manual hub re-installing the axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by blake5995, May 21, 2013.
  1. May 21, 2013 at 10:41 PM
    blake5995
    blake5995 [OP] Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Alright i need help quick. my buddies truck has a 6 inch lift and both lower and upper ball joints sheared off and the spindle went flying. so now i need to put the truck back together. after replacing much of the front end i am now stuck on how to put this axle in. i have never done one with a manual locking hub. i have done the ADD axles 40 times on my truck and i can do it in no time but this manual hub has me beat.
  2. May 21, 2013 at 10:54 PM
    blake5995
    Blake
    Truckee, CA
    no one ever replaced a axle?
  3. May 22, 2013 at 4:05 AM
    Snorkie
    Snorkie Trail Leader
    Snorks
    Earth
    2003 Pre-Runner 1999 2wd 4Runner
    enough to get by on
    What exactly you having problem with?
  4. May 22, 2013 at 12:22 PM
    blake5995
    Blake
    Truckee, CA
    i dont have a problem i have never done a manual hub and the shop i work for hasnt done one in many years so i am kinda lost on it. I know on auto hubs you simply slip the axle end in the hub and tighten the huge nut on the outside of the hub. but on a manual i am guessing it is only held on by a c clip?
  5. May 22, 2013 at 1:38 PM
    Snorkie
    Snorks
    Earth
    enough to get by on
    Yes held on by c clip, but also seen some that have a bolt on the end of the shaft.
  6. May 22, 2013 at 4:13 PM
    blake5995
    Blake
    Truckee, CA
    So how do you go about putting the axle in? Sliding it in the installing the c clip?
  7. May 22, 2013 at 5:19 PM
    ludeaddict
    ludeaddict Member
    NorCal
    1996 Tacoma 4X4
    N/A
  8. May 22, 2013 at 8:02 PM
    Snorkie
    Snorks
    Earth
    enough to get by on
  9. May 22, 2013 at 8:08 PM
    Snorkie
    Snorks
    Earth
    enough to get by on
    I did away with the snap ring and just used the bolt on the end of the axle.
    Using the snap ring
  10. May 22, 2013 at 9:15 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    The snap ring holds the axle in the diff, i would defiantly not "do away with it"
  11. May 22, 2013 at 10:29 PM
    blake5995
    Blake
    Truckee, CA
    yea guys thanks for the help a little late though. i figured it out
  12. May 23, 2013 at 2:50 AM
    Snorkie
    Snorks
    Earth
    enough to get by on
    The "outer snap ring", like the one in the pic.
    The purpose of the outer snap ring is to keep the axle from sliding out of the hub.
