Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Nov 25, 2020 at 11:47 PM
    #1341
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    My dads in town so he helped me clean up we’re the engine cage will mount to the cab. Also got the plates formed and tacked for the inside frame gusset.
    ordered solid inners after shop in town jerked me around and can’t find anyone else to do. Should be here December 1st
    6F4AEF9B-A426-44AA-98A7-D4543806C5E3.jpg 339D150B-ED05-4DAB-AA47-5429043F383E.jpg A8CC9AFF-5051-47A8-8A99-CEC43D6559E1.jpg
  2. Dec 2, 2020 at 12:20 AM
    #1342
    malburg114
    Las Vegas, NV
    Cs finally showed up. Lots of math and mocking up today to figure out how much to cut the housing. Should have the housing cut and assembled tomorrow hopefully.
    and don’t worry. My car parts are rona free.
    D08D9E24-AAFB-463A-9244-582FE7C0140C.jpg AEA2AFA1-2F5F-4925-9599-338D990A9436.jpg 968F8338-7623-4528-8FD0-419D380108F9.jpg F173D1EF-D7BD-455C-8E8A-1DE3E1D4749F.jpg E414A9C7-909D-42ED-A806-B50A9715D15B.jpg
    I know the knuckle is backwards in the last two pictures. Just showing how I got my measurements. I’ll explain with more pictures tomorrow
    tacoma16, cbechtold, slander and 5 others like this.
  3. Dec 2, 2020 at 10:09 PM
    #1343
    malburg114
    Las Vegas, NV
    What a long stressful day... but the cs are on. Driver side took 3 tries. First wasn’t hot enough and I pounded on only to pound off cause it wouldn’t move. Cleaned the tube up a little, iced it and got the c super hot and it slid right on. Got the degrees perfect only for the housing to still be to long. I cut an 1 1/8 out of it and iced it and heated the c again. It slid on but cooled quick so was .5 degree off what I wanted. Cleaned up the c and assembled the hub.
    Everything fits but the shaft hits the locking up cap keeping it from turning so I’ll try to put the housing in the press to move the c an 1/8 or just grind the shaft a little.
    Other side I cut out 21 3/4 of the tube. The shaft slid in but only had 1/2 in of spline engagement so took another 3/4 of an inch out and it was just right. Did the same thing, iced and cleaned up the housing and left the c on the grill for a while. Tried it and it didn’t even slide on so I found some patience and threw them back in the grill. Half hour or so later it slid right on and was able to match the degree within a .25 degree.
    Pretty happy overall. Once I figured out the heat/ice it was very simple. Just stressful with the cuts. The short side is well.. short. Should make the lower mount ineresting. Overall happy with how it turned out. Mad cause I beat the crap out of the one c but happy it’s together and I can start cycling.
    Ended up with 15.5 degrees (was shooting for 16) so I’ll do 7 3/4 degrees of pinion angle which will give me 7 3/4 caster
    2532CAB1-02A2-4C6D-ABBF-A520F6430101.jpg78A82452-38A2-4466-BD55-84B170F69F6E.jpg08F14084-1B13-4A8C-89E9-9DEA91C84352.jpgE6453B93-EC6D-4E26-9CA8-B5987F411517.jpg8D91890F-F092-4131-9F24-CC068C55AB3A.jpg9AF68DF8-6E50-4055-9DBA-99FAAE9D9B76.jpg2A187127-BD86-4FED-BA89-4A614CC7A248.jpgFE27452A-5693-4E4D-9FC6-7536B8E6155C.jpgAF0DA94B-1408-4A28-806A-B0A9BF74815C.jpgAC95145A-16CA-4239-997C-ED9E41A3EB42.jpg7958B057-8157-4993-ACA1-A0AB7F0EF972.jpg9B30E36C-43FE-4541-BCA0-009BA2B63C11.jpg
    Yota X, tacoma16, cbechtold and 11 others like this.
  4. Dec 2, 2020 at 10:16 PM
    #1344
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Man that kinda stuff is so nerve racking
  5. Dec 2, 2020 at 10:27 PM
    #1345
    malburg114
    Las Vegas, NV
    I over complicated a lot of things and after I got moving and figured out how hot the cs had to be it got easier. Pretty funny watching me run around with mig gloves on and a piece of metal smoking on a metal plate lol.
  6. Dec 4, 2020 at 1:16 AM
    #1346
    malburg114
    Las Vegas, NV
    Links laid out. 45 in long lowers. 44.5 in upper. 6.5 degrees on the lowers at ride height. -1 on the upper but I could lower the frame side an inch. I’m not quite sold on the upper mount yet so chopped it up and lowered it and moved it foward some and shortened the upper by an 1.5 to gain some more uptravel. Plan on shortening the wheelbase an inch or two to get the upper behind the ac compressor for more uptravel. Moving along and feel like I made good progress today. Threw a fender on just to see where I was at wheelbase wise as well.
    C345023F-19D4-436E-9DBB-84EBBAC2BF81.jpg FA2BC511-E068-4EE6-9D2B-83C9F6B193A2.jpg 00EC32B0-BEA5-4C9B-8A5D-7809071FA4F9.jpg 1964758F-3FFB-4C2C-9F0F-E0BC3583F75A.jpg 186B9317-0D7B-44EF-A6B8-0C44D18FDE1A.jpg 2450A774-0F51-48AE-97DD-0964C4F29C32.jpg
    Yota X, Lfaub03, Kkrause09 and 10 others like this.
  7. Dec 5, 2020 at 8:32 PM
    #1347
    malburg114
    Las Vegas, NV
    Redrilled the upper and moved it foward some. Plan on making a new upper mount similar to bamf to clear the ac compressor.
    My dad got me a brake from grizzly and can’t thank him enough. He always saw me playing with his and asked if I wanted one and I couldn’t say no lol. Got a stand made for it tonight. It’s a little tall so may shorten it some and need to ad some shelves but hot bad for some scrap and just metal I had laying on the shelf.
    and a picture of the little man when he couldn’t find his way back out behind the band saw
    27F146F0-107A-427C-B1FA-B159B7926461.jpg 08E5FDEA-9E7A-4B4F-B33D-81A56D0D7867.jpg 7324B674-783A-4B7B-A9B8-7384F576C174.jpg
  8. Dec 9, 2020 at 7:21 PM
    #1348
    malburg114
    Las Vegas, NV
    Remade the upper mount to get most up travel. Straight up and down is roughly 7 inches but will probably get limited to 6.5 or so or until I do some more cycling. Upper link no longer limits the travel as the actual housing is getting into the oil pan at that much up travel.
    Got the steering drilled and sleeved as well. Moving along. Signed up for trails at winter 4x4 so kind of have a deadline now
    DEAC3F8C-68E4-41D6-879E-E8363E5A3839.jpg F517A430-FB13-49CB-B0B5-53D53615C3D3.jpg F57F6D1E-A4C5-4E8A-A5E2-7716D01F5CA3.jpg D1F16135-FD80-4AE9-B045-42D3245ACB06.jpg F0AFAA73-CFF8-47E8-9907-713128310C03.jpg B0D56886-2F63-486D-A92B-9F23C5BA5230.jpg 4666B164-4638-4672-8353-AB40EA751988.jpg
    Lfaub03, Kkrause09, jubei and 5 others like this.
  9. Dec 9, 2020 at 8:52 PM
    #1349
    malburg114
    Las Vegas, NV
    Steering arms. The factory hole is at angle so I’ll grind the misalignments to Match the angle and sit flat
    11BC0947-20F4-4675-9C68-E5F527634E7B.jpg 43AAFC6B-65D3-4B9C-94A6-5D00D8F97FA1.jpg
  10. Dec 10, 2020 at 10:56 PM
    #1350
    malburg114
    Las Vegas, NV
    Moving along. I think everything is in place. Need to get some dom to really start cycling everything. Panhard and draglink are in their approximate place I think. Clearance is tight. And garage is getting full with tools...
    5F9C12E2-67BB-4A63-84A4-1B2DC259190D.jpg 226154DB-5123-4188-875C-6048AC8FDB76.jpg F80D6F7E-8E6B-47B4-823B-9351F2C2871B.jpg 2DD0E759-8568-4729-90EC-11B0F49DFCD0.jpg 0308DE2B-0EC1-4895-B5E8-12E9C17C5566.jpg E4F9E720-32BD-4164-BB52-4417B797E01D.jpg
    Yota X, tacoma16, Lfaub03 and 10 others like this.
  11. Dec 11, 2020 at 8:53 AM
    #1351
    Kkrause09
    Kkrause09 Well-Known Member
    Kyle
    Tacoma sas
    Great work man, you got that packaged in there tight!
    sparkystaco and malburg114[OP] like this.
  12. Dec 11, 2020 at 12:20 PM
    #1352
    malburg114
    Las Vegas, NV
    Not much room that’s for sure. Stuff is just kind of going where it fits with a little adjustment lol
  13. Dec 13, 2020 at 1:30 AM
    #1353
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    You may have to notch that pax side frame rail above the steering. Mine cleared when garage cycling, it started hitting the frame on the trail.
    Yota X, malburg114[OP] and Dalandser like this.
  14. Dec 13, 2020 at 4:55 AM
    #1354
    malburg114
    Las Vegas, NV
    I ended up having to move the draglink to on top of the steering arm so it wil for sure need notched now. I’ll double shear the heim and notch the frame.
    slander[QUOTED] likes this.
  15. Dec 13, 2020 at 4:57 AM
    #1355
    malburg114
    Las Vegas, NV
    Got some dom in town and got all my links and steering etc cut. Need to get two 7/8 1 inch tube inserts as the ones I have are to big for the tie rod but other than that it’s time to really start cycling everything.
    A9A9EBFA-DDE9-4181-A314-229273D16DBE.jpg 3CABDE47-EEB6-4DFC-B45A-990F86F45D45.jpg AD9371B5-8393-47D1-B888-AC7F217F5390.jpg 83419286-8395-4E9C-92EF-136C76D45736.jpg
    Lfaub03, ToyRyd04, Duckfatt and 6 others like this.
  16. Dec 16, 2020 at 10:17 PM
    #1356
    malburg114
    Las Vegas, NV
    More good progress. Frame notched for draglink and panhard. All brackets are made. Need to drill the hole for the pitman arm and finalize the panhard. Looks like everything clears while cycling. Got one bump stop tacked. Going to start on the shock mounts tomorrow hopefully.
    I also made a mistake when putting the cs on had them about an 1/8 in to far on the axle tube on each side keeping the locking hub cap from turning. Made a cradle out of some 1/2 plate scrap I had laying around and got them pushed out. Passenger side barely took any force. Driver side bent a bunch of plate and took some heat and ice but got them done.
    4327D568-01FB-428D-9A69-91301A225B1F.jpg 8B9B179B-F19F-4E01-9D9B-31A4E6B08507.jpg E89DDF2B-5332-48A7-BF77-F6308F17813F.jpg EC3CB353-B7AF-4521-BF7D-3C20395AC383.jpg 75D4E197-B643-4D17-9418-BAC726F95D22.jpg
    Yota X, tacoma16, Lfaub03 and 7 others like this.
  17. Dec 17, 2020 at 5:03 AM
    #1357
    slander
    Hickory, NC
    I dig the knuckle puller of death!!
  18. Dec 17, 2020 at 9:55 AM
    #1358
    malburg114
    Las Vegas, NV
    It was terrifying. Especially when the 1/2 in plate started bending and cracking.
    tacoma16 and slander[QUOTED] like this.
  19. Dec 17, 2020 at 10:47 AM
    #1359
    slander
    Hickory, NC
    I wish I still had a pic of the triangle of death my friend built to straighten his bent 14bolt. It involved an I beam, a section of RR tie a 50ton bottle jack and a bunch of chain. Scary as hell!!
  20. Dec 18, 2020 at 11:07 PM
    #1360
    malburg114
    Las Vegas, NV
    5 or 6 different panhard brackets later and I finally have something I like. Draglink and panhard are within a degree of each other and pretty close in length. Got my bump stops tac’d so I have a hard stop point when cycling the suspension and started locking up the lower shock mounts as I was struggling coming up with an idea to mount them in such a tight space.
    Idea is to angle them back 8-10 degrees to make sure they clear the hood. I may need to notch the bumpstops into the frame though
    5C374F1F-BA42-40B4-8B92-6FF10043F9D3.jpg D9A5E4F3-5B16-49C9-A8C2-BCAB209C7AD8.jpg AF475E97-E018-4F55-A897-74005883BFD4.jpg D08B480A-0B10-4AF0-8EBA-92D00097FFAF.jpg F9EFD5C8-0D12-404F-A54D-40E7504E6A12.jpg
    alee891, allenfab, Duckfatt and 8 others like this.
