Major loss of power 4cyl!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 28, 2015.
  1. Dec 28, 2015 at 2:56 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I just installed an AFE pro dry s airfilter today and some new headlights. I drove it a bit and it was fine. Went to take it out and test my headlights in the dark anddddddd .... I started it up with the clutch in and the revs immediately started dropping and continued to drop below 1000. They got to about 300 and I shut it off. Started it up and it was fine revs sat around 1000. Even though they are sitting at 1000 that is a bit low from what they used to be. They usually stay at 1400-1500 until its warmed up. Now it stays at 1000-1100 right on startup. Could this just be due to having a brand new very clean airfilter on? Or does the computer need to reset?
    Liam
  2. Dec 28, 2015 at 2:59 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    check all the electrical plugs and vacuum lines, I bet something came unplugged on something you touched, or near something you just worked on
  3. Dec 28, 2015 at 3:00 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    @Rock Lobster
    ^^^this guys knows i'm sure^^^
    Sounds like ICV, or like the other fella said some sort of vacuum line has fallen off.
  4. Dec 28, 2015 at 3:04 PM
    goldentaco03
    Liam
    NJ
    Now that I think of it I dont think I plugged the line back in on the side of the airbox......
  5. Dec 28, 2015 at 3:06 PM
    goldentaco03
    Liam
    NJ
    Scratch that it was hooked up
  6. Dec 28, 2015 at 3:07 PM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    And you can quote me on the quote me on the quote, unquote.
  7. Dec 28, 2015 at 3:49 PM
    goldentaco03
    Liam
    NJ
  8. Dec 28, 2015 at 4:18 PM
    goldentaco03
    Liam
    NJ
    Guess that afe filter really makes a difference.
    I've decided on an Ecu reset which I'll do in the morning before I drive to Toyota for that spare tire carrier recall. I had the battery unplugged for my lights but then plugged it back in and did the filter later.
  9. Dec 28, 2015 at 4:43 PM
    goldentaco03
    Liam
    NJ
    I drove it some more (2 miles) and the idle seems to have set in around 750 but is pretty rough.
  10. Dec 28, 2015 at 4:48 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Keep driving it. Usually it takes the computer a good 10-25 miles or longer just for it to adjust, report back in the next few days (depending if you drive it)
  11. Dec 28, 2015 at 4:55 PM
    goldentaco03
    Liam
    NJ
    Is it actually possible for an air filter to cause that much of a difference in the intake?
  12. Dec 28, 2015 at 4:57 PM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Yes because it's sucking a lot more air than the stock intake.
  13. Dec 28, 2015 at 8:50 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    when i swap out filters on mine to clean them, i disconnect the battery for at least 10 minutes then reconnect before firing her up... when i don't, i sometimes get wonky RPMs too... i know when you first install the K&N intake, instructions tell you to disconnect the battery prior to install...
  14. Dec 29, 2015 at 6:54 AM
    goldentaco03
    Liam
    NJ
    ECU reset seems to have done the trick. It settled in at a nice low idle on startup about 1200 then when it warmed up it dropped to about 750 and it was very very smooth. Proof that AFE filters do a good job.
  15. Dec 29, 2015 at 7:12 AM
    goldentaco03
    Liam
    NJ
    Proof of increased air flow am I right?
  16. Dec 29, 2015 at 7:16 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Just curious, did you just drop an AFE filter in the stock airbox? Or a whole new intake?
  17. Dec 29, 2015 at 7:18 AM
    goldentaco03
    Liam
    NJ
    Cleaned out the airbox and dropped in a filter.
  18. Dec 29, 2015 at 7:20 AM
    goldentaco03
    Liam
    NJ
    :boom:
