Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Apr 15, 2016 at 7:21 PM
    #341
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Looks like the company decided to cancel the group buy after the first one :confused::confused: and people arent hearing back from the company who ordered theres.. Such a bummer.
  2. Apr 15, 2016 at 7:35 PM
    #342
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Ahh sorry man, I saw that thread when it first started....are people being ripped off?
  3. Apr 15, 2016 at 7:39 PM
    #343
    malburg114
    Las Vegas, NV
    Not sure. Ill have to call the company and see if they are still doing the offer. Sounds like you have/had to wait till they had 20 orders then they make them.
  4. Apr 15, 2016 at 7:40 PM
    #344
    FirstGen Jer
    Jeromey
    Good luck
  5. Apr 16, 2016 at 5:27 PM
    #345
    malburg114
    Las Vegas, NV
    FirstGen Jer and SnowroxKT like this.
  6. Apr 16, 2016 at 7:23 PM
    #346
    malburg114
    Las Vegas, NV
    Got the chevys all mounted today. I think mine ended up almost 9.5in foward of stock hanger. I put the hanger at 90* to the frame and thats where I notched the frame. Put the leaf spring pin in the same place as stock when at ride height. At full drop, they were close 3/4 in foward. Everything I read about how to do this got thrown out when the first measurment I took was off. :frusty: Putting the bed back on tomorrow with tires to double check everything.
  7. Apr 16, 2016 at 7:28 PM
    #347
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Good post...
    I was not aware they moved that much in the forward direction. I was thinking mine moved due to breaking the spring pack.
    Keep us informed.
    Thanks for the up-date.
  8. Apr 17, 2016 at 5:34 AM
    #348
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    Yeah i think the instructions say 7" forward but mine will like be close to the 9" range. I though about cutting the front hangers off and just pulling it forward until the axle lined up in the middle. Or should the leaf pin actually be the middle? Not sure if that lines up like that or not..
  9. Apr 17, 2016 at 8:34 AM
    #349
    malburg114
    Las Vegas, NV
    No way these will line up 7" unless you move the rear hanger back. Using the stock Shackles on the rear, I put them 90* to the frame. At the time, the leaf pin was not in the middle but when I put the axle back under it and put it at ride height, the pins where in the stock location. I didn't end up using the factory hanger and it actually just got in the way so I trimmed it down till I could get in there to take it the rest of the way off.
    And a note, all the factory mounts on the driver side where an 1/8 farther foward than the passenger side. I don't think it will affect anything as it is still all square now.
    Going to cycle everything with the bed and tires today and will let you know tonight how it all works out. Hope all that makes sense
  10. Apr 17, 2016 at 5:58 PM
    #350
    malburg114
    Las Vegas, NV
    Got bumpstops set and started cycling the suspension today and tried to get the ride height set. Had to pull a leaf in the front and will be pulling another tomorrow. Frame height is still only 23 1/4" with 35s. Getting closer to being done!!
    [​IMG]2016-04-17_05-29-43 by Harrison M, on Flickr
  11. Apr 17, 2016 at 6:52 PM
    #351
    Ritchie
    That is awesome... looks good.
  12. Apr 18, 2016 at 6:47 PM
    #352
    malburg114
    Las Vegas, NV
    Ride height is set. Just shy of 23 in to the bottom of the frame in the front and 23 in the rear. Should sit level with all the armor and RTT.
    [​IMG]2016-04-18_05-10-40 by Harrison M, on Flickr
  13. Apr 18, 2016 at 8:50 PM
    #353
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Damn this thing is looking good!
  14. Apr 18, 2016 at 11:26 PM
    #354
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Nice low ride height!
    malburg114[OP] likes this.
  15. Apr 19, 2016 at 5:19 AM
    #355
    malburg114
    Las Vegas, NV
    Thanks guys. Moving right along
  16. Apr 19, 2016 at 7:58 AM
    #356
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Man you didnt waste any time, looks good!
  17. Apr 19, 2016 at 8:06 AM
    #357
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    :woot: I like how it isn't ridiculously tall
  18. Apr 19, 2016 at 9:54 AM
    #358
    malburg114
    Las Vegas, NV
    Thanks guys. Definitely wasn't easy to keep it low and have decent up travel. Still have a lot of work to do though haha
  19. Apr 25, 2016 at 6:21 PM
    #359
    malburg114
    Las Vegas, NV
    Getting close to being done. Got the rear shock tabs tacked on and all the gussets and everything else I need to finish up the rear. Bed is off and will start welding tomorrow. Just have to pull the rear third member and drop it off to have it regeared.
    Also picked up a front driveshaft from a 4runner today and measured to have it lengthened and the rear one shortened and both rebuilt.
    One set back though as the steering box I got is leaking at the input shaft. Pretty bummed since I paid a 100 bucks for it and spent most of a day pulling it from the junkyard. Most likely going to get a re manufactured one from rock auto.
    [​IMG]2016-04-21_04-33-29 by Harrison M, on Flickr
    [​IMG]2016-04-21_04-33-46 by Harrison M, on Flickr
    Full stuff. Only have to do some minor trimming of the fenders at the bottom to clear the 35s completly.
    [​IMG]2016-04-21_04-33-01 by Harrison M, on Flickr
    FirstGen Jer likes this.
  20. Apr 25, 2016 at 6:32 PM
    #360
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I'm in the minority but I think 23 is pushing the limit of too low at Xtra cab Tacoma wheelbase. Extra height helps you not drag the belly on everything.
    Really like the build though
