Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Mar 18, 2016 at 8:16 AM
    #281
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Looks good, nice crossmember. Its a tie between building that and my steering shaft on things I'm dreading the most to complete my SAS.
    You will love the crawl box, hands down the best money i have ever spent on any wheeling mod on any vehicle i have owned. I was lol'ing at the part about crawling over the rocks at 10mph, that's about your max speed fully spooled out in 5th gear in double low!
    malburg114[OP] likes this.
  2. Mar 18, 2016 at 10:37 AM
    #282
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Thanks man! Yeah took us 2 and half long days to get it done... Steering shaft shouldn't be to bad for me. I got all the parts from the 4runner I took the box from and ordered a u joint coupler from Speedway to attach to the steering wheel so will cut the parts I don't need and weld it all together.
    It'll be more like 3mpH but I'm still stocked on it hahaha can't wait to use it!
  3. Mar 18, 2016 at 10:54 AM
    #283
    slander
    Hickory, NC
    Do you have the part number for that coupler to the steering wheel? I'm going to a ford box, but i have a 4runner shaft as well and i cant find a coupler for the shaft to steering column connection, i already have the one for the shaft to box.
  4. Mar 18, 2016 at 11:13 AM
    #284
    malburg114
    Las Vegas, NV
    Yeah. The part number is: 91032236-PLN
    Here's the linkhttp://www.speedwaymotors.com/Sweet-Mfg-Steering-U-Joint-3-4-36-Spline-to-3-4-Round-GM-Manual-Mustang-II,31386.html
    That is supposed to be the same coupler trail gear sells. Just a little cheaper and maybe different brand. That goes from the steering wheel to the steering shaft. One side has the 36 splines for the steering wheel and the other side is smooth 3/4 opening. I'm going to weld the smooth end to a piece of 3/4 in tubing that will slide over my 4runner shaft with the crush point and weld those two together. The crush point will then be connected to the box with the coupler that came on it.
    Not sure if that all makes sense haha
  5. Mar 18, 2016 at 11:14 AM
    #285
    malburg114
    Las Vegas, NV
    I got the coupler. It's just sitting in the mail box. Will let you know if it works tonight once I get the mail.
    I also ordered their 10 in long u bolts. They showed up already and they are beefy and will definitely do the trick
  6. Mar 19, 2016 at 8:02 AM
    #286
    malburg114
    Las Vegas, NV
    I got the coupler last night. It does not work on the steering will shaft. Returning that one and going to order a different one today from a different company. The shaft is actually 17.5mm. Not 3/4. And It has 34 splines total. 2 of them are the flat smooth splines so if yiu cut them, it'd be 36 total
  7. Mar 19, 2016 at 4:17 PM
    #287
    malburg114
    Las Vegas, NV
  8. Mar 19, 2016 at 4:28 PM
    #288
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    BHill_teq likes this.
  9. Mar 19, 2016 at 4:37 PM
    #289
    malburg114
    Las Vegas, NV
  10. Mar 19, 2016 at 5:05 PM
    #290
    FirstGen Jer
    Jeromey
    35x12.5?
  11. Mar 19, 2016 at 5:08 PM
    #291
    slander
    Hickory, NC
    Hmmm. Supposidly the stock ifs shaft will work if you ditch that cv part but i cut mine in half being an idiot.
  12. Mar 19, 2016 at 5:41 PM
    #292
    malburg114
    Las Vegas, NV
    Not sure I follow you? The only part I have left of the stock steering is the shaft coming out of the steering wheel. I took off all the couplers and such.
  13. Mar 19, 2016 at 5:42 PM
    #293
    malburg114
    Las Vegas, NV
    Yes sir! 4 used ones and 1 new one. Had to get new wheels though. Old ones weren't wide enough. Used ones only had 500 miles on them though
  14. Mar 19, 2016 at 6:30 PM
    #294
    FirstGen Jer
    Jeromey
    Nice...500 miles that's pretty much new
  15. Mar 19, 2016 at 6:33 PM
    #295
    malburg114
    Las Vegas, NV
    Exactly. Spent more than I wanted but it's done lol. It's just money?
    FirstGen Jer[QUOTED] likes this.
  16. Mar 19, 2016 at 7:14 PM
    #296
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    What are the wheel specs if you don't mind me asking? I'm in the hunt for new wheels and can't decide on 16s or 17s yet. I'm too damn indecisive on the little things :bananadead:
  17. Mar 19, 2016 at 7:23 PM
    #297
    malburg114
    Las Vegas, NV
    It was a super impulse buy because I met a guy from craigslist at discount to get his 315s. (They where on his FJ, so he was selling me his 35s and buying 33s) When they dismounted mine and went to mount the 315s, they said the wheel is too narrow. (7" wide, needs to be 8-8.5")
    Sooo after them showing me some, these are 8.5 inches wide, with a -6 offset. Essentially, these are the same as my old wheels with the new width being added to the outside. I got a good deal on them and the 5th new tire so was hard to say no. These cleared the calipers and highsteer arms and fit the hub on them. 16s are hard, discount only had this wheel and 2 other ones wide enought to fit a 315 tire.
    I like these though, theyre a 16" rim so I get a little more side way and I think they look good. The fake beadlock is just plastic? bolts filling a hole though, cant add a piece sadly.
  18. Mar 19, 2016 at 7:25 PM
    #298
    malburg114
    Las Vegas, NV
    And if I had time to research wheels more, Id be in the same boat as you. Very indesive and always have buyers remorse on things like this. But this time I dont, Im very happy with them. Tires and wheels. I like the 16s though for more sidewall. Id search craigslist though and see if you can find a set of used tires then base your wheels off of that! Let someone else decide for you!
  19. Mar 19, 2016 at 7:28 PM
    #299
    alee891
    Austin
    Black Hills
    Tacomaless
    Yeah, the stockers won't hold up to 315s. I'm leaning towards 16x8s right now because of the extra sidewall when aired down. At first I wanted 17x9s, but am getting away from that more and more each day. What is the backspace on em?
  20. Mar 19, 2016 at 7:29 PM
    #300
    malburg114
    Las Vegas, NV
    Id have to look at the paper again. The offset is -6 though.
