Maintenance questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Feb 28, 2008.
  1. Feb 28, 2008 at 4:28 AM
    evile
    evile [OP] Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    Got a Couple quests about teh 30k mile Maintenance for the Tacoma
    1. where the hell is the fuel filter? I put it on my lift and looked all over couldnt find it any where
    2. What type of Transmission fluid does it take
    3. Spark plug recommendations? manual say change at 30k for the emmisions warranty
  2. Feb 28, 2008 at 8:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm not much help here and have limited time...
    Here's an online version of the Factory Service manual. You can look around in there and see if yoiu can locate the filter. What transmission do you have? Auto or manual?
    Spark Plugs? When I did my 96 - I went with factory plugs. And only because they were already gapped properly and cost about the same as *the others*.
  3. Feb 28, 2008 at 10:01 AM
    evile
    Orlando, Fl
    sorry forgot to add its an Auto tranny
  4. Feb 28, 2008 at 10:25 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I believe the fuel filter is in the tank itself (fuel pump) and doesn't need changing until 100K. Someone correct me if I'm wrong...
  5. Feb 28, 2008 at 10:27 AM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    You shouldnt need to do the fuel filter yet. Same with the tranny fluid, just check the level and the color of it, should be a dark redish
  6. Feb 28, 2008 at 1:17 PM
    evile
    Orlando, Fl
    LOL ok gotta remember i work on Fords every day heres what our 30k includes
    oil and filter
    rotate tires
    air filter
    fuel filter
    flush transmission
    throttle body service
    fuel injector flush service
    some of the newer fords like the 500/taurus have trans fluid that lasts longer but i wasnt sure what the tacos had
  7. Feb 28, 2008 at 2:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    transmission fluid is supposedly good for 100k miles(ws fluid)(unless you tow alot, then you may opt to do it sooner).
    fuel filter is basically non-serviceable(or so i've heard)....and in the tank. and like the tranny fluid....you may opt to do it sooner than recommended(i probably will....i would hate the fuel pump going out after the warranty expries)
    sparks plugs....if you have the 4 banger....you are good til 100k, v6.....plugs should be changed at 30k according to toyota....and if you decide to go with iridiums, they are good for 100k.
    rear diff fluid should also be changed according to toyota(i did mine at 20k and went with mobil1 syn.).....also at 30k, i'll probably clean my throttle body also.
    the rest is basic really.....rotate tires, change oil, check/change air filter if needed, check/change cabin air filter if needed, check/fill fluids as necessary.
  8. Feb 28, 2008 at 3:51 PM
    evile
    Orlando, Fl
    do the tacomas have cabin air filters?
  9. Feb 28, 2008 at 4:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    behind the glove box. the 05's didnt i dont think, but the 06 and up does.
