Manual Transmission Getting Stuck in Gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by motomaster132003, Feb 9, 2016.
Does your 2016 Toyota Tacoma 3.5L 6sp Manual become difficult to shift out of gear on longer drives?
  1. Yes
    30.0%
  2. No
    70.0%
  1. Feb 13, 2016 at 10:16 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Very strange. Maybe the throw out bearing has an issue??
    At any rate this sounds like it's going to take awhile to resolve and get complicated because they'll try all the simple easy fixxes first. And will require a few back and forth trips to dealer.
    Remember to be cool calm and collected when working with the service team and I'm sure they'll diagnose and fix the issue and warranty it.
  2. Feb 13, 2016 at 10:30 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    @motomaster132003, you shouldn't change the transmission oil, it might give the dealer an excuse to deny warranty coverage. With the problem being intermittent and happening in almost every speed, I wonder if there's a problem with the master or slave cylinder. Does the clutch pedal feel different when the transmission won't come out of gear? I used to have a Subaru wagon that had a hard time shifting after a drive on the highway and the problem turned out to be the master cylinder leaking internally.
    stealthmode likes this.
  3. Feb 13, 2016 at 11:16 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    26xx
    It did it again just last night after being in cruise control in 6th gear for a bit at 80mph
  4. Feb 13, 2016 at 11:54 AM
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    Over 4K no issues with my manual...good luck OP.
  5. Feb 13, 2016 at 6:37 PM
    motomaster132003
    motomaster132003 [OP] Well-Known Member
    2016 Tacoma TRD OR DCSB
    It didn't do it yesterday, but did it once today in 4th and 5th. I seems like it's slightly less difficult to get it out of gear when it sticks if I really push the clutch pedal into the floor. I have a good amount of free play in the clutch, so I'm thinking about taking a few mm of free play out just to see if it makes a difference. The master is still full, so it doesn't seem to have a leak, and the clutch pedal feels consistent.
  6. Feb 13, 2016 at 6:46 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Subd. I don't have this issue on mine with 5000 miles. But I am interested to see if it occurs with others trucks.
  7. Feb 28, 2016 at 1:53 PM
    motomaster132003
    Please see original post. I added a video, and have also taken the truck into the dealer.
  8. Feb 28, 2016 at 2:23 PM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    Try pushing the clutch twice when it happens. If it then comes out you can likely conclude it is an issue with the master or slave.
    DaveInDenver likes this.
  9. Feb 28, 2016 at 2:25 PM
    AFMurse2014
    Devin
    San Antonio
    No change
  10. Feb 28, 2016 at 2:26 PM
    AFMurse2014
    Devin
    San Antonio
    OP. I watched your video, exact problem I have
  11. Feb 28, 2016 at 2:28 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    This looks to be a synchronizer issue. Had a R151 that did this after a rebuild had to disassemble it and use valve lapping compound to dress the synchronizers and the problem was solved. Hope the dealer service can get your issue resolved.
    Try floating the gears through the up and down shifts. Some call this rev matching. only use the clutch to start off from stop. This will force the synchronizers to do their job.
    Ugly Betty and stealthmode like this.
  12. Feb 28, 2016 at 2:40 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Sucks Toyota is not fixing their errors. My 1st gen is around 190K on the original clutch. No issues shifting after swapping out the old slave and master.
  13. Feb 28, 2016 at 2:48 PM
    AFMurse2014
    Devin
    San Antonio
    I double clutch but it doesn't help. I'd rather not straight shift (no clutch) with the carbon /composite synchros this thing has.
    If it had trouble going into gear I'd say synchros.. But it's trouble getting out of gear.
  14. Feb 28, 2016 at 3:16 PM
    RedBeard1
    Red
    Seriously your issue is most likely the synchronizers. If it will up and down shift "straight shifting" it with out hanging into gear then that is your issue. Shifting that way takes the pressure off of the hub spline locks and allows them to come out easier. The pic above is strait out of Toyota's transmission trouble shooting manual just to illustrate the part I am talking about. Give it a try floating up and down through the gears it is under warranty.
  15. Feb 28, 2016 at 3:34 PM
    #35
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Auto Trans FTMFW
    nv529 likes this.
  16. Feb 28, 2016 at 4:06 PM
    #36
    motomaster132003
    Have tried Rev matching the down shifts, and it still does it. Double clutching doesn't help either.
    RedBeard1 likes this.
  17. Feb 28, 2016 at 4:08 PM
    #37
    motomaster132003
    The weird thing is that you have to leave it in the same gear for a few minutes at minimum. If you shift from 6th to 5th to 4th to 5th to 6th, etc every 1 minute or so between shifts it will never stick.
    Wampa likes this.
  18. Feb 28, 2016 at 4:11 PM
    #38
    RedBeard1
    Red
    Checked the fluid level? They have been under filling the autos maybe they are doing it on the manuals too.... Lol
    James_Bond likes this.
  19. Feb 28, 2016 at 4:12 PM
    #39
    motomaster132003
    I checked the level before taking it in, and it was full. The dealer checked the level as well, and confirmed that it's full.
  20. Feb 28, 2016 at 5:23 PM
    #40
    gearcruncher
    Canadain bumper technician
    When I get a chance I will do a write up on the 2016 manual transmissions . Haven't had much time lately to research the new manuals as most of my time has been tied up with the low fluid in the auto
    Give me a day or two .
    Sticking in gear sounds like the transmission is still under load while you are downshifting .
    This would make it difficult to move the shifter .
    Do you guys know if the injectors are turning off when you decelerate ?
    Wondering if its got something to do with the atkinson cycle ?
    jpb2 likes this.
