Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 11, 2017 at 8:41 PM
    #5601
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2015 Tacoma had the Clutch catch all the way up at the top of the pedal travel which made it a bit of a pain, my 17 is a little bit lower making it much easier and the location of Reverse is no big deal.
    su.b.rat likes this.
  2. Aug 11, 2017 at 10:44 PM
    #5602
    Aw1985
    Aw1985 Member
    Alex
    Colorado springs
    2013 4Runner
    Hey guys-
    Just got stationed in Alaska. Have a 2017 TRD Pro with manual.
    I'm in Fairbanks, and temps get as low as -50. I've added the block warmer and battery blanket.
    I was wondering about the antifreeze and clutch fluid. Should I have to worry about the freeze point?
    My other buddies that have Tacomas up here said their trucks did fine.
    Appreciate the help!
    Alex
  3. Aug 12, 2017 at 8:42 AM
    #5603
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Sounds like your truck should do fine if you follow what they do.
    shakerhood likes this.
  4. Aug 13, 2017 at 8:31 PM
    #5604
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    So I changed my tranny fluid to redline mt90. Ran it for a day and was super smooth. Then today all gears were pretty notch and worse than before my change. I filled all the way up so that it dribbled out so pretty sure I'm good there but curious why this would happen? Was smooth prior to change then smoother after. Now pretty clunky all the way through. ??
  5. Aug 13, 2017 at 8:50 PM
    #5605
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Fresh lube feels great. The longer and harder you drive the drier it gets? True for many things in life...
    samiam likes this.
  6. Aug 13, 2017 at 9:29 PM
    #5606
    shakerhood
    Southern Ohio
    Back when I had my 2000 Tacoma I put Amsoil in the Transmission and it got harder to shift, would not go in 2nd gear when it was cold. I swapped back to regular old gear oil and it was fine again.
  7. Aug 13, 2017 at 10:07 PM
    #5607
    JARStacoma
    Alaska
    Hmmm. Two days and you lose viscosity??
    thanx. Maybe I'll have to switch back. Bummer.
    shakerhood[QUOTED] likes this.
  8. Aug 14, 2017 at 3:14 AM
    #5608
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
  9. Aug 17, 2017 at 8:52 AM
    #5609
    elistan
    elistan Active Member
    2017 TRD OffRoad V6 manual.
    Another manual fan here.
    Old truck is an S-Runner, which only came in a manual. New truck is a TRD OffRoad manual. I've heard that the AT learns and improves over time, but disliked it so much during the test drive that I just couldn't bring myself to get one.
    I know the AT models have multiple-terrain select and crawl control, while the MT has A-Trac... I'm interested in any off-road driving tips as that's something I'm new to, and what exactly from a mechanical point of view do the various modes do. The owner's manual isn't especially clear.
    BlakeM, shakerhood and Misfit like this.
  10. Aug 17, 2017 at 9:00 AM
    #5610
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This kind member came up with a good explanation. Happy reading:
    https://www.tacomaworld.com/threads...ntrols-trac-auto-lsd-trac-off-vsc-off.464400/
  11. Aug 17, 2017 at 9:11 AM
    #5611
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    I hated the stock set up and went with the short throw shifter from urd. My own shift boot heavy skull shift knob. and custom pedals.
    nevadabugle[OP] and TeecoTaco like this.
  12. Aug 17, 2017 at 12:56 PM
    #5612
    su.b.rat
    su.b.rat broken truck
    correct. sorry, just saw this post.
    MOC221_[QUOTED] likes this.
  13. Aug 17, 2017 at 1:02 PM
    #5613
    su.b.rat
    this is indeed a great post.
    but if you're looking for a short and probably oversimplified answer regarding the difference between the AT's CC and the MT's ATRAC, you could say that the CC system is brake/throttle automated, you just steer, while the ATRAC does most of the same brake modulation stuff but does not automate the throttle like CC does.
    if you've never used the CC system it's freaky... you take both feet off the pedals for it to do its thing. you only control the wheel. and that shit can work well, too.
    but I'll take the MT any day, of course.
  14. Aug 17, 2017 at 1:04 PM
    #5614
    su.b.rat
    so let's see the boot & knob pic!
    TeecoTaco likes this.
  15. Aug 17, 2017 at 1:33 PM
    #5615
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Indeed...I do like those pedals. I'm with St. Germain, looks sweet so far...but show us your knob!!!
  16. Aug 17, 2017 at 2:05 PM
    #5616
    akTacoBlanco
    akTacoBlanco Well-Known Member
    Omaha, NE
    2017 White Tacoma TRD Off Road M/T
    Stock.
    Ohh yeah lets see that nice knob of yours!
  17. Aug 17, 2017 at 2:24 PM
    #5617
    MOC221_
    Frank
    No worries, I was being lazy anyhow.. verified thread size and ordered a custom knob!
    su.b.rat[QUOTED] likes this.
  18. Aug 17, 2017 at 2:46 PM
    #5618
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    CC is crawl control?
    1st + 4Lo has worked well for me.
  19. Aug 17, 2017 at 4:07 PM
    #5619
    su.b.rat
    yeah crawl control.
  20. Aug 17, 2017 at 9:37 PM
    #5620
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
