Maintenance Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WarrenH, Jul 10, 2013.
  1. Jul 10, 2013 at 9:11 AM
    WarrenH
    WarrenH [OP] Active Member
    Lake Stevens, WA
    V6, Long Bed, TRD Sport
    I've seen several maintenance threads but have a few questions I am still unsure about.
    In a 2011 Sport, is it okay to use Castrol Syntrax Limited Slip 75-90 Gear oil in the rear differential? I've usually only done oil changes on my vehicles, but am starting to do more of my own stuff. I still have a lot to learn though.
    I'm at 30,000 and had a free standard maint from the dealer and they essentially did a 25K service and I figured I'd do the rest to make it a 30K. But I'm wondering how much they did. Does a dealer normally do the items listed under the special conditions (towing and offroad)?
  2. Jul 10, 2013 at 7:09 PM
    WarrenH
    Lake Stevens, WA
    Called Oreilly's, they said that the LT in the rear isn't a problem.
  3. Nov 13, 2013 at 2:33 PM
    yarro
    yarro Well-Known Member
    Tacoma, WA
    11' TRD Off Road DCSB
    TREX Eyelids. RIGID Fogs Toyota Skid Plate. AVID Light Bar. Rigid SR 20"Combo LED bar OEM Toyota Running Boards, LEER Canopy RIGID Roof Rack - COMPLETE. FJ cruiser Switch panel install in center isle. (4 new slots for OEM switches) Glove box & Center counsel Lighting with amber switch.
    As far as I was told when I was doing my first rear differential oil change, Limited Slip was ok on the non Limited Slip differentials. but if you had Limited Slip than you had to put in LS. there's supposed to be a sticker of some sort under the truck where you put in and drain the oil. I believe I used Mobile one with LS
  4. Nov 13, 2013 at 2:37 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
