Manual locking hubs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fed454, Jul 16, 2007.
  1. Apr 1, 2021 at 12:50 PM
    #81
    rcjeff
    rcjeff Member
    '98 Tacoma Xtracab 4x4
    To be clear, the front drive portion of the transfer case.
  2. Apr 1, 2021 at 1:01 PM
    #82
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    :rofl::rofl::rofl:
    Free wheeling stops Tcase noise while in 2HI :thumbsup:
  3. Apr 1, 2021 at 1:06 PM
    #83
    rcjeff
    rcjeff Member
    Except that the front driveshaft is still spinning (with live axle/hubs), which is spinning all the internals of the transfer case.
  4. Apr 1, 2021 at 1:07 PM
    #84
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The "front drive portion" along with the differential carrier, ring/pinion gears and the front drive shaft do not spin with ADD in 2wd. Only the CV's, differential side/spider gears and the ADD intermediate shafts.
    Black DOG Lila likes this.
  5. Apr 1, 2021 at 1:24 PM
    #85
    Black DOG Lila
    Virginia
    Yeah, right.o_O
    You must have an unusual drivetrain.
    Or ADD is always ON.
  6. Apr 1, 2021 at 1:28 PM
    #86
    Black DOG Lila
    Virginia
    @rcjeff
    I sure hope this is your idea of an April fool's joke.
  7. Apr 1, 2021 at 1:49 PM
    #87
    rcjeff
    rcjeff Member
    Yeah, yeah. My bad, forgot about the ADD system. Must just be the lack of front axle noise that's made it quieter.
  8. May 1, 2021 at 8:56 PM
    #88
    stihlslayin
    stihlslayin Member
    Blake
    04 tacoma double cab trd
    Trying to figure out a few things before i get started on this project, i got some manual hub assemblies with steering knuckle and cv axles, but the cv axles r crusty and rusty. My plan is to press out the hubs from the manual hub spindles and press them into my spindles on my 04. I bought some koyo bearings off ebay and it said they were compatible with 95.5-04 tacoma but now after more reading im seeing that manual hub bearings are different, is this true? Also i need to get cv axles, can i just get new cv axles for a 96 tacoma that has manual hubs and they will fit my tcase? And is doing the add hose clamp thing absolutly necissary, because the tcase would then always be in 4wd, so wouldnt it defeat the purpose of switching to manual hubs because of driveline vibrations?
    #88
  9. May 1, 2021 at 10:07 PM
    #89
    Kwikvette
    Fresno County
    4 run, 2 don't
    Your cv axles, whether manual hub or add, will absolutely fit your front differential...they do not go into your transfer case.
    The wheel bearings are the same.
    The clamp is to keep the front diff actuator in the engaged position, and make it "fixed" just the way it is fixed on the tube extending from the front differential on a manual hub setup.
    #89
  10. May 2, 2021 at 6:42 AM
    #90
    stihlslayin
    stihlslayin Member
    Blake
    Thank you! So do most people remove the 4wd bulb in the dash so its not always on then seems that would get kind of annoying seeing the light always on
  11. May 2, 2021 at 6:59 AM
    #91
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Nope, the light in the dash is driven by a switch on the tcase, so it'll only be on when 4x4 is engaged.
  12. May 2, 2021 at 9:35 AM
    #92
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Reliability. Plus when locked it essentially is shift on the fly anway. No sense in turning axles unnecessarily
  13. May 2, 2021 at 9:41 AM
    #93
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Can you shift while in motion? I know my j-shift will bark if I’m moving at all
  14. May 2, 2021 at 10:52 AM
    #94
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You can still shift from 2HI to 4HI in motion, though I've found it's smoother if I let off the gas and push in the clutch. 4LO, of course, still requires a full stop.
    Rachelsdaddy likes this.
  15. May 2, 2021 at 12:02 PM
    #95
    Rachelsdaddy
    Southern NH
    I do... all the time during winter.
  16. May 2, 2021 at 5:12 PM
    #96
    0xDEADBEEF
    4 lo goes easier for me if I'm coasting slowly with the clutch in. But on autos, I think you have to stop.
  17. May 2, 2021 at 5:14 PM
    #97
    Kwikvette
    Fresno County
    4 run, 2 don't
    All autos have to stop, put the transmission into N, shift from 4H to 4L, then go to D.
    0xDEADBEEF[QUOTED] likes this.
  18. May 3, 2021 at 8:47 PM
    #98
    LazyEye
    LazyEye Active Member
    2001 Tacoma double cab 4x4
    don't buy a kit just but a pair of cv axles from rockauto for a 98 tacoma w/manual hubs. get the aisin hubs from lowrange offroad, and the stud bolt/cone washers. then you can drop a spartan lunchbox locker in the front diff. of course you'll have to buy wheel new bearings and press out the old ones from your hubs to press in the new ones. i'd have to look and see what I spent but I think it was around 1000 for all I did.
  19. May 4, 2021 at 3:53 AM
    #99
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Quick question.
    I still havn't found a front diff in 4:56.
    So to be clear....If I find an add diff in 4:56, I can use the green (add) cv shafts or the blue (manual) shafts and hose clamp mod the diff?
    If I find a manual front diff in 4:56, I have to use the blue manual CV shafts only?
    Or a front add diff with a non add tube, I use the blue manual cv shafts only?
  20. May 4, 2021 at 4:43 AM
    #100
    stihlslayin
    stihlslayin Member
    Blake
    Im having troubles understanding why we need to hose clamp the diff into 4wd with manual hubs, is it strictly so we dont grenade gears accidentally pressing 4wd while moving?
