Manual trans hard to drive smoothly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vTEQ, Oct 29, 2019.
  1. Nov 4, 2019 at 8:37 AM
    #121
    su.b.rat
    su.b.rat broken truck
    seriously y'all, only a grandma with internet paranoia refuses to do this. if you can log onto TW you can work this out and stop whining about dealer morons. you can fix this yourself. probably in less than an hour all said and done.
  2. Nov 4, 2019 at 8:37 AM
    #122
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    2018 MGM Tacoma TRD Sport 4X4 M/T
    TRD Cold Air Intake TRD Manual Transmission Shift Knob Tacoma All-Weather Floor Mats Tacoma Center Console Organizer Tacoma Roof Rack Tacoma Tri-Fold Tonneau Cover TRD Exhaust TRD Pro Fox Shocks (front & rear) TRD Matte Grey 17" Wheels 265/70/17 Falken Wildpeak Tires OV Tune SFOB Premium Tune Accumulator Delete
    Once I flash with OVTune doesn't it forgo the latest ECU version and just uses the data from OVTune?
  3. Nov 4, 2019 at 8:38 AM
    #123
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    They are hanging their hat on that it references torque converter and the manual doesn't have one. But the TSB pertains to throttle response etc. from my understanding.
    Obviously TSB are issued off of number of complaints and the MT crowd doesn't have enough numbers to justify their own TSB I guess.
    shakerhood[QUOTED] likes this.
  4. Nov 4, 2019 at 8:38 AM
    #124
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
  5. Nov 4, 2019 at 8:39 AM
    #125
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    OVT overlays the ECU software and there are some areas that he doesn't touch like TRAC. Read up and make an informed decision. Like I said, the TSB tune is a free update once you get the OVT kit.
  6. Nov 4, 2019 at 8:39 AM
    #126
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    They did a TSB for me on my AT for free because it had a code stored . It was free but regular price is $48 slip said .
  7. Nov 4, 2019 at 8:40 AM
    #127
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Slow down and read! It is the 'same software.'
  8. Nov 4, 2019 at 8:40 AM
    #128
    su.b.rat
    if you want your motor as good as it can be, both. if you just care about driveability & smooth shifting, i guess the TSB alone may be sufficient for you.
  9. Nov 4, 2019 at 8:41 AM
    #129
    briandock
    briandock Well-Known Member
    San Rafael, CA
    2012 TRD Off-Road DCSB
    Stock
    I short shift it from 1st to 2nd, maybe 1,500 RPMs or wring it out to 3,000-3,500.
    If my girlfriend is with me, I shift slow. Roll off the throttle and take 1-1.5 seconds to shift, and its smooth as butter. When shes not with my its probably a wild ride.
    ArmandHammer83 and Junkhead like this.
  10. Nov 4, 2019 at 8:41 AM
    #130
    su.b.rat
    you are thinking way too much about stuff that doesn't matter. what are you trying to accomplish exactly?
    tonered likes this.
  11. Nov 4, 2019 at 8:42 AM
    #131
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The problem is that the original revision of both TSB-0058-18 and TSB-0125-18 reference MTs and MT ECU IDs. They pulled that from the current revisions. The old revs are in the MT Update thread. The current versions can be found at nthsa.gov.
    6MTPro[QUOTED] and shakerhood like this.
  12. Nov 4, 2019 at 8:42 AM
    #132
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I really need to get that TSB Tune done one of these days too, just haven't had time to go to the Dealer
    Junkhead, 6MTPro and tonered like this.
  13. Nov 4, 2019 at 8:44 AM
    #133
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am absolutely certain that someone local to you would be happy to help you out if the dealer doesn't come through.
  14. Nov 4, 2019 at 8:44 AM
    #134
    6MTPro
    HI -> CA
    Yeah I think that actually made it harder/worse, because they said they use only the latest and greatest for reference.
    tonered[QUOTED] likes this.
  15. Nov 4, 2019 at 8:47 AM
    #135
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    I'd likethe truck top simply run smoother. Improved driveability. Better throttle response, smoother delivery of power. I've been reading through all the OVTune forums and ECU update forums for the manual transmission and just trying to decide what I should do.
    su.b.rat[QUOTED] likes this.
  16. Nov 4, 2019 at 8:49 AM
    #136
    su.b.rat
    ok got it. i strongly suggest you make this easy:
    - setup a computer with TIS and install the TSB yourself, or a dealer if it's convenient.
    - stop there and spend some time assessing. i bet that will be all you need.
    - if you feel you need more, OVT is waiting for you.
    tonered likes this.
  17. Nov 4, 2019 at 8:49 AM
    #137
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is just harsh as MTs engines suffer the same problems as the MTs. When the revisions happened, I expected them to make it simpler by dropping MT specific TSBs. That didn't happen, but someone at corporate obviously created software for 04B10, 04B11, 04B12, and 04A70.
    Like I said to @shakerhood , I'm certain that there is someone near you that would help you out.
  18. Nov 4, 2019 at 8:51 AM
    #138
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is exactly what I did and how I ended up where I am at. I borrowed a cable graciously loaned out by @mstrbrc and then ponied up for OVT when he added features specific to the MTs.
  19. Nov 4, 2019 at 8:52 AM
    #139
    Mike2121
    Mike2121 Club-Coma
    Michael
    Georgia
    Thanks for your input. Might I ask what you have installed? Curious to know what each tune drives like.
  20. Nov 4, 2019 at 8:59 AM
    #140
    su.b.rat
    you mean software?
    i started with OV back with the first alpha files when it was only MT trucks. that was before the TSBs. i did the TSB when it showed up, and then OV enhanced his files after that, and i kept upgrading OVT as the files released.
    i bought OV catless dump tubes on release and got a catless dump tube 2.0 beta file for 93oct and installed it at that time. the tubes leaked badly so i went back to stock front cats temporarily, but I've been running this 2.0 catless beta file ever since because it runs so great.
    tl;dr; latest TSB + OVT 2.0 beta catless dump tube for 93oct. :)
    tonered likes this.
