Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. May 14, 2016 at 6:58 PM
    #401
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    If you don't mind me asking, how much roughly was this setup? Just curious I won't be doing it to my truck but I will my 92 4Runner
    Looks awesome by the way! Good work
  2. May 14, 2016 at 7:07 PM
    #402
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    So sick man! Looking forward to seeing it in action!
  3. May 14, 2016 at 7:09 PM
    #403
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Not quite sure im ready to post how much ive spent on this quite yet but its a lot. Im pretty far over budget but I also got a lot more than I was planning on.
    I will post a parts list and may include the prices then. And mind you, I didnt use a kit and built/made a lot of the pieces. The little things added up quick.
    Thanks! Nothing compared to some of the builds on here or pirate though but it will fit my needs and make me happy.
  4. May 14, 2016 at 7:09 PM
    #404
    malburg114
    Las Vegas, NV
    Thanks man. Shouldnt be to much longer.
  5. May 14, 2016 at 10:06 PM
    #405
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Awesome!
  6. May 14, 2016 at 10:10 PM
    #406
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I see 37s in your future sir :cool:
  7. May 14, 2016 at 11:24 PM
    #407
    malburg114
    Las Vegas, NV
    Far far future... they would look great. Maybe if I find a good deal on some used ones :spy:
    cbechtold[QUOTED] likes this.
  8. May 15, 2016 at 6:55 AM
    #408
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I'd stay on 35's as a DD. 37's are too expensive to DD unless money isn't an object lol
    FirstGen Jer likes this.
  9. May 15, 2016 at 9:27 AM
    #409
    malburg114
    Las Vegas, NV
    Money's definitely an object and I'll probably stay 35s till I get a dd. I just think they will look better and fill the wheel wells. Would have to trim the cab on the front though as it rubs on 3/4 turn plus stuff right now a little
  10. May 20, 2016 at 7:05 PM
    #410
    malburg114
    Las Vegas, NV
    Well found one major problem on Wednesday and got it fixed today. Since the truck was a prerunner to start, we got the inchworm prerunner adapter with trail gear crawl box and transfer case. When we put the adapter in, my dad made a note about there being no seal between the adapter and transfer cases. Didn't think anything of it and fast foward to now. After driving it and checking all the fluids after every drive, I kept noticing the tranny fluid always being low to not registering on the dipstick. I knew some had leaked out when swapping radiators but definitely wasn't 3 and half quarts worth (added all over about a week) so I pulled the transfer case fill plug and sure enough, tranny fluid came spraying out.
    When we got the adapter, it seems we where missing a box with a Spacer and the seal. Well after several phone calls with low range (who we ordered everything through) we Finally got the inchworm tech and told him what we where mising. They overnighter the seals and spacer and today we tore the transfer case and adapter back out and got the seal in. Didn't fill it yet, waiting for the ultra Grey to cure so we will check again tomorrow. Sucked having to pull all that again but glad it's done and hopefully that's the last of the major problems.
    And a big thanks to low range for all their help and being patient with us. We ordered a lot of our parts through them and highly recommend them to others.
    Will be working on the bumper tomorrow so things are getting close to being done again.
    SnowroxKT likes this.
  11. May 21, 2016 at 6:54 PM
    #411
    malburg114
    Las Vegas, NV
    Well filled the tcases and tranny with oil today and crusied around the block. No leaks and it shows it has oil so we will see what it looks like tomorrow. Pretty sure it was just the missing seal that was causing it to leak.
    Got a lot done on the bumper today. Drilled all the holes and got the winch plate tacked together and bolted to the truck and got the bumper cut and slid over the winch plate. Going to weld it all together tomorrow and it should be good to go!
    [​IMG]2016-05-21_06-31-08 by Harrison M, on Flickr
  12. May 24, 2016 at 11:21 AM
    #412
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
  13. May 24, 2016 at 1:01 PM
    #413
    malburg114
    Las Vegas, NV
    Bumpers all welded and ready for paint. Going to make a template and weld some tabs for the filler piece around the winch. Exhaust end is fixed and no more rattle from that. Painted behind the bumper black and it all blends in now. Last few things to do besides the bumper is get a new license plate light, put the skid plate on and mount the center console filler piece for around the shifters.
    [​IMG]2016-05-22_06-14-21 by Harrison M, on Flickr
    Bumper is the same as it was before. Just cut out the middle for the winch and shortened it up a lot since it was attatched to the ifs cross member.
  14. Jun 1, 2016 at 4:55 PM
    #414
    malburg114
    Las Vegas, NV
    Bumpers being painted today. Got the winch all set up and ready to be bolted in. Skid plate is on and painted. All that's left is to get a license plate light and wire up the new fuse box. Been driving it around town and am really enjoying it. Driving great with the exception of a vibration when sitting at a stop light in drive. But goes away in neutral or park.
    Should have the bumper on tomorrow hopefully and maybe go do a shake down run on Saturday.
    LogCabins and FirstGen Jer like this.
  15. Jun 1, 2016 at 6:03 PM
    #415
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    must be a drive shaft vibe :notsure:
  16. Jun 1, 2016 at 7:20 PM
    #416
    malburg114
    Las Vegas, NV
    Shouldn't be drive shaft because it only happens when It is at a complete stop in drive with my foot on the break. Goes away when I step on the gas or shift to park. I did loosen all the rubber mounting points on the tcase so they wherent bulging as much and thag helped. Just still there.
    I'm starting to think it's either the motor mounts or the body mounts. It had a small one before and I think with the tcase it just worsened. Body mounts may be the next thing to do.
  17. Jun 2, 2016 at 7:06 AM
    #417
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Did you upgrade the trans/tcase mount? Are the tcase or trans mount bolts tight?
  18. Jun 2, 2016 at 9:32 AM
    #418
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It sounds like you have a front range off-road horseshoe style tcase mount. Those will make the truck vibe a fair amount at low idle in gear. When I had that style mount the truck vibed pretty hard at idle and when I went to the stock trans mount, the vibes went away. Then I threw in a bombproof TG tcase mount and the vibes came right back
  19. Jun 2, 2016 at 10:10 AM
    #419
    malburg114
    Las Vegas, NV
    Truck was a prerunner to start with so we made our own tcase mount to replace the transmission mount. It has two bombproof TG mounts and then the four legs attached to the frame are rubber mounted as well.
    Both the TG mounts and frame bushings are tightened to before the bushing starts to mushroom or crush.
    No horseshoe style mount. Just a cradle with the TG bombproof mounts.
    Vibes are definitely less since I loosened everything about a turn though. Don't want to go any farther than where it is now though or they will be to loone.
  20. Jun 2, 2016 at 10:28 AM
    #420
    slander
    Hickory, NC
    Its the new mount, you will get used to it. I had the same thing when i switched over to the 4xinnovations style mount with stiff bushings, i actually thought i broke something when i first started it. I got used to it in a few days.
