Maintenance Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bengland25, Jan 21, 2012.
  1. Jan 21, 2012 at 1:42 PM
    Bengland25
    Bengland25 [OP] Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Hey guys, gonna do some maintenance on my truck and want to make sure I'm covering everything and want to know if im missing anything or if you guys suggest anything else that I do.
    BTW I have a 2009 Tacoma Access Cab with the v6 4.0 Manual transmission with around 60,000 Miles
    Also if you guys have some experience and preference with certain products that would be great!!!
    What I am going to do:
    >Front and Rear Differential and Transfer Case Oil Change:
    -5 quarts 75W-90 gear oil
    >Manual Transmission Oil Change:
    -3 Quarts Redline MT-90 (75W-90) Gear Oil
    >Oil Change:
    -5.5 Quarts 5W-30 Valvoline Full Synthetic
    -Mobil 1 filter or OEM Filter
    >MAF Sensor:
    -MAF Sensor Cleaner (Not sure what brand is good??)
    >TB Cleaning:
    -TB and Intake Cleaner (Not sure what brand is good??)
    >Air Filter:
    -Usually get a fram but would like to get something better...
    SUGGESTIONS???
    >In-Cabin Air Filter:
    -Going to build the washable/re-usable one
    >Spark Plugs:
    -Denso plugs
    >Grease Zerks:
    -What type of grease you guys recommend?
    >Brake Fluid:
    -DOT3
    >Coolant:
    >Power Steering Fluid:
    >Rotate Tires:
    That is all I have for now, what I am missing and what products do you guys recommend on those services??
    Thanks in advance Guys and Gals of TW
    :cheers:
  2. Jan 21, 2012 at 2:35 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Unless I'm blind, you left out the most important piece of information : YOUR MILEAGE
    Follow the intervals recommended by Toyota - that's all you need.
  3. Jan 21, 2012 at 2:37 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Good point, figured I would take care of everything that im able to so i dont have to over pay the dealership for stuff that i can do!
  4. Jan 21, 2012 at 6:53 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Bump! Anybody have some other suggestions of other things to check before I go buy all this good stuff??
  5. Jan 21, 2012 at 7:00 PM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
  6. Jan 21, 2012 at 7:03 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
  7. Jan 21, 2012 at 7:03 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Subtle! I like it haha
  8. Jan 21, 2012 at 7:04 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    I'll check em and clean em or replace them if need be. Thank you!
  9. Jan 21, 2012 at 7:05 PM
    Dark_Taco
    2023 TRD Pro
    Stock
    At 60K if they have never been done.....just replace them with the Denso's
  10. Jan 21, 2012 at 7:09 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Alright then, decision made. Adding plugs to the list!
  11. Jan 21, 2012 at 7:13 PM
    Dark_Taco
    2023 TRD Pro
    Stock
    Do you have 4wd?
  12. Jan 21, 2012 at 7:14 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What about changing your rear differential gear oil?
  13. Jan 21, 2012 at 7:18 PM
    Dark_Taco
    2023 TRD Pro
    Stock
    If you have 4wd grease the zerk fittings. What about changing your cabin air filter.
  14. Jan 21, 2012 at 7:18 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yes 4WD. And is the rear diff same gear oil as front diff? And how much does the rear diff take?
  15. Jan 21, 2012 at 7:19 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Another good one! Cabin filter is on the list.
  16. Jan 21, 2012 at 7:19 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Clutch fluid
    brake fluid
    power steer fluid
    coolant
  17. Jan 21, 2012 at 7:22 PM
    Dark_Taco
    2023 TRD Pro
    Stock
  18. Jan 21, 2012 at 7:22 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Sounds easy enough! Thanks man.
    All of those are on the list. Just didn't write them down. I'll update that later tn.
  19. Jan 22, 2012 at 12:20 PM
    cjthedj
    cjthedj Member
    Chadd
    WV
    06 extended cab
    The cabin air filter most people don't know exists but I change mine every few months and my 06 with 300k still smells good inside. Sounds anal but.. Everytime I change it there's a world of difference
  20. Jan 22, 2012 at 12:21 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i dont have a 4x4 but dont most transfer cases use ATF not gear oil?
