Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Apr 25, 2016 at 6:49 PM
    #361
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Thanks man! Been watching yours as well.
    Its actually even a little lower now around 22 3/4. Turned out a lot lower than I thought it would but with it still being my DD and a more overland than rock crawling truck, im not overly concerned. I know ill drag but nothing a quarter inch skid wont protect the vitals from. It was hard setting this truck up but its still taller than what my truck was before. If its to low, gives me another reason to go to 37s or 3/4 link :D
    Just kidding, Im gonna wheel the crap out of this until I even think about that hahah:burnrubber:
    Milota95 and FirstGen Jer like this.
  2. Apr 25, 2016 at 7:02 PM
    #362
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Love the build man!....+1 for the sweet tie die duck tape mod :D :fistbump:
  3. Apr 25, 2016 at 7:08 PM
    #363
    malburg114
    Las Vegas, NV
    Haha gotta protect em any way you can! :bananadance::luvya:
    FirstGen Jer likes this.
  4. Apr 27, 2016 at 4:09 PM
    #364
    malburg114
    Las Vegas, NV
    Dropped off driveshafts today. Not sure if the CV i got for the front will work so waiting to hear what the driveline shop says. Got most of the welding on the drivers side down and got the truss for the axle cut today.
    Rear shock mounts
    [​IMG]2016-04-26_05-44-03 by Harrison M, on Flickr
    Rear shackles
    [​IMG]2016-04-26_05-43-50 by Harrison M, on Flickr
    SnowroxKT and FirstGen Jer like this.
  5. Apr 28, 2016 at 5:09 PM
    #365
    malburg114
    Las Vegas, NV
    SnowroxKT likes this.
  6. Apr 28, 2016 at 7:38 PM
    #366
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Looking good. Can't wait to play catch up.
    Edit autocorrect.
  7. Apr 29, 2016 at 10:30 AM
    #367
    malburg114
    Las Vegas, NV
    Thanks! Everything's getting pretty close now and just trying not to slack on the details now.
    Looking foward to seeing how you do yours. What's your plans for it so far?
  8. Apr 29, 2016 at 10:32 AM
    #368
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Last final exam in 30 minutes. Then I drive home and start with the front end. Once it rolls I will get the rear regeared then I'll tackle the 63's.
  9. Apr 29, 2016 at 10:35 AM
    #369
    malburg114
    Las Vegas, NV
    Nice! Have fun with the 63s. All the research I did on mine didn't end up panning out for me. Still got them in and should work fine. They are just SUPER soft and flexy. I added a cut down Wagoneer leaf and an add a leaf that was on the toyota pack I got and it gave me the right height and feels a lot better now.
  10. Apr 29, 2016 at 10:39 AM
    #370
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Yeah I thought the 63's might need a couple leaves from my current leaf pack made for the older Toyota Pickups. I'm pretty sure I'll have to cut part of my slider reinforcements off my frame too...
    What size tires are you going to run?
  11. Apr 29, 2016 at 10:47 AM
    #371
    malburg114
    Las Vegas, NV
    Your 63s could be different though cause I frenched my rear hanger in. I think if I would have mounted the front hanger on the bottom of the frame, I wouldn't have had to add extra leafs.
    35 inch Bfg k/o2s. With these, I won't have to trim the front and will only have trim the bottom of the flare for the rear. But I did move the front axle 1 inch back for steering reasons and the rear axle I think 1 inch back and that centered it in the wheel well.
  12. Apr 29, 2016 at 4:14 PM
    #372
    malburg114
    Las Vegas, NV
    Everythings painted for the rear except the axle. Called it a day early after rolling around in overspray and smelling the fumes in the garage.
    [​IMG]2016-04-29_03-17-07 by Harrison M, on Flickr
    SnowroxKT, FirstGen Jer and alee891 like this.
  13. Apr 30, 2016 at 7:32 AM
    #373
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Good plan to wheel the crap out of it and have fun!
    I would go for more up travel on mine but the drag link makes a lot of love with the oil pan as it is...And I'm too lazy to notch the pan or raise the motor. Simple is good sometimes
  14. Apr 30, 2016 at 9:37 AM
    #374
    malburg114
    Las Vegas, NV
    Yeah will see how everything does when it drives. As long as I don't bottom out on everything, I will be happy. Should work just fine though. Leafs aren't as simple as one would think hahaha
  15. Apr 30, 2016 at 6:59 PM
    #375
    malburg114
    Las Vegas, NV
  16. May 2, 2016 at 5:06 PM
    #376
    malburg114
    Las Vegas, NV
    Just doing all the little things now while I wait on the rear 3rd and drive shafts. Once I get those, going to turn the truck around and do the front shock towers and remeasure for bumps since I took some leafs out of the front.
    Got the exhaust mostly done today. Have to finish welding it and mount some hangers on it.
    [​IMG]2016-05-02_03-31-56 by Harrison M, on Flickr
    [​IMG]2016-05-02_03-32-06 by Harrison M, on Flickr
    Axles done except for brake lines. Waiting to put the axle shafts back in to bend the new lines though
    [​IMG]2016-05-01_01-18-56 by Harrison M, on Flickr
    [​IMG]2016-05-01_01-19-16 by Harrison M, on Flickr
  17. May 6, 2016 at 8:36 PM
    #377
    malburg114
    Las Vegas, NV
    :bananadance::burnrubber::spy:
    Shes alive!! Drove it about a 100 feet. Rear driveshaft didnt line up tothe Tcase so going to swap to a pre tacoma flange on monday and that should finish up the rear except for paint, finish bleeding the brakes, and the gas tank skid.
    [​IMG]2016-05-06_07-54-11 by Harrison M, on Flickr\
    [​IMG]2016-05-06_07-53-58 by Harrison M, on Flickr
    [​IMG]2016-05-06_07-55-26 by Harrison M, on Flickr
    But holy rake... Will be adding the leafs I took out of the front once I cycle it again to mount shocks and move the bump stops. Then just weld the shock towers, secure brake lines and bleed and touch everything up for the most part. Then move onto breaking in the gears and doing the front bumper.
  18. May 6, 2016 at 8:38 PM
    #378
    malburg114
    Las Vegas, NV
  19. May 6, 2016 at 11:34 PM
    #379
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Sub'd! Good work on the SAS! :thumbsup:
    malburg114[OP] likes this.
  20. May 8, 2016 at 3:24 PM
    #380
    malburg114
    Las Vegas, NV
    Shock towers are cut. Bump stops are mounted and winch plate is cut for the front bumper.
    Shock towers before and after and lower shock mounts for the axle.
    [​IMG]2016-05-08_12-20-23 by Harrison M, on Flickr
