Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Oct 29, 2020 at 8:25 PM
    #1301
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yea yours may be easier! I had a motor mount in the way and I waaaaaaay overbuilt mine since evreyone I know is constantly welding on their mounts it seems.
    What box is that? Is that off a jeep?
  2. Oct 29, 2020 at 8:28 PM
    #1302
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Hydro assist makes the steering box mounting wayyy less important strength wise
    malburg114[OP] likes this.
  3. Oct 29, 2020 at 9:11 PM
    #1303
    slander
    Hickory, NC
    Half the people I see welding on frame rails have hydro assist. I'm 0% worried about mine, it's the strongest part of the entire truck Lol
  4. Oct 29, 2020 at 10:34 PM
    #1304
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Yeah psc big bore box meant for like a tj. New frame is 3/16. I’ll cut some steering box mounts out of 3/16 and then sleeve the bolts with dom. Weld it all together rand drop it over the frame. I would hope it holds lol
    slander[QUOTED] likes this.
  5. Oct 30, 2020 at 3:33 AM
    #1305
    slander
    Hickory, NC
    That's basically how I did mine as well.
    Interested to see how the steering box on the inside of the frame rail works out!
  6. Oct 30, 2020 at 9:34 PM
    #1306
    malburg114
    Las Vegas, NV
    Yeah same. I’ll mess with it this coming week hopefully. If I have to I’ll notch them frame to sink the steering box in with a body mount over the top. We will see though
  7. Nov 2, 2020 at 6:04 PM
    #1307
    malburg114
    Las Vegas, NV
    Got a little done today and last night. The inner c’s gave my press and i a run for our money. In the end, can’t be tight if your liquid lol.
    axle is set at ride height. That’s a wheelbase of 126-130 (shooting for 128 or less) and that’ll put the center section at hitting the motor at 7.5 inches. Panhard should fit between the motor and radiator.
    got the brackets for the steering box cut. Psc must have two different big bore boxes as mine is a little different from the one my dad is running. Need a radiator that is significantly smaller though to clear the steering shaft.
    BA9A3CDF-DAF3-459D-9A15-F0EFF0CE1B9D.jpg 73D6C27D-28D1-44BC-A7E4-DA785BA31113.jpg F968B1FB-5BA2-484D-89F9-303057DEF5C3.jpg 5987F4EF-F244-4E6B-A3C9-39221B88F530.jpg AF4057CF-7F5C-4473-B0A5-190969913EB8.jpg 3810209F-97A2-4F6D-BA45-BA4BD350886D.jpg 004E8EC8-3CC7-4575-A696-4DD40BA9629E.jpg 660EC931-9AD3-46A6-82BC-B5E37BEB381E.jpg 4A3D88E4-32C8-4004-BD83-22D3D6DBF7C8.jpg
    Duckfatt, Kkrause09, ToyRyd04 and 6 others like this.
  8. Nov 3, 2020 at 8:35 AM
    #1308
    Kkrause09
    Kkrause09 Well-Known Member
    Kyle
    Tacoma sas
    look into 3gen pickup radiator, they are narrower by 6” and don’t hang below frame
  9. Nov 3, 2020 at 8:43 AM
    #1309
    02hilux
    Planet: EARTH
    3RZ radiator is flush with the frame
  10. Nov 3, 2020 at 9:04 AM
    #1310
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I like that axle jacking dolly thing you have
    malburg114[OP] and slander like this.
  11. Nov 3, 2020 at 1:27 PM
    #1311
    malburg114
    Las Vegas, NV
    I’ll look into the 3rd gen one as I already have the smallest 3rz one in there now. Issue is I raised the frame so everything needs to be significantly smaller.
    I found two from griffin radiators and one from summit racing. One griffin and the summit are both 22 inches wide by 19 inches tall. That’ll fit between the frame rails and box but will be close with the hood. I may be able to angle it a little but not much since the fan is there. The other one I was looking at from griffin is 22 in wide by 15.5 tall. This would be ideal but seems pretty small and worried about cooling issues. The griffin ones are 3 inches thick and have two cores which is way bigger than my current one. Summit is only 2.25 inches thick.
    Links
    15.5 griffin
    https://www.summitracing.com/parts/gri-1-26181-ts
    19 griffin
    https://www.summitracing.com/parts/gri-1-26182-ts
    19 summit
    https://www.summitracing.com/parts/sum-381424
    Kkrause09[QUOTED] likes this.
  12. Nov 3, 2020 at 1:28 PM
    #1312
    malburg114
    Las Vegas, NV
    Thanks. My dad came up with the idea and used it to move his 14b and 60 around. Picked up the jacks at the junkyard and make it easy to cycle suspension etc.
    slander and jubei like this.
  13. Nov 3, 2020 at 1:28 PM
    #1313
    02hilux
    Planet: EARTH
    Ooops, forgot you raised the frame.
  14. Nov 4, 2020 at 5:14 AM
    #1314
    slander
    Hickory, NC
    If it's a trailer queen, toss the radiator in the bed.
  15. Nov 4, 2020 at 10:17 AM
    #1315
    malburg114
    Las Vegas, NV
    It is and it isn’t. It gets trailered to like the hotel or camping spot but like sand hollow we still drive 20 minutes to the entrance of the park, we typically drive from Tahoe to loon lake (70 miles or something) for the rubicon and I drive it to the trail heads in Moab. Plus with the bobbed bed it’s already pretty small with no good place for it. Thought about it and quickly ruled it out.
  16. Nov 5, 2020 at 5:20 PM
    #1316
    malburg114
    Las Vegas, NV
    This kingpin stuff has been rough. Only spent a few hours in the garage but was trying to get the the old kingpins out so I could try to turn the id of the c down to fit the axle tube.
    Kingpins-6
    Me-2
    I broke 2 breaker bars, bent an 8ft cheater bar, bent a bunch of metal by beating on them after welding it to the kingpin, broke an extension I welded to use my big impact on.
    in the end cut the kingpin as low as I could and welded a 1/2 nut on super hot with tons of penetrating fluid and hit it with the impact for a minute or so lol.
    got one back side of the c turned down before I broke the lathe cross saddle. I don’t have strong enough tool holders to do the id so I’ll have them taken somewhere to be done.
    bumpstops showed up and found a set of new in box hubs which should be here later this week.
    9FF6BC7E-B6DE-4C58-9FA3-1376D0B83573.jpg 0E025D35-0E11-4980-95B6-7D113EF27C14.jpg C81F9E34-A6EB-47C5-8AFB-CFB4CC241572.jpg 0907C934-9F3C-452D-82AD-24FEE1C908F5.jpg A3804333-6A0F-4EAE-9B0F-87FAD4F5A7F8.jpg 05E59BFD-A026-41F3-BBD4-A667FCDEE23F.jpg 4F1AF1A7-0289-49A7-B1B8-AB479CD90696.jpg
    jubei, ToyRyd04, Lfaub03 and 2 others like this.
  17. Nov 5, 2020 at 6:15 PM
    #1317
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    You keep making a SD60 with ball joints look more appealing! Especially since I’ve done them twice on my old F250 and know what I’m in for at least
  18. Nov 5, 2020 at 6:49 PM
    #1318
    slander
    Hickory, NC
    King pins are overrated for our application!
    Keep posting, looking good!
    tacoma16 and malburg114[OP] like this.
  19. Nov 5, 2020 at 7:13 PM
    #1319
    malburg114
    Las Vegas, NV
    Knowing what I know now and I didn’t find such a good deal on my rear axle setup I would have done unit bearings all around but the rear spindle and hubs etc I got a good deal on and to make carrying parts easy I did the same for the front so that meant kingpin.
    I’ll probably never have to do this again and will be easier when there is something to hold the c down rather than just a vise with my body weight holding my welding table down lol
    slander likes this.
  20. Nov 8, 2020 at 8:19 PM
    #1320
    malburg114
    Las Vegas, NV
    Lower link frame mounts tacked together. Kind of at a stand still till i get the hubs and high steer arms. Should be here this week hopefully.
    AD01DC81-C512-4753-8BB7-02365013693D.jpg BCF98839-FF73-4E26-AE3D-1FB53871D297.jpg 99F012E3-0834-40A7-A23E-950002465320.jpg
    Yota X, cbechtold, Kkrause09 and 5 others like this.
