Manual Transmission Fluid Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nad, Sep 23, 2009.
  1. Sep 23, 2009 at 11:30 AM
    nad
    nad [OP] mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I am wondering if someone has done a write up on changing the fluid in a manual 4.0l. I looked but could not find.
  2. Sep 23, 2009 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its very similar to the diff's. Drain and fill.
  3. Sep 23, 2009 at 11:32 AM
    nad
    Jordan
    Canada
    wow that was fast, idk where to drain and where to fill and I dont know what to use for oil
  4. Sep 23, 2009 at 11:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    75-90 works well.
    API GL-4 or GL-5
    2 Quarts. (or 2.7 if you have the 5 speed)
  5. Sep 23, 2009 at 11:41 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The drain plug is on the bottom towards the rear, the fill plug is on the left side towards the front.
  6. Sep 23, 2009 at 11:53 AM
    nad
    Jordan
    Canada
    what brand of oil would you guys recommend?, and is this something that should be very easy to do?
  7. Sep 23, 2009 at 12:02 PM
    nad
    Jordan
    Canada
    I heard that there is some synthetic brand that everyone raves about and makes for smoother shifting, but I cant remember what it was.
  8. Sep 23, 2009 at 12:19 PM
    nad
    Jordan
    Canada
    well thanks for all the info you guys have given me so far I appreciate it.
  9. Sep 23, 2009 at 12:53 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Redline MT90.
    FJBub and scottalot like this.
  10. Sep 23, 2009 at 1:04 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
  11. Sep 23, 2009 at 1:07 PM
    nad
    Jordan
    Canada
    awesome thanks guys, so redline mt-90 and a pump to get it in there, now do I want to use two quarts exactly?
  12. Sep 23, 2009 at 1:09 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Heres what i posted last week. Couple Qts of your preferred 75w-90. You'll need a cheap pump and hose to refill and a 24mm socket (If I remember correctly). Loosen filler plug on mid section of tranny facing drivers side. Loosen drain plug on bottom of tranny. Drain. Tighten drain plug. pump in oil. Tighten fill plug. Open beer.
    Silvertaco 603 and tacopashka like this.
  13. Sep 23, 2009 at 1:11 PM
    nad
    Jordan
    Canada
    thanks, I like the ending, so two quarts exactly or just till it start spilling out? and is the fill accessible from under the hood or under the vehicle?
  14. Sep 23, 2009 at 1:16 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    1.9 quarts. If you have a torque wrench, torque the plugs to 27 ft lbs.
  15. Sep 23, 2009 at 4:22 PM
    nad
    Jordan
    Canada
    well i just checked and they dont sell redline or amsoil anywhere in the city I live in, GoD DamN! Im gonna c if I can order some from somewhere.
  16. Jan 4, 2010 at 5:17 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    For those who have done it, did two quarts cover the fill well enough? I'm looking at doing mine here soon.
    The manual says it takes 1.9 quarts. I have 2 quarts of MT90, and I also have some Red Line 75W-90NS. I'd just like to know if 2 quarts of MT90 will definitely cut it, or will I end up short? I can put in a little 75W-90NS if I'm just a bit short I suppose?
  17. Jan 4, 2010 at 5:18 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    how much is redline mt 90 for you guys? at my local store it's $20, such bs for some damn oil
  18. Jan 4, 2010 at 5:26 PM
    ryanf
    ryanf Well-Known Member
    NY
    06 AC 4X4 6cly/6spd TRD-OR
    Rain Visors,
    I ran just run of the mill synthetic, cost me like $6/qt. That was 10K and no issues what so ever, I change mine every 25K, you don't have too, but in case there is water or contamination it doesnt hurt, change rear diff at the same time.
    @ 52K and need to do trans case and front diff, but that will get done in spring when im under there spraying my frame with bedliner.
    It's super easy tho.
  19. Jan 4, 2010 at 5:32 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    redline vs amsoil?
    any opinions?
  20. Jan 4, 2010 at 8:23 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Either way its a GL-4 which is good for brass syncro's...both are similar in price, and both get good reviews. AWD turbo crowd tends to favor Redline for transmission oil, I have seen some guys post good reviews of Amsoil's MTG. Personally in my 6MT I will use MT90 just cause I had great results with it over 50k miles @ 315hp/330tq (EVO RS).
    If you go Amsoil and plan on using their engine oil become preferred customer for the discount.
