Manual Transmission Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TGCRVT, Jul 21, 2016.
  1. Jul 21, 2016 at 3:16 PM
    TGCRVT
    TGCRVT [OP] Member
    2007 Tacoma 4.0l Manual
    I'm going to change the transmission fluid and the differential fluid. Toyota parts dept. won't tell me what to use. Anyone know what manual tranny fluid and gear oil to use?
  2. Jul 21, 2016 at 3:25 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Owner's manual is great for that kind of information.
  3. Jul 21, 2016 at 3:43 PM
    Pigpen
    Dan
    Northwest Montana
    What I use (as well as many others) is Mobil 1 full synthetic in the diffs and Redline MT 90 in the Tranny and t case. Does your rear have the true LSD? You can run the Mobil 1 with LSD additive either way.
    Nessmuk likes this.
  4. Jul 21, 2016 at 3:53 PM
    Btorquer
    Btorquer Member
    Paul
    2013 4WD Manual Transmission
    Pigpen likes this.
  5. Jul 21, 2016 at 4:09 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm happy with Severe Gear 75W-90 in the transmission, transfer case, and both differentials.
  6. Jul 22, 2016 at 2:25 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I use Redline MT90 in the transmission and standard Redline GL-5 in the transfer case and diffs. Weight is 75W90 in all places.
  7. Jul 22, 2016 at 2:41 PM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    Amsoil website will give you a list of every fluid your truck takes. Just fill out year and model
  8. Jan 31, 2020 at 7:20 AM
    flynonh2o
    flynonh2o Member
  9. Jan 31, 2020 at 10:05 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Just enter your vehicle information, and it will tell you what's required:
    https://www.redlineoil.com/find-products-for-my-vehicle
    My 2008 Tacoma requires MT-90 75W90 GL-4 in the transmission, and 75W90 GL-5 in the diff. The Diff requires GL-5 because Toyota installed a "clutch type" LSD in the 2005-2008 Tacomas.
  10. Jan 31, 2020 at 1:23 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    GL4 in trannie...........Redline MT90
    GL5 in diffs..........correct me if wrong
  11. Jan 31, 2020 at 1:32 PM
    badger
    badger Well-Known Member
    07 SR5
    This
    GL5 is for hypoid gears. I like Redline's 75-110w for the rear diff. Not as fussy about the front. Any good 75-90 GL5. I have not tried the Ford fluid in the tranny. It may be great. I do know the Redline MT90 works great. I've been running that for years.
  12. Jan 31, 2020 at 2:55 PM
    Armed in Utah
    2003 Lexus LX 470
    my MT Taco with Redline MT90 makes 'er shift smooth as snot
    C41n likes this.
