Manual gas mileage.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kruuuzn, Nov 22, 2020.
  1. Nov 22, 2020 at 8:28 AM
    Kruuuzn
    Kruuuzn [OP] Well-Known Member
    Randy
    Traverse City, Michigan
    I’ve only ran a couple of tanks through my new Sport but it quickly became obvious that 5th & 6th can almost be considered overdrive gears, especially around town.
    Since this engine is happier in the higher rpms has anyone else wondered if you’re actually hurting gas mileage when using these gears and lugging the motor at too low a speed?
    Junkhead likes this.
  2. Nov 22, 2020 at 8:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Those are OD gears. 4th is 1:1.
    Nope. Once broken in, I can cruise around smoothly at low RPMs, esp with the tune.
    That is the beauty of MT. You can drive it however it feels right.
  3. Nov 22, 2020 at 8:38 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Mt mileage: poor I have around 12k on my 2019 and get better mileage around town than highway.
    fourth gear at around 47mph the mileage indicator all the way up to 30mpg.
  4. Nov 22, 2020 at 8:40 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I keep my RPM's between 2K-3K regardless of what gear I'm in and seem to get a consistent 19 MPG. On So.Cal. freeways there are times I can drive 50 miles or more and never have need to get into 6th. I come from the air-cooled VW World and don't like to lug engines if I can avoid it.
    Blackbeard83 and SilverBulletII like this.
  5. Nov 22, 2020 at 8:43 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    6 manual has no direct gearing 5 and 6 are overdriven. 18-20 is doable 20-23 on the highway.
    Blackbeard83 likes this.
  6. Nov 22, 2020 at 8:45 AM
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Is the mileage indicator actually accurate? Both the current MPGs and the tank MPGs? On my 4R (2003) the est MPGs is always a couple high when I actually average out the tank.
    It's a shame 5th isn't 1:1.
  7. Nov 22, 2020 at 8:46 AM
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    I get 13-15 mpg now with a roof rack. 16 mpg when I was stock.
  8. Nov 22, 2020 at 8:47 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When it's time to fill up the tank the final number is very accurate on my truck, + or - .1 or .2.
  9. Nov 22, 2020 at 8:53 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Modern ones are fairly accurate. It's rare, but the farthest off mine has been was .5 MPG, roughly. I manually calculated it enough times to trust the accuracy.
    shakerhood and Junkhead like this.
  10. Nov 22, 2020 at 9:10 AM
    Kruuuzn
    Randy
    Ahhh.......I didn't know 4th was 1:1. This all makes sense now.
    I only have a little under 1,000 miles on the truck so not too concerned about gas mileage yet, although it IS fun to play with the mileage called out in the readout. I've found the readout to be very accurate also with the couple of full tanks I've ran though it. It's been within a tenth of a gallon.
    I've also got a tune on it but only the basic regular gas tune. I was in a hurry to get rid of that funky throttle response. I'll start to play with the other tunes when I get more miles on the truck.
    tonered likes this.
  11. Nov 22, 2020 at 10:26 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    On secondary roads (50-60 mph) I will see the display up in the 25 mpg range, I generally have a pretty light foot. Steady highway cruise control at 70 mph will drop the number down to 21. I am completely stock including tires.
  12. Nov 22, 2020 at 10:30 AM
    ret42
    VA
    Can you speak to how cruise, particularly adaptive cruise control, work with the manual? In my previous MTs, pressing the clutch would disable it. I'd imagine if you can set adaptive cruise at 70 and traffic slows down to 25 you have to get out of sixth and get down to 3rd. Do you have to re-enable it once you change gears, or will it let you change and remain active? How does the cruise control your speed (decelerating, specifically) when the clutch is depressed? I've been curious but didn't really want to start a thread around it.
  13. Nov 22, 2020 at 10:35 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Sorry, mine is a 2017 so it only has the old fashioned cruise -- thank goodness... The adaptive cruise became standard on the 2018s.
    Fastbilly5, Junkhead and shakerhood like this.
  14. Nov 22, 2020 at 10:40 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    You can shift with cruise and it remains active
    Irons, maytime and Kev250R like this.
  15. Nov 22, 2020 at 10:54 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I have a roof rack and 255/70 AT tires so I get around 17-18 mpg, if I am careful I can get it up to 20+ mpg but I do like to drive with a heavy foot and slam through the gears.
    I regularly cruise around in 6th gear at 35-40mph, as long as you downshift when you want to accelerate the truck doesn't care.
    And the adaptive cruise control is great you can up/down shift and it will remain active, a very nice feature when you go for long road trips.
    Two things I would recommend you do for your truck is the ADM (accumulator delete mod) which gives you a much more responsive feel in the clutch and getting an OV Tune, the tune fixes all the lag/lack of power in the engine.
    For the tune this guy does it at a 1/4 of the cost of having to buy all the software yourself - https://www.tacomaworld.com/threads/shellshocks-midwest-tuning-thread.672327/
    Shellshock likes this.
  16. Nov 22, 2020 at 10:56 AM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    I easily average around 18.5 to 19 when not really paying attention to my gas mileage. If I am, I can get around 21.5 to 23.
    Irons, Junkhead and shakerhood like this.
  17. Nov 22, 2020 at 11:06 AM
    hockeynut258
    hockeynut258 Well-Known Member
    2019 OR MT
    Same here. Put on Duratrac 265/75/16 C loads and maybe lost 0.5-1 mpg.
    Big improvement over my previous 2017 Nissan Frontier V6. Was I the 14-16mph range :eek:
  18. Nov 22, 2020 at 11:08 AM
    RedWings44
    Michigan
    Related question. Has anyone tried/mastered clutch less shifting in one of these? Or will the truck not allow you to?
    Kev250R and TeecoTaco like this.
  19. Nov 22, 2020 at 11:16 AM
    hockeynut258
    2019 OR MT
    I typically double clutch, but haven’t tried clutch less on anything but my motorcycles :rolleyes:
    I’d want to practice on something old and heading to the junk yard
  20. Nov 22, 2020 at 11:18 AM
    Blackbeard83
    Sam
    Massachusetts
    currently stock
    Good to know that you barely lost any going to the 265/75/16! Looking to go to that size when I need to replace my tires.
