottle of Techron once per year to a half tank of fuel just before the truck is ready for an oil change. It's one of those products on the shelf that actually works. On my truck, if I check the oil on the dipstick before and after using the Techron: it looks a little darker after using it.
    The Care Care Nut on YouTube just did a video on alignments and he has one on fuel additives and Throttle Body cleaning as well.
    TacoSR523 likes this.
  16. Feb 12, 2024 at 9:15 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It’s all crap. First stop taking your truck to the dealer for maintenance. Find a shop you trust and bring your vehicle there for maintenance .Dealers are way way expensive , 2 to 3x what a private shop charges. As far as alignment take your truck to a tire and alignment shop and get their opinion. If it needs alignment again it’ll be cheaper. #1 and #2 are laughable. Dealers are notorious for doing unnecessary work to take your $$$.
  17. Feb 12, 2024 at 9:21 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    On the alignment, years ago I went in to get my free tire rotation and pick up an oil filter (not letting them change my oil even if it is for free). They did that laser check in the bay and told me I needed an alignment. So, I told them to go ahead. They gave me the report off the actual alignment rack, and my "before" numbers were near perfect and "after" numbers barely changed. I told them they owed me a free alignment but never went back for it. Don't trust the laser check, especially since some kid probably did it while watching TikTok videos.
    The throttle body and fuel injector cleaning is a money grab. Just get a bottle of Techron and put it in the tank when you fill up. The other one you will see is a power steering fluid flush. Not bad to do about the same time as auto transmission fluid.
    WV_Tacos likes this.
  18. Feb 12, 2024 at 10:09 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Yeah just because the laser can measure arcseconds doesn’t mean the mechanism can be adjusted that precisely!
  19. Feb 12, 2024 at 10:09 AM
    Horseshoez
    Dale
    Maryland
  20. Feb 12, 2024 at 10:14 AM
    3rd gen AC SR5 4x4
    Manual also states lifetime auto trans fluid.....
