Manual Transmission clunking in neutral going over bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yzkiley, Jul 26, 2016.
  1. Jul 4, 2018 at 4:27 AM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    I’ve had three manual Tacoma’s and they’ve all done this. I just stay in gear over speed bumps.
  2. Jul 4, 2018 at 5:16 AM
    toddab68
    toddab68 New Member
    My 17 trd off road used to do this. There is a tsb out for a howl noise, at 30 to 50 specific to manual transmission. (Not rear end howl). I think they put some dampers on transmission or exhaust. Mine sounded like a bell clanking over bumps. Tsb fixed it.
    No more clanking. If you search for the howl noise and manual trans on forum you will find tsb. Just describe the symptoms in tsb and dont mention internet they should fix it for you. I did have howl noise and was pleased that tsb fixed clanking noise which was a bonus. I will look for my paperwork for tsb#
    mackay and bobrown14 like this.
  3. Jul 10, 2018 at 11:27 PM
    mackay
    mackay i love cheap beer!
    SLC, UT
    OME 881 ARB Bummper/XRC OME Dakars
    Just got mine on. Clunking can still be heard sometimes but is greatly reduced in frequency and harshness. Running 5 psi now w.o load. I can't recommend these bags enough if you tow or load dirt bikes or motorcycles.
  4. Jul 10, 2018 at 11:29 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    It's a truck. Get some real tires, roll the window down, turn the radio up, and stop worrying about all the noises that come from it. If it's not broke, don't fix it.
    radclerk1 likes this.
  5. Jul 10, 2018 at 11:36 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Funny. People comment on the clutch chatter in my truck like it's a good thing. Your truck is fine, you're reading too much TW.
  6. Sep 6, 2019 at 4:48 PM
    Rdalexanry
    Rdalexanry New Member
    2016 Double Cab Tacoma Off Road 6 Speed
    Did you ever find the tsb #? Mine is doing this
  7. Sep 6, 2019 at 5:26 PM
    Jepoy_Cemento
    Jepoy_Cemento Well-Known Member
    Alaska
    2019 Tacoma OR 6MT 4x4
    Just going to assume its normal. I hear clunks from 1st to 2nd gear as well at times, most definitely when shifting at lower RPM.
  8. Sep 6, 2019 at 5:36 PM
    Rdalexanry
    I figure the clunk is normal even my 87 does that. I have a howl in neutral with foot off the clutch pedal and it gets louder before road noise takes over when accelerating. Sounds like it's coming from the front of the truck. Its going in next week to be looked at.
  9. Sep 6, 2019 at 6:57 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I found you have to do very smooth and slow release on the clutch pedal to get rid of the clunking a lot of times . I blame it on the clutch fluid accumulator. I kind of learned to live with it but would like to remove in the future.
    85% of the time are perfect shifts tho :D
    Jepoy_Cemento likes this.
  10. Sep 6, 2019 at 7:00 PM
    Jepoy_Cemento
    Alaska
    Imma test that out, but yea other than that smooth shifting.
    Junkhead[QUOTED] likes this.
  11. Sep 6, 2019 at 7:04 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    This tranny is buttery smooth compared to 5 previous MTs ive had. Love it.
    :burnrubber:
