Managing Weight of Truck Cap and DECKED Drawer System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xebeche, Feb 26, 2025.
  1. Feb 26, 2025 at 8:31 AM
    xebeche
    xebeche [OP] New Member
    Portland, OR
    2010 Base Standard Cab 4x4 4cyl
    I have a 2010 Base Standard Cab 4x4 4-cylinder Tacoma. The truck is being loaded for "car" camping, part-time videography jobs and for occasional house projects. All scenarios can have several hundred pounds loaded into the bed. I'm concerned that the stock leaf springs, suspension and other mechanisms that I'm unfamiliar with may need to be replaced or beefed up. I've researched some in these threads, but would really appreciate comment on my specific use case so that I can focus my research and make informed decisions. I'm woefully ignorant right now though.
    An A.R.E. MX truck cap with roof rack will be installed soon. I've already installed a tailgate lock (Pop & Lock PL5400). I'm considering adding a DECKED Drawer System for circumstances where I need to briefly secure some videography equipment in the drawer. The drawer and sleeping platform will be very welcome. I'm also considering Cali Raised Bed Stiffeners as insurance.
    Is this too much weight to have in the truck (should I give up on the drawer system)? If not, what parts should I consider to preserve the truck and the ride?
  2. Feb 26, 2025 at 9:15 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Good call on the bed stiffeners, they're very good to have with a camper shell.
    It's not too much weight to have in the bed, but you'll definitely want to consider upgrading the rear leaf springs with at least an "add a leaf" or new leaf pack. Or you can do airbags.
    I'd recommend installing the drawers and camper shell, then loading the truck as it'll be driven most of the time, then take it to a truck stop/CAT scale and weigh it. Knowing the true weight of the truck is crucial to setting up the suspension appropriately.
    Where are you located?
  3. Feb 26, 2025 at 9:37 AM
    xebeche
    Portland, OR
    Excellent, thank you!
    I'm located in Portland, Oregon. I make frequent trips at all times of year to mountain trailheads and campsites.
  4. Feb 26, 2025 at 10:34 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    On my truck the ARE cap alone put the truck in the Butt squat bro Mode with the headlights aiming noticeably higher then they should have been. It had Toyota's crappy recall springs and definitely needed heavier springs or add a leafs esp when I put something with a little weight in the topper. I ended up with HD leaves and OME884 springs up front to level it out. The job lifted the truck about 1 3/4" which was something else I hoped to come out of the job. An add a leaf would be a cheaper alternative.
    I didn't want a drawer system but wanted a place to store and lock stuff in the back. I ended up building a storage box in between the wheel wells that's bolted into the front tiedown points. I didn't loose the headroom in the topper for it's full length and this was a fraction of the cost of a drawer system. My DCSB is too short to sleep in so it's not interfering with any of that. If did sleep back there I wouldn't have gone this route. The platform works out nicely when loading the truck up for camping, I added lots of tiedown points
    [​IMG] [​IMG]
    Naveronski likes this.
  5. Feb 26, 2025 at 3:13 PM
    TacoTuesday1
    FL
    I’d start by getting a truck with a truck engine
    fatfurious2 likes this.
  6. Feb 26, 2025 at 4:30 PM
    xebeche
    Portland, OR
    It sure would be nice to have a V6, but this 4 cylinder was in my budget and it has been a good truck for my needs.
    Taco_NW likes this.
  7. Feb 26, 2025 at 5:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is a sticker on the drivers door jamb with a statement that reads something like "(The weight of all passengers and cargo should not exceed XXXX lbs). It varies but 1000-1300 lbs is typical. You need to determine this 1st. Considering you have a base model truck with a regular cab you should be on the higher side so that's good. You might be closer to 1400 lbs with the 4 cyl engine.
    That includes your weight as well as any passengers and cargo you put in the truck including the cap or the tongue weight of a trailer.
    Figure out how much the cap weighs as well as everything you want to put in it. Most caps are 180-200 lbs and I doubt if everything else will go over your payload rating. Not having a crew cab keeps the weight of passengers down. Four adults riding in a crew cab Tacoma could just about max out payload without anything else in the truck.
    I think you can make this work, but you have to 1st figure out the payload of YOUR truck and do the math on the weight of what you want to haul. If you're close to maxing out payload some suspension modifications will help improve the ride, but they don't increase how much weight you can safely carry.
  8. Feb 26, 2025 at 5:59 PM
    xebeche
    Portland, OR
    Thanks for the insights! Combined weight for my truck should not exceed 1,300 lbs. (technically 1,297 lbs. per a sticker that reduces capacity by 3 pounds due to modifications). A.R.E. states that a stock MX cap on a mid-sized truck with a long bed is 200 lbs. The DECKED Drawer System for my truck is stated to weigh 205 lbs. Toss me and my daily carry items into the truck and I'm about 50% of the truck's capacity before gear/equipment.
  9. Feb 26, 2025 at 6:59 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
  10. Feb 27, 2025 at 5:16 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Don't listen to the 4-cyl haters. The 2TR-FE is one of the most reliable, most durable gas truck engines Toyota ever made. A proven million-mile motor if taken care of.
    stickyTaco and ridefreak like this.
