Manual trans floor shift assembly diagram
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05taconorth, Nov 17, 2019.
  1. Nov 17, 2019 at 3:55 PM
    05taconorth
    05taconorth [OP] Active Member
    Dan
    2005 TRD Off Road
    Hi all.
    I’m looking for help finding a part.
    At the bottom on the shifter (the black rod section) there is a rubber sleeve that has worn out. I’m trying to find a part number but can’t find a detailed diagram.
    Can anyone help me out? I’m thinking a more detailed diagram of the floor shift lever assembly might be helpful.
    05 4.0L manual trans.
    Thanks.
  2. Nov 18, 2019 at 3:52 PM
    05taconorth
    Dan
    2005 TRD Off Road
    Bueller?
  3. Nov 18, 2019 at 5:00 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  4. Nov 18, 2019 at 5:11 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    MY50cal and garciav like this.
  5. Nov 19, 2019 at 6:00 AM
    Hazzi03
    Hazzi03 Member
    North NJ
    05 Silver 4dr TRDOR 6 speed 4.0
    5100's w HS 2.5in coils, Icon AAL, JBA UCA's, URD short shiftier, kenwood head unit & speakers, Blaisbrostacos rear diff breather mod, TRD battery hold down. SCS Ray 10's 16in wheels, 285/75 Cooper AT3 xlt
    Im having the same problem, It's the plastic bushing that disintegrated at the end of the black shaft... I was quoted that the whole shifter would need replacement. Im thinking of going with a hurst for a pretty penny thouogh
  6. Nov 19, 2019 at 7:28 AM
    Jeff Lange
    Calgary, Canada
  7. Nov 19, 2019 at 7:38 AM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    BassAckwards likes this.
  8. Nov 19, 2019 at 8:57 AM
    05taconorth
    Dan
    2005 TRD Off Road
    Bingo. That’s the part that busted.
  9. Nov 19, 2019 at 8:59 AM
    05taconorth
    Dan
    2005 TRD Off Road
  10. Nov 19, 2019 at 9:01 AM
    Jeff Lange
    Calgary, Canada
    Read my earlier post for the part you need.
    Jeff
  11. Nov 19, 2019 at 9:02 AM
    Jeff Lange
    Calgary, Canada
    Oh hold on, are you saying you broke the shifter itself? Yeah you can’t replace that. You need the whole shift lever for sure.
    Jeff
  12. Nov 19, 2019 at 12:05 PM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    Theres another thread on here where someone mentioned they had epoxied the two back together. That bushing between the two shift levers molded in there around the shaft of the bottom half. Just fill the top half with an epoxy and stick it over the bottom half. You should have the shifter out of the truck when you do that so you can have it upside down. Otherwise epoxy will get all over the place. Not sure what type of epoxy to use.
    05taconorth[OP] likes this.
  13. Nov 20, 2019 at 7:47 AM
    05taconorth
    Dan
    2005 TRD Off Road
    In researching this I saw that @badger posted saying he had made a new rubber bushing.
    Maybe he’ll chime in with some wisdom?
  14. Nov 20, 2019 at 3:57 PM
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    Ah, your stick bushing gave out.
    My old assembly is collecting dust if you're interested... where are you located?
    Might still have the urd SS still with it too, will have to check the parts bins.
  15. Nov 20, 2019 at 4:58 PM
    05taconorth
    Dan
    2005 TRD Off Road
    Sent you a pm
    MY50cal[QUOTED] likes this.
