Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Feb 12, 2017 at 4:20 PM
    #3541
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So lessons learned, if you're from Cali, you should know the Grapevine...I went through the Grapevine in 6th gear and cruise control at about 70. Only mod was Supercharger, stock tires and upgraded performance stuff. Watched boost going up but never pegged out. I'm like 90% sure thay accelerated my clutch burn out, but that would have happened later anyways. It was cool to see it make it though.
    For those that don't know its like 10-20 miles of super uphill from Sea level to I wanna say 5k feet? And then back down. No clutch burn after the fact.
  2. Feb 12, 2017 at 4:20 PM
    #3542
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Nearly identical mines an 01
  3. Feb 12, 2017 at 4:47 PM
    #3543
    Danno04
    Danno04 Well-Known Member
    16 GX460, 22 4R PRO, 22 M5C
    Yea I got that. I found a rubber grommet at SEARS, but its too small, I couldn't find the right size at home depot, but I don't like how it just sits there like a flap. I need to find the grommet from SEARS the right size as you can actually stuff the chrome indentations inside of it and its very secure.
    Thats how it looks like, like a doughnut.
    This size is too small, i think 1 and 1/8 overall diameter, 1 and a 1/2 would cover it perfectly.
  4. Feb 12, 2017 at 4:56 PM
    #3544
    Sprouty115
    Sprouty115 Well-Known Member
    RI
    2017 Tacoma Sport 6MT
    1-3/8" is the actual OD of the chrome ring. The 3/4" grommet from Home Depot has a 1-1/4" OD, but it covers the chrome ring enough so that you don't see the inner retaining features. If you trim off the bottom lip of the grommet it's pretty secure.
    mustangwilly likes this.
  5. Feb 12, 2017 at 8:19 PM
    #3545
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2019 Ford F150 XLT
    I just switched mine - I wanted something with a little more pop than the TRD knob.
    su.b.rat, Sprouty115 and TACK like this.
  6. Feb 14, 2017 at 10:13 AM
    #3546
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
  7. Feb 14, 2017 at 1:17 PM
    #3547
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    Probably a long shot but do you know what diameter the chrome piece is where the boot attaches to it? Also, is the shift rod tapered all the way down or is the spot where the 3/4 o ring sits a consistent diameter? Reason I'm asking is I want to machine a steel piece with a set screw and get rid of the chrome piece all together and run the round trd shift knob. I would look at my own truck but it's still on order. Here's an idea of what Im going to machine.
    http://m.ebay.com/itm/VMS-MUSTANG-S...3A3e7b243615a0a622836f7f98fff8975a%7Ciid%3A11
  8. Feb 14, 2017 at 1:20 PM
    #3548
    Sprouty115
    RI
    Will have some info a bit later, when I get home...
    I somehow thought you were asking for the measurement of the ID of the chrome ring, bur I realize now you are looking for the measurement of the bottom of the chrome ring where the boot is attached - that would take some disassembly, sorry.
    As for the taper - the actual measurement of the shaft where I can push the ring down is about .700" and it's hard to tell if the taper continues. So considering this is something you are going to machine, I'd check all the dimensions once you get your truck.
    Thought I could be more helpful...
    mustangwilly[QUOTED] likes this.
  9. Feb 15, 2017 at 1:54 PM
    #3549
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    Digging my truck so far. Haven't gone anywhere far yet. Hopefully soon. The engine and MT seem to loosen up over time. I'm getting about 16 MPG in the city and 19 on the highway. About as expected... odd it doesn't do better than that considering the redesign and wind tunnel work etc. Overall happy with the truck and I expect rising levels of stokeage as I get out on some adventures.
    TroutBum likes this.
  10. Feb 15, 2017 at 2:06 PM
    #3550
    mustangwilly
    Thanks for looking. Ill just mess with it when mine shows up.
  11. Feb 15, 2017 at 2:53 PM
    #3551
    WyomingSkidmark
    WyomingSkidmark Well-Known Member
    I'll be taking a 16 hr trip down to Texas this week, really curious to see what the mpg's are going to be during the drive and also the change at a lower elevation. Going from 7220' to less than 1000'
  12. Feb 15, 2017 at 2:54 PM
    #3552
    PROseur
    Pussy
    I did 3600 mile trip with my PRO. Got 21.75 MPG.
    Rownan and TroutBum like this.
  13. Feb 15, 2017 at 3:06 PM
    #3553
    su.b.rat
    su.b.rat broken truck
    that's an AT truck, right?
  14. Feb 15, 2017 at 3:07 PM
    #3554
    PROseur
    Pussy
    sorry, i would swallow my mom's dick before I drive AT 3rd gen.
    Both my 16 OR and my 17 PRO are how god intended real men to drive, MT
  15. Feb 15, 2017 at 3:10 PM
    #3555
    su.b.rat
    i asked cus that number... i thought you mentioned having MT somewhere, but i can't wrap my head around that number. i haven't even hit 18 yet, almost to 4400 miles.
  16. Feb 15, 2017 at 3:11 PM
    #3556
    PROseur
    Pussy
    My truck has 10,200 miles as of yesterday.
    In my regular everyday driving, 17.89MPG is what I have reached best.
    That was on my 3600 mile trip up to Montana.
  17. Feb 15, 2017 at 3:15 PM
    #3557
    su.b.rat
    i see. i went DFW to Houston and back, but i was on bigger tires then and the truck was under 2k miles, so that's not a fair comparison. I'm heading to Austin and Houston again Friday so I'll see how it goes. got the smaller tires, but went up to E tires so they're heavier, and i got a tonneau as well, so hoping for at least 18. first oil change tomorrow, too.
  18. Feb 15, 2017 at 3:16 PM
    #3558
    PROseur
    Pussy
    Mine had bone stock tires. No tonneau.
    I am going narrower and lighter tires, and switching out to 245/255 section width. Also added LEER camper.
  19. Feb 15, 2017 at 3:19 PM
    #3559
    su.b.rat
    yeah the tires may be our big difference. I'm on 265.65.17 ST Maxx. love'em, but E tire heavy.
  20. Feb 15, 2017 at 3:19 PM
    #3560
    PROseur
    Pussy
    I have no need for heavy tires. I only go to the mall :)
