Manual Transmission Downshifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dingchavez24, Apr 8, 2010.
  1. Apr 8, 2010 at 11:11 AM
    dingchavez24
    dingchavez24 [OP] Active Member
    Charlotte, NC
    09 Manual TRD Sport SR5
    Current: URD Short Shifter, Flyeyes, CB, Billy's rear bumper
    So this is more of a "feeler"/poll for how everyone else is driving their 2nd Gen 6 spd manual's... As i'm a seasoned veteran of driving multiple manual trucks in the past, i've noticed that finding a good downshifting point between 3rd and 2nd gear when approaching a stop sign/red-light (on a flat road) is a bit tricky... I end up with either too low of an engine RPM to provide any "transmission breaking", or too high of an RPM that may be detrimental to the transmission... So, if you have a manual transmission, please provide some thoughts on the following for when you're approaching a stop sign or red-light on a flat road at 45 mph:
    1. do you downshift?
    2. have you found the "sweet-spot" in either your speed or on the tac that provides applicable engine breaking?
    3. at what estimated distance prior to the stop sign/red light do you perform your downshift and in what gear?
    etc...
    any other thoughts would be welcome!
  2. Apr 8, 2010 at 11:18 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i've got a 5 speed....but i leave it in 5th until it's about to stall out, then toss it in N.
    if i know i will be speeding up without coming to a stop, i leave it in whatever gear i'm in, until it's time to go, and then grab the right gear for the speed
  3. Apr 8, 2010 at 11:19 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    still searching for a sweet spot myself. most times the RMPs are too high to feel a good engine brake.
    at times I may ride the clutch a bit to get a good brake then release it all the way.
    I used to downshift in my Gen1 all the time but this G2 6spd is still driving me nuts
  4. Apr 8, 2010 at 11:25 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Dude, brake pads are MUCH cheaper than a clutch.
    Just leave it in the gear your in until about 1k rpm then put it in neutral and use the brakes. On my first gen, it will go into neutral right at 1k rpm with out the clutch since there is no load on the trannsmission at that point.
  5. Apr 8, 2010 at 11:34 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    That is true, if you can rev match it on the downshift than it is okay, but I have yet to ride with someone else who actually does that and it makes me cringe every time.
    I just like to save the wear and tear on the drive train and use the brakes when coming to a complete stop.
  6. Apr 8, 2010 at 12:03 PM
    importeater
    importeater Member
    I was half and half on my old 05 tacoma. From what I can remember I didn't really engine brake much. I probably wouldn't downshift to 2nd until I was around 30 mph.
  7. Apr 8, 2010 at 12:07 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    If I down shift, usually I do not, I tend to throw it in 3rd. The gears are geared to low to drop it into second unless you blip the gas pedal to match the RPMS.... too much work, I just drive "normally" and not Indy 500 style.
  8. Apr 8, 2010 at 12:09 PM
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    boom! i agree you can buy ceramic pads turn rotors and drums for
    150-200
    clutch by itself is like 400-600...
  9. Apr 8, 2010 at 12:38 PM
    Dan893
    Dan893 Well-Known Member
    Dan
    Connecticut
    09 SR5 doublecab longbed
    TRD cold air intake, 6k HID headlights, 3K HID foglights, custom sockmonkey decals
    I just used my brakes and left it in watever gear I was in and then went into neutral before I stopped brake pads are much cheaper than a tranny rebuild I.e. Syncros, clutch and wear on the backside of the gears you guys can do what you want but I've always been told downshifting was not the right way to slow a vehicle down
  10. Apr 8, 2010 at 12:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :thumbsup:
  11. Apr 8, 2010 at 2:27 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Watch your rpms when you upshift, that's what your rpms are going to be when you downshift at a particular speed. When downshifting, you can probably figure the rpm is going to go up about 500 rpm higher than the gear you're currently in for the same speed. If your foot is off the gas when it's at the higher rev, that's going to be more abrupt than the upshift was. Give the engine a rev in neutral before downshifting and it'll be much smoother. I do that as well if I'm coasting on the freeway. I'll give it a quick rev before putting it back in 6th so I don't get that jerk when letting off the clutch. You don't have to be super fast for it to make a difference.
    For the most part, I just shift to neutral and brake.
  12. Apr 8, 2010 at 2:49 PM
    LawP
    LawP Well-Known Member
    Rio Rancho, NM
    2010 4x4 TRD OR Double Cab
    I always used to use the brakes and shift into neutral. I have never driven this truck in the manual configuration so I can't comment per say (I can no longer put weight on my left lower leg/foot due to a 45ft fall in the military), it is pretty nice driving an automatic, to just drive, and relax. I remember sitting in traffic driving up a mountain in MN and my leg would be dying it hurt so bad.
  13. Apr 8, 2010 at 2:51 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    I used to downshift until today!:wink:
  14. Apr 8, 2010 at 3:42 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    I know exactly what your talking about! It took me a few months to master the "sweetspot". And even know im still not perfect at it!
  15. Apr 8, 2010 at 3:56 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I'm 50/50. But when I tow my travel trailer I use more engine breaking
  16. Apr 8, 2010 at 3:57 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    heel toe off the off ramps!
  17. Apr 8, 2010 at 3:57 PM
    beetlejuice2275
    Reximus
    Queens, NY
    if you don't, get an automatic!!!! aahhahahaaahha
  18. Apr 8, 2010 at 4:13 PM
    Taco Guapo
    Taco Guapo Lurker
    Carefree AZ
    09 AC 4X4 2.7L
    Bone stock
    I've been downshifting every manual shift vehicle I've ever owned for 40 years and only had one transmission failure, in a Ford (never again). My Jeep with manual trans had 126,000 miles when I sold it and still had original clutch AND brakes. OTOH, every automatic I've ever had went through front pads every 25 to 35,000 miles.
  19. Apr 8, 2010 at 4:18 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I downshift quite a bit to slow down. That said, I do it sensibly.
    As for the OP's question, I don't really have a set of rules for downshifting that I could explain. Everything is situational dependent.
    I almost never downshift to 2nd to slow down. I've found the drop to 2nd is too low. I use 5th, 4th, and 3rd at various times to slow down, but usually from third I go to neutral and exclusively use the brakes if I'm coming to a stop. If I do downshift to 2nd, it's simply because I've slowed down to that speed and figure that's the gear I'll need to continue forward.
  20. Apr 8, 2010 at 4:19 PM
    MGRS
    MGRS Well-Known Member
    '20 Tundra OR
    I generally leave it in gear and let the drivetrain slow the truck down until it is about to stall, and then throw it in neutral and use the brakes.
    I do downshift some when towing to achieve more control over the truck and trailer.
    On a daily basis, I see no point to it. I can do brakes easily and cheap. On a clutch I am not so confident.
