Maintenance Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bengland25, Jan 21, 2012.
  1. Jan 23, 2012 at 6:21 PM
    #41
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    OK. I would reccomend you get yourself a tread depth gauge and check the actual depth. Your truck is driven probably 90% of the time in 2wd, thus the rear tires will wear out faster than the fronts. If the wear between the front and rear gets too far apart, you can damage the transfer case when you use 4wd. :cool:
  2. Jan 23, 2012 at 6:31 PM
    #42
    Taco11
    Seattle WA
    Almost forgot, you may want to replace your PCV valve while your at it as I'm sure its never been done.
    Looks like there are still some K&N believers out there on here.. I would not reccomend the use of any oiled air filter as it can lead to the MAF sensor getting covered in oil causing it to read innacurately or potentially fail. I use Mann filters personally.
  3. Jan 23, 2012 at 6:32 PM
    #43
    Bengland25
    Bengland25 [OP] Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    good to know, thanks man! ill take it over to my buddies tire shop and have him rotate them for me just to make sure
  4. Jan 23, 2012 at 6:53 PM
    #44
    Taco11
    Seattle WA
  5. Jan 27, 2012 at 5:58 PM
    #45
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Was at Autozone today and the guy told me the NGK Iriduim IX will work with the truck. Been reading on here that most people do not like them due to acceleration issues. Most of those cases were for 1st Gen's. Anyone with a 2nd gen v6 4.0 have any input on these?! Bought them but want to know before I install so I dont waste the little fortune that these cost....
    THANKS!
  6. Jan 27, 2012 at 6:01 PM
    #46
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Return them and get the stock denso's from the dealer.
  7. Jan 27, 2012 at 6:10 PM
    #47
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    X'2
  8. Jan 27, 2012 at 6:17 PM
    #48
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yeah, bought them after I realized they dont seem to work in my truck! guess ill be going back and then picking up some Denso's from the dealer or something! thanks guys
    :cheers:
  9. Jan 28, 2012 at 4:36 AM
    #49
    VORTMAX_99
    VORTMAX_99 Member
    I'd suggest removing and putting a bit of anti-seize on the pins
    that hold the brake pads in the front brake calipers, especially if
    you live up here in the rust belt.
    On my 99, when I went to replace front brake pads at around
    60,000 miles, I didn't think I was going to be able to remove the
    pins as they had started to seize in the caliper. Luckily, I was
    able to finally get them removed, and thereafter, I pulled the
    pins and anti-seized them every 6000 miles when I rotated the
    tires.
    On my 09, I kept an eye on them and sure enough around 24000
    miles (after 2 winters worth of salted roads), you could feel where
    they were beginning to seize again. I went back to pulling the pins
    every tire rotation and applying anti-seize again. You don't have
    to pull the pads, just do one pin at a time. It will save you a lot
    of hassle come time to change the pads.
    Geo.
  10. Nov 4, 2012 at 3:25 PM
    #50
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Bump, Finally finished all of this, Took way too long to get to it IMO but atleast it is done. The magnets in the Diffs were atrocious. happy they are cleaned and good to go now. Need to just order the redline MT-90 for the tranny and do that real quick.
