Manual transmission gear oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by mycogn, Dec 30, 2018.
  1. Dec 30, 2018 at 4:18 PM
    mycogn
    mycogn [OP] New Member
    1999 Tacoma
    My 99 Tacoma has developed a leak that appears to be coming from the rear seal of the transmission just before the drive shaft. What's got me puzzled is that the fluid is clear in color. Is this the normal color for the gear oil? Could it be something else, or am I missing something here?
  2. Dec 30, 2018 at 4:19 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes it's clear maybe slightly yellow.
  3. Dec 30, 2018 at 4:19 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If it's clean it is pretty well clear, more golden colored when there's lots of it. Requires 75W-90 GL4 gear oil
  4. Dec 31, 2018 at 12:43 PM
    mycogn
    1999 Tacoma
    Thanks. How difficult a project is it to replace the seal? I'm assuming drain the transmission, remove the drive shaft, work the old seal out and replace with new. Just don't know the difficulty of removing the old seal...
