Malburg114's 3Link go fast SAS
Discussion in '1st Gen. Builds (1995-2004)' started by malburg114, Jan 4, 2013.
  1. Dec 20, 2020 at 5:48 AM
    #1361
    malburg114
    malburg114 [OP] Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Notched the frame some more for the draglink. Still not enough so think I’ll end up putting a small section of frame on top and bridging it and cutting the entire notch out. Also got the bumps recessed and mocked up a shock to figure out how much downtravel I’ll get. Just a temporary shock tower. Will get redone wider to accommodate the coilover as well.
    1F08C250-D7AB-4BCD-A02F-4309461EE4AE.jpg 544BAE57-7E17-418B-B0E7-E59453264770.jpg 435C5192-E682-4D6E-AB48-6369ECAFEF84.jpg 32577B59-8C49-40EE-A24E-F88236F124E3.jpg 46C89CD7-BE2B-476F-8ACB-44B06257AB33.jpg
    Yota X, jubei, Broke Okie Ty and 7 others like this.
  2. Dec 20, 2020 at 4:53 PM
    #1362
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I had an engineer at my former job tell me that the reinforcement should be 2.5X's the length of the notch on either side. Obviously fact check that!!
    tacoma16 and malburg114[OP] like this.
  3. Dec 20, 2020 at 7:05 PM
    #1363
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Nice work, H. This thing has come a long way.
    jubei and malburg114[OP] like this.
  4. Dec 20, 2020 at 8:19 PM
    #1364
    malburg114
    Las Vegas, NV
    Good to know. I’ll check to see how true that is
    thanks. It’s getting there slowly but surely
    slander[QUOTED] likes this.
  5. Dec 29, 2020 at 10:08 PM
    #1365
    malburg114
    Las Vegas, NV
    Short break for the holidays but finally found some time and motivation to go out and bust out the lower shock mounts and start on the uppers.
    B7797B78-2165-497F-80B3-EF210B97BAB5.jpg 8E691B4A-7709-4196-8C56-5984D849C84D.jpg 733FAA02-529C-497E-8A21-2785D4B64772.jpg 0E5C145C-4E0E-41EF-BE04-EF96C20496CA.jpg
    tacoma16, alee891, jubei and 5 others like this.
  6. Dec 30, 2020 at 5:24 AM
    #1366
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Fab work is awesome, progress is looking good, what machine are you using to weld?
    malburg114[OP] likes this.
  7. Dec 30, 2020 at 11:17 AM
    #1367
    malburg114
    Las Vegas, NV
    Thanks. Not bad for all hand cut. Still using my miller multimatic 215
    Kkrause09 likes this.
  8. Dec 30, 2020 at 10:35 PM
    #1368
    malburg114
    Las Vegas, NV
    Looks like I actually did something today. Got the passenger side shocks mounted and tacked together. Onto the driver tomorrow and then more cycling.
    things are really tight. Had to rotate the bump can so the bypass clears the bolts on full articulation and will have to drill a hole in the panhard mount to get a nut on the shock bolt. Lots of clearancing and cycling to be done.
    hood still closes. Fenders just sagging in that picture. Shocks are angled about 5 degrees back and tops angled 2 degrees out to clear everything.
    249A49BB-8B38-45EC-AA88-1A726FA4DD61.jpg C5D4BC44-57D7-4697-884B-07964A6F0F2D.jpg 0BB3CF4F-6349-4917-AA8F-C19D492F048A.jpg 8C3016F5-ADD5-424C-B580-1589FA10DD75.jpg 3F47AC9F-39D5-4BBB-8F0C-1E797C9FCEDD.jpg 53CA6231-7074-487E-8CB8-F2257789CC2E.jpg 8F59700B-FF7B-423D-9160-A0625E3073F4.jpg C26E8FCA-A3BA-452D-9614-363DC32CF333.jpg B278895A-FD84-48B7-B9A3-5BDADDB51125.jpg C7ED5A77-D0C0-4B0C-9DD8-50EF91C1B836.jpg 9A7F5B5C-725A-47F1-B5AA-EE313C35A2F5.jpg
    PcBuilder14, alee891, jubei and 11 others like this.
  9. Dec 31, 2020 at 6:00 PM
    #1369
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    You used your 2wd prerunner tranny for this?
  10. Jan 1, 2021 at 9:02 PM
    #1370
    malburg114
    Las Vegas, NV
    Yep. Adapter is pretty bad though as it’s a single seal and under torque in 4 low fluid goes by the seal. Better off finding a 4wd trans or finding an aw4 from a Jeep and swapping bell housings etc since they’re the same transmissions essentially
    tacoma16 likes this.
  11. Jan 2, 2021 at 8:29 AM
    #1371
    malburg114
    Las Vegas, NV
    Got the driver side tabs cut and hoop tacked together. It’s always hard copying stuff from side to side to be the same.
    5B9A63BA-3A3B-4EEF-9444-96D1C9C39DC8.jpg CD1D681D-DC56-458B-A665-890079F907D5.jpg 0A2E2B8B-D1B9-4F23-A510-9B27BF597797.jpg
  12. Jan 2, 2021 at 9:41 AM
    #1372
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Nice work as always!
    Those tabs with the hex cutouts are freaking slick!
  13. Jan 7, 2021 at 8:01 PM
    #1373
    malburg114
    Las Vegas, NV
    Lately it’s been one step forward and then 100 back. Had the lower shock mount bolts oriented the wrong way so bad to remake them. The steering arm got into the bypass so had to redo the uppers and angle them back 10 degrees. Bypass still kisses the panhard mount so will angle that in tomorrow. Slowly but surely getting there. Using all of the travel the shocks has though. Atleast on the bypass. Cause of the angles, coilover is the bump at articulation and bypass fully extended the down travel.
    need to finish the lower shocks mounts and clearance the upper shock mounts to get more angle out of them and then it’s onto the engine cage.
    some more pictures
    5FD0F366-209A-4192-8E38-7DE74C8D3F6C.jpg 319F4548-336A-477C-A137-4F730E7DB850.jpg 4CBABE4F-B1C8-40EC-BAE9-35F6C1BDD625.jpg 6B0C4E2B-7C5B-435B-8740-D73B3909DA4F.jpg D4631F9B-65E5-4444-BA0D-D38D6957DF19.jpg 74183845-85E7-4675-B3DB-D20AF8DDFCAF.jpg
    alee891, jubei, Duckfatt and 9 others like this.
  14. Jan 10, 2021 at 9:06 PM
    #1374
    malburg114
    Las Vegas, NV
    Such bad decisions
  15. Jan 19, 2021 at 11:12 PM
    #1375
    malburg114
    Las Vegas, NV
    Went to sand hollow over the weekend and rode with my dad for winter4x4jamboree. Was run. A couple roll overs. Gave me some more motivation to get working. Tried redoing the upper shock mounts again to inboard them more but stuff is to tight so made another set and put them back how I had them. Need to mess with the bypass orientation and do a little more cycling and finish the lower shock mounts but everything is tacked and cycled for the most part.
    sitting at a 24.5 in frame height with 7.5 inches vertical up travel and about 8.5 under articulation.
    took a break from the shocks and started on the engine cage. Took me a few hours to figure out the bender and notcher but got moving pretty well the second day.
    64B60FEC-C274-4E53-A8AA-271E8E9CED9F.jpg 850472CB-373F-45BE-9373-FA6A3C2E1777.jpg C3D95E90-99D0-4442-9981-AD056BCF89AF.jpg 6DB21D4F-0BEC-450A-AA11-1672BE28A922.jpg 671CB508-3649-4433-ABEA-4868DCFC7560.jpg B4503C7B-BC9A-4BBF-AAD0-300BAC0A1677.jpg C8B18284-2357-4F93-BCD7-4A1D5F6F8AC2.jpg BD098AFE-63BA-4F1E-81D0-FBA1602D9214.jpg 8DA53B5D-AE7E-4A3F-94F2-D2E1EBE149D9.jpg C5732E9F-7748-4016-9EF6-1F73F6868A84.jpg
  16. Jan 20, 2021 at 4:58 AM
    #1376
    jubei
    NoCo
    Stuff. Also things.
    Awesome work as always, man!
  17. Jan 20, 2021 at 10:31 AM
    #1377
    malburg114
    Las Vegas, NV
    Thanks. Never really bent/notched tube on my own. All the other projects my dad was around and gave me ideas and guidance so it’s a learning experience. Just kind of putting stuff where it fits lol
    jubei[QUOTED] likes this.
  18. Jan 22, 2021 at 1:17 PM
    #1378
    malburg114
    Las Vegas, NV
    Redid the fender bars. Probably add a 45 piece from the shock tower to the fender bar and then a rear hoop along the firewall and be done with the tube work. Probably time to move onto mounting everything to the tube work. May be time to make a list to so I know what I have to do lol
    C5B44DF0-28E0-402B-9580-43168C6AFAD1.jpg 89DA45D1-0467-404F-994C-FE99978477E6.jpg
    alee891, cbechtold, slander and 6 others like this.
  19. Jan 22, 2021 at 6:30 PM
    #1379
    DillzGarage
    DillzGarage Mall Crawler
    Vegas
    1996/2014 Tacoma
    Hey just a curious question I also live in vegas and I was wondering where do you buy your tubing from?
  20. Jan 22, 2021 at 6:50 PM
    #1380
    malburg114
    Las Vegas, NV
    Curtis steel is where I get sheet metal and tubing and everything else. Curtis doesn’t sell dom unless you special order it so I’ll get that from highland steel or this last time I got the dom for the links and steering from scorpion motor sports which is just around the corner from Curtis.
    DillzGarage[QUOTED] likes this.
