Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 16, 2017 at 6:52 PM
    #5341
    natural_nativ
    natural_nativ Well-Known Member
    2024 TRD Sport MT
    Wow. Our avatars have finally come together. I've seen you on here and wanted to say something, but now is the perfect time.
    su.b.rat and nevadabugle[OP] like this.
  2. Jul 16, 2017 at 6:54 PM
    #5342
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Are the installed correctly. Alot of times the coil isn't seated perfectly in the coil seat on the shock and that causes a little clunk when the coil shifts. How about wheel bearings? Grab your tire from the top and push it in and out of the wheel well until it starts moving the truck a bit, if you hear a click/clunk from the hub, your wheel bearing is going out. Just because you're not hearing the whirring or grinding noise when driving doesn't mean it's fine.
  3. Jul 16, 2017 at 6:55 PM
    #5343
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Because these 3rd Gens have a weird dead spot low in the rpm range, it's hard to describe unless you drive one.
  4. Jul 16, 2017 at 6:55 PM
    #5344
    VolcomTacoma
    Jeff
    NorCal
    That's what's up. Be alot cooler if you had the quote though ;)
    nevadabugle[OP] likes this.
  5. Jul 16, 2017 at 6:57 PM
    #5345
    natural_nativ
    2024 TRD Sport MT
    Alright, alright, alright, I'll get one.
    VolcomTacoma[QUOTED] likes this.
  6. Jul 16, 2017 at 6:57 PM
    #5346
    VolcomTacoma
    Jeff
    NorCal
    That's fine. Again, how does that correlate to shifting. I'll repeat myself again, it doesn't matter how little or how much power you have in your power band, if your transmission and engine speeds are synched up perfectly when you release the clutch, there will be no bucking. Bucking is caused when you release the clutch and your engine speed is higher or lower than the transmission speed, causing the transmission and engine to forcefully sync up speeds to each other.
    02Duck likes this.
  7. Jul 16, 2017 at 6:58 PM
    #5347
    VolcomTacoma
    Jeff
    NorCal
  8. Jul 16, 2017 at 7:02 PM
    #5348
    natural_nativ
    2024 TRD Sport MT
    How's that?
    Clever enough?
  9. Jul 16, 2017 at 7:04 PM
    #5349
    shakerhood
    Southern Ohio
    Maybe phrasing it as lack of low end torque being the issue is wrong and more of the tune causing that dead spot and then a surge, several guys have almost been in an accident trying to cross traffic and have that dead spot hit.
  10. Jul 16, 2017 at 7:29 PM
    #5350
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    It's weird in this truck, you can shift perfect but if you end up too low in the rpm range, even say in 2nd, and hit the gas the power delivery seems like a sine wave and bucks the truck back and forth until RPMs get maybe above 2500 or so. And we aren't talking about lugging the engine low RPM.
    Maybe that's what is being referred to? I'm not sure.
    shakerhood likes this.
  11. Jul 16, 2017 at 8:04 PM
    #5351
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    They appear to be installed correctly. I've put 20000 or so hard miles on them. Be strange of an improper install would show up after that many miles bit it's possible.
  12. Jul 16, 2017 at 8:08 PM
    #5352
    nevadabugle
    Elko, NV
    Hmm...i wish there was a good way for me to determine if it was this or the cab mounts. I crawled under there tonight and there was nothing obvious. This front cab mounts are pretty well hidden. My dealership in Elko blows so I'm sure they will blame it on my 5100s or tires. Bottom line is I need to get this diagnosed or atleast documented soon. I have 33500 on the truck and that warranty is about to expire. Shit.
  13. Jul 16, 2017 at 8:17 PM
    #5353
    aero90
    The front most cab mounts support the radiator core. Grab a hold of something solid and pull up and push down. Or open your hood and start pushing down hard in that area to see if you hear anything. It might be tough to capture if the rest of them are good and it's only one bad one. When most of the body mount bushings went bad on my last truck, you could hear that thing creaking and clunking from down the street.
  14. Jul 16, 2017 at 8:18 PM
    #5354
    VolcomTacoma
    Jeff
    NorCal
    Might just be a blown up shock
  15. Jul 16, 2017 at 8:24 PM
    #5355
    nevadabugle
    Elko, NV
    samiam likes this.
  16. Jul 16, 2017 at 8:25 PM
    #5356
    nevadabugle
    Elko, NV
    I did blow both my rear 5100s already...:burnrubber: replaced with icons and so far so good.
  17. Jul 16, 2017 at 10:03 PM
    #5357
    VolcomTacoma
    Jeff
    NorCal
    I actually think one of my shocks up front might be blown or lost its pressure, I've got a clunk as well. Could just be uniballs are shite though. Well see when I replace the uniballs this week. Shocks are due for a rebuild anyhoo.
  18. Jul 17, 2017 at 7:33 AM
    #5358
    su.b.rat
    su.b.rat broken truck
    honestly I've gotten you two guys confused more than once. lol
  19. Jul 17, 2017 at 9:13 AM
    #5359
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    So I def. have that small dead spot but is more of just a fraction of a second hesitation and if I'm jamming the pedal it doesn't seem to drop off it just powers right through it. Is yours more defined. Also. Does anyone know if the auto tranny guys have this dead spot hesitation thing going? It doesn't happen during or after a shift but just cruising along while Rpms are increasing. Doesn't seem to be a drive by wire slow response. Just curious if we are all affected.
  20. Jul 17, 2017 at 9:14 AM
    #5360
    JARStacoma
    Alaska
    This was the quote I was referring to. Oops.
