Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Apr 1, 2016 at 5:05 PM
    #321
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Some pictures. Went back to the junkyard today to get some springs to help with the ride height and spring arch in the front. Ideally, I wanted to get wagoneer springs but I have yet to see one there.... Went in looking for thin leafs in general and while walking around... Found Grand Wagoneers. Untouched. Looked like they had just set them there. So with that said, my dad and I pulled the whole axle. Hes using one on his jeep and took it for a future project. I got the springs though and will set ride height tomorrow and get everything welded up for the front!
    leafs
    [​IMG]2016-04-01_04-29-10 by Harrison M, on Flickr
    Frame plates for the frenched hangers
    [​IMG]2016-04-01_04-29-27 by Harrison M, on Flickr
    And the front spring hanger all welded up
    [​IMG]2016-04-01_04-29-19 by Harrison M, on Flickr
    Milota95 likes this.
  2. Apr 1, 2016 at 6:53 PM
    #322
    malburg114
    Las Vegas, NV
    Need some opinions here. Need to order shocks soon and am undecided on what to get. Looking at just getting fox 2.0 smooth bodies, blistein 2.0s with remote resis, or possible icons 2.0 smooth bodies. Really wanted am adjustable shocks to account for varying weights but cant swing that much right now.
    What's everyone think
  3. Apr 1, 2016 at 10:54 PM
    #323
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Given those I'd go foxes. But all sound good.
  4. Apr 2, 2016 at 5:38 AM
    #324
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I like icons.
  5. Apr 2, 2016 at 9:31 AM
    #325
    malburg114
    Las Vegas, NV
    Thanks guys. Going to call and get some prices. Those are the two I'm swaying towards
    FirstGen Jer likes this.
  6. Apr 2, 2016 at 12:56 PM
    #326
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I'd get the foxes, a friend of mine has them and really likes them on his SA'ed 4Runner. I've got 5125's all around on my truck and they work fine, the weight in the front seems to make whatever work well up there
  7. Apr 2, 2016 at 6:08 PM
    #327
    malburg114
    Las Vegas, NV
    Thanks. Wasnt sure how the 5125s would do with all the weight up front and extra weight in the back from a swingout, rtt, rack, and camping gear and such. Thats the real reason I want the adjustable ones but they will have to wait and I will just a little bit of a rake for now.
  8. Apr 3, 2016 at 7:37 PM
    #328
    malburg114
    Las Vegas, NV
    Front is almost done! Got the truck sitting on its own weight for a little. Getting the power steering lines fittings tomorrow and ordering longer wheel studs to finish it off. Plan for tomorrow is to start painting everything and get the skids template made along with shock towers. Front should be done soon.
    [​IMG]2016-04-03_05-26-10 by Harrison M, on Flickr
    Dont mind the steering..
    [​IMG]2016-04-03_05-25-56 by Harrison M, on Flickr
    [​IMG]2016-04-03_05-25-42 by Harrison M, on Flickr
  9. Apr 8, 2016 at 10:55 AM
    #329
    malburg114
    Las Vegas, NV
    Well shes a roller! First time its been out of the garage since we started. Frame height for now is 23" with just under 3" of uptravel on 35s. Not to bad. Had to move the axle back 1" to clear the pitman arm though. Front is done except for drive shaft, finish welding the steering and making shock towers and installing shocks. And the usual fill the axle and other little things. Should have it turned around beginning of next week hopefully.
    [​IMG]2016-04-08_10-04-56 by Harrison M, on Flickr
    [​IMG]2016-04-08_10-05-02 by Harrison M, on Flickr
    [​IMG]2016-04-08_10-51-44 by Harrison M, on Flick
    :bananadance:r
  10. Apr 8, 2016 at 11:09 AM
    #330
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  11. Apr 10, 2016 at 4:47 PM
    #331
    malburg114
    Las Vegas, NV
    Got the bed pulled off and hosed down as well as cut and bent the skid. Going to weld the skid plate in the morning when I get off from work then should be able to turn the truck around and get it pushed back in the garage to start the rear.
    [​IMG]2016-04-10_04-26-49 by Harrison M, on Flickr
    1 Solid piece of 1/4 in cut and bent.
    [​IMG]2016-04-10_04-26-39 by Harrison M, on Flickr
  12. Apr 10, 2016 at 5:09 PM
    #332
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    How did you bend it?
  13. Apr 10, 2016 at 5:46 PM
    #333
    malburg114
    Las Vegas, NV
    I cut the middle sections and we bent it by "hand" since the pieces where to long to fit in the press. I'll clamp it to the truck tomorrow and then weld in the parts I cut on the bottom and inside.
    BYJOSHCOOK[QUOTED] likes this.
  14. Apr 11, 2016 at 5:07 PM
    #334
    malburg114
    Las Vegas, NV
  15. Apr 15, 2016 at 6:54 PM
    #335
    malburg114
    Las Vegas, NV
  16. Apr 15, 2016 at 7:06 PM
    #336
    FirstGen Jer
    Jeromey
    There is a group buy going on right now I believe for carrier bearings
  17. Apr 15, 2016 at 7:10 PM
    #337
    malburg114
    Las Vegas, NV
    Ill look but do you have a link possibly??
  18. Apr 15, 2016 at 7:12 PM
    #338
    FirstGen Jer
    Jeromey
    Let me look
  19. Apr 15, 2016 at 7:15 PM
    #339
    FirstGen Jer
    Jeromey
  20. Apr 15, 2016 at 7:15 PM
    #340
    FirstGen Jer
    Jeromey
    They are available for 1st gens as well^^^
