Manual Transmission Clutch Squeak?
Discussion in '3rd Gen. Tacomas (2016+)' started by Pags500, Jul 4, 2020.
  1. Jul 4, 2020 at 7:01 AM
    Pags500
    Pags500 [OP] New Member
    2019 TRD Off Road Double Cab Manual
    My 2019 TRD Off Road just passed 1 year old, and its developed a squeak in the clutch pedal inside the cab. I know it's a pneumatic clutch connection so I'm not worried about the transmission itself, but it gets progressively louder every time I press the pedal in normal driving conditions. Has anyone else noticed this? And is it just the spring on the pedal itself that can be fixed by some WD-40?
    Any suggestions? Thanks!
  2. Jul 4, 2020 at 7:08 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Disc Brake Grease on all the pivot points will take care of the old barn door creak sound.
  3. Jul 4, 2020 at 9:04 AM
    Smalltaco44
    Smalltaco44 Active Member
    Central Illinois
    2018 Barcelona Red Tacoma TRD Sport 4x4
    MBRP stainless split dual exhaust, MX4 Bakflip Tonneau Cover, Tuffyproducts bed lock box, Redline Tuning hood struts, Gentex homelink rearview mirror, Weathertech side window deflectors, Rockymounts bike mount in side bedrail, a/c drain mod, front bumper & side mirrors clear vinyl, Ziebart undercoating, Tacoma bed and dash letters, bed extender, Predator side steps, LED bed lights.
    Mrtacoman88 and SilverBulletII like this.
  4. Jul 4, 2020 at 9:13 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    yeah. itll happen eventually. happen in my 08 xrunner, and my 13 trd or. now my 19 trd sport has it very slightly. all was purchased brand new off the lot, so i was there when it developed. i pretty much babied all of them, so to me its only a matter of time. like mentioned earlier, small dab of grease should alleviate. i never knew about the tsb so maybe that too.
  5. Jul 4, 2020 at 9:17 AM
    Smalltaco44
    Central Illinois
    Yeah - it's only been a known issue for Toyotas for the last 15 years or so - not holding my breath that they're going to fix this anytime soon... They tried to grease the original assembly, but it started squeaking again before I even left the dealership. I took it straight back and showed them the TSB, and they replaced everything; no questions asked.
  6. Jul 4, 2020 at 9:40 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I don't understand why someone would spend a day (or more) dealing with a dealership and having a major component replaced when the fix is so easily done in less time than it takes to drink a beer. Seriously, 5 minutes to apply some thick grease to a couple moving parts that you can reach from inside the cab and you won't have to hear the sound again. I haven't had to reapply the grease once and haven't heard a squeak in the 4 years since I did this on my truck.
    TRD4X4TOY likes this.
  7. Jul 4, 2020 at 9:44 AM
    Smalltaco44
    Central Illinois
    To each their own, I guess. FWIW - once the parts were in, it only took a couple hours for them to replace the assembly. My thought is I spent a lot of money on my truck and didn't feel that slathering a part with grease was the right answer for me. Again - for me - the dealership tried to lube up the assembly, but it didn't fix the issue.
  8. Jul 4, 2020 at 9:47 AM
    Smalltaco44
    Central Illinois
    ... also - if you look at the TSB, the replacement parts are different part #s than the factory original assembly. Why Toyota couldn't just put the replacement parts in our trucks from the get-go is beyond me.:confused:
  9. Jul 4, 2020 at 9:49 AM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Yep, my manual FJ Cruiser had it. Sprayed the areas above the clutch pedal with grease and it's gone.
    Mrtacoman88 likes this.
  10. Jul 4, 2020 at 10:24 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Usually roll with the windows down so I rarely notice the squeak
  11. Jul 4, 2020 at 10:28 AM
    Mrtacoman88
    Mrtacoman88 TRDude
    Serge
    Canada, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    They replaced mine but it came back after few months. I will just use some grease when it gets annoying. It comes and goes, so it doesnt really bother me.
    TRD4X4TOY and shakerhood like this.
  12. Jul 4, 2020 at 11:23 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Toyota replaced my entire assembly 2 years ago and the squeak came back last year. I've since just been applying grease every 6 months or so and it's been fine since.
    shakerhood and TRD4X4TOY like this.
  13. Jul 4, 2020 at 11:49 AM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    2019 Tacoma TRD Off-Road DCSB 6SPD MT
    2019 Tacoma TRD Off-Road 4x4 All stock 2014 Tacoma TRD Sport Exterior: Debadged TRD pro badge (TRD only) on tailgate Removed mud flaps Toyota OEM cargo net TRD Pro grille insert Weathertech window visors TRD skid plate Relentless Fab driver and pass. hood mounts Lighting: Toyota OEM smoke housing headlights LED interior lights and license plate lights Interior: Weathertech floor mats Suspension: Bilstien 5100 shock absorbers all around Toytec Eibach front springs Toytec 1" rear blocks and U-bolts FN BFD wheels Nitto Terra Grappler tires Mcguard lugs Eletronics: Factory Navi with JBL Cobra 75 CB radio Uniden BCD536HP Scanner
    I got the creaking sound... dealership replaced the assembly and all
    Is good..... for now but I feel it coming back ...
