Manual Trans Diff Fluid question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Nov 12, 2019.
  1. Nov 12, 2019 at 10:53 AM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  2. Nov 12, 2019 at 11:10 AM
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
  3. Nov 12, 2019 at 11:17 AM
    george3
    New Jersey
    Thanks but I thought we were supposed to use 75w-90 not 85w-90 - don't know if it makes that much difference or not - does it ?
  4. Nov 12, 2019 at 11:20 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    When I had my 5 speed, I tried the MT90 and didn’t notice a difference either, but I guess it has additives to protect the synchros. Who knows? Probably just marketing.
  5. Nov 12, 2019 at 11:23 AM
    Nessmuk
    Bob
    Charlottesville, Va
    I don’t believe it makes any difference. I also tow a trailer a good bit. The manual calls for a GL3 or GL4 oil. Most you find are GL5.
    I also run run SuperTech 80-90 in my diffs. The only synthetic I use is in the transfer case.
  6. Nov 12, 2019 at 11:27 AM
    Nessmuk
    Bob
    Charlottesville, Va
    The Stalube has no sulfur in it from what I can see.
    This is from my manual:
    Manual transmission
    Gear oil capacity (Reference)
    2.7 L 4-cylinder (2TR-FE) engine
    4.0 L V6 (1GR-FE) engine
    2WD models
    2.7 qt. (2.6 L, 2.3 Imp.qt.) 4WD models
    2.3 qt. (2.2 L, 1.9 Imp.qt.)
    1.9 qt. (1.8 L, 1.6 Imp.qt.)
    Gear oil type
    Gear oil API GL-3 (GL-4)
    Recommended gear oil viscosity
    SAE 75W-90
  7. Nov 12, 2019 at 11:43 AM
    george3
    New Jersey
    Thanks for replies guys.
  8. Nov 12, 2019 at 12:05 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I run 85w140 Lucas in mine and i havent had any issues. It's a little bit stiffer to shift when its below 30* outside until it warms up for a minute or two. After that i can't tell a difference from the 75w90
    Nessmuk likes this.
  9. Nov 12, 2019 at 4:41 PM
    george3
    New Jersey
    It was 20F today and not even Thanksgiving yet - think I'll stick with the 75 - I like somethings stiff but not shifting. Thanks.
    BassAckwards[QUOTED] likes this.
  10. Nov 12, 2019 at 4:44 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Any GL-4 will work fine ..a GL-5 that is formulated to help with yellow metals will do just fine as well
    I have been using MOBIL 1 for about the past 25k miles.... No issues. (2.7L 4X4 Manual Trans)
  11. Nov 12, 2019 at 4:47 PM
    george3
    New Jersey
    Thanks.
