Manual Transmission Getting Stuck in Gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by motomaster132003, Feb 9, 2016.
Does your 2016 Toyota Tacoma 3.5L 6sp Manual become difficult to shift out of gear on longer drives?
  1. Yes
    30.0%
  2. No
    70.0%
  1. Feb 28, 2016 at 5:32 PM
    #41
    motomaster132003
    motomaster132003 [OP] Well-Known Member
    2016 Tacoma TRD OR DCSB
    Good thoughts, but at 75mph, I can put in the clutch, let the RPMs drop to idle before a downshift, and it doesn't make a difference. It will still be just as difficult to shift. I have also reved the engine to 3.5 - 4.5K RPM to to see if that would make a difference, and that doesn't seem to make a difference either.
    The only real constant variable that I have is that the truck must be in the same gear for an extended period of time for the next shift to become difficult.
    Also, the longer you have been driving for, and the higher the rate of speed you are traveling at slowly brings up the percentage rate of the transmission becoming difficult to shift up to 100%.
    If neither of these variables occur, it will rarely become difficult to shift.
    MaineTaco16, stealthmode and Wampa like this.
  2. Feb 28, 2016 at 6:35 PM
    #42
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Exactly what he said..
    If I use cruise control, I can pretty much expect a stiff shift.
    No matter what kind of fancy foot work, rpms, or "floating gears"/straight shifting changes it...
    With the clutch pushed it's hard tonget out of gear... Can't imagine how much more difficult it would be without the clutch
  3. Feb 28, 2016 at 7:00 PM
    #43
    motomaster132003
    I have shifted out of gear without using the clutch in 6th to see the difference, and honestly it's very similar to shifting with the clutch in when the gear is sticking.
  4. Feb 28, 2016 at 7:43 PM
    #44
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Haven't had this issue, but the synchros in mine are still a bit notchy (4500km).
    Someone mentioned the slave cylinder possibly leaking earlier in this thread, and I assume that meant the clutch not fully disengaging when pressing the pedal ...
    Question - wouldn't that be even more noticeable when you're trying to put the tranny into a gear (grinding?). Unless of course you have exactly matched the revs.
    Hmmm
  5. Feb 29, 2016 at 4:36 AM
    #45
    motomaster132003
    I wouldn't think a leaking clutch, or a clutch with air in the line could be able to cause gears to stick, but not cause gears to grind. I also feel like when the gears stick, the next gear that I shift into feels notchy (slight grind). It could just be that I have to apply so much pressure to get it out of gear, that it rams into the next gear, and doesn't let the syncros do the work.
  6. Feb 29, 2016 at 10:06 AM
    #46
    drzplease
    drzplease New Member
    2016 Tacoma TRD ORDC
    Just joined this forum after finding this thread on google.
    Mine is doing this same thing, and I don't want to take it to a dealer without it doing it more often then "occasionally" as well.
    Anyone having any luck on a cause for this?
    Nunya Bizness likes this.
  7. Feb 29, 2016 at 10:13 AM
    #47
    Doug007
    Doug007 Well-Known Member
    Doug
    Houston, TX
    '16 TRD Off-Road M/T
    When I approach a stop light I generally put the transmission into neutral without the clutch just with light pressure on the shifter as I take my foot off the gas.
    The clutch should have nothing to do with this. You should be able to pull it out of gear easily as you take your foot off the gas.
  8. Feb 29, 2016 at 10:27 AM
    #48
    motomaster132003
    That's what I would do with my 2001 Tacoma, but it's nearly impossible to do it with my 2016 unless you apply a lot of pressure for about 5-6 seconds. With my 2001, I could be rolling to a stop light and just tap the shifter with one finger and it would easily come out of gear, just as you described.
  9. Feb 29, 2016 at 10:30 AM
    #49
    motomaster132003
    No luck yet, but so far it seems like there are a total of 3 2016's on this forum with the same problem. When I said it did it "occasionally", that was before I started driving it on longer trips. Now on a 2 hour trip, it will start to do it 100% of the time about 40-50 minutes into the drive.
    MaineTaco16 likes this.
  10. Feb 29, 2016 at 11:57 AM
    #50
    drzplease
    Mine also does this on any extended freeway time in 5th or 6th gear mostly. Everytime its in gear longer then a few minutes at 60mph+ it will become hard to shift. Sometimes it requires quite a bit of force to get it out of gear, then by the time im in my lower gear I have to drop another gear just to make up for the extra loss of rpm.
    Also worth noting, this isn't something that slowly started happening. It was since 200 miles on the clock its been stiff. But as a mechanic myself, I know how intermittent problems, especially on lengthy warranty work, can be swept away.
  11. Feb 29, 2016 at 12:06 PM
    #51
    motomaster132003
    Sounds like we have the exact same problem then. Exactly, I have had this issue since day one as well. I was just hoping that it was just tight tolerances and that it would fix it self quickly, but definitely not the case! Are you going to take your truck into the dealer? Once a dealer is able to figure out the cause of the problem, it will hopefully be an easy fix for others that have this same problem.
    MaineTaco16 and snowmonkey like this.
  12. Feb 29, 2016 at 12:11 PM
    #52
    drzplease
    I didn't pay a lot of concern to it as well since it was brand new (granted none of my MT vehicles have ever had hard shifting), so I figured it may take some time to "break in." But, after I talked to my co worker with his TRD Sport with a MT, he said it was smooth all the time, no matter what.
    I will try my dealership and see what they can do, hopefully take it on a freeway and get it to replicate it, with or without me. I was kinda just going to wait and let a bunch trickle in so they can make a TSB or recall for a fix, which by the sounds of it, is bound to happen. Ill keep updating after I take it in.
  13. Feb 29, 2016 at 1:11 PM
    #53
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
  14. Feb 29, 2016 at 1:26 PM
    #54
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    The master cylinder can have air in the system and air will compress, unlike the fluids. If you wanted to look at fixing it yourself and for fairly cheap look at buying a mityvac. I had a T56 manual that came from the factory with air in the system.
    http://mityvac.com/
    Amazon sells them. basically you fit the rubber end on it, have someone press in the clutch and squeeze the handle a few times with the rubber end stuck to the hole in the master cylinder
  15. Feb 29, 2016 at 1:50 PM
    #55
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Call and get a case number with Toyota before you take it in and then corporate can track this issue better.
  16. Feb 29, 2016 at 2:05 PM
    #56
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    My Fiat 124 Sport Coupe got stuck in 5th gear once. I had to stop and pull it out with both hands. Never happened again, I don't know why it happened once.
  17. Feb 29, 2016 at 7:13 PM
    #57
    motomaster132003
    Thanks for the tip.
  18. Feb 29, 2016 at 8:55 PM
    #58
    gearcruncher
    Canadain bumper technician
    The 2nd to first downshift issue is a common complaint as you are slowing to a stop .
    It is called reverse power flow .
    When you decelerate , your rear differential actually drives the drive shaft which in turn drives the output shaft of the transmission .
    As you are slowing down , there is a load on the transmission preventing you from grabbing first gear .
    Pushing the clutch to the floor is not going to help . When you push the clutch to the floor , the engine is disconnected from powering the transmission , however , because the truck is rolling ,there is still a load on your transmission from the rear differential .
    To verify this , try rev matching the speed of the transmission with the speed of the rear tires . Your synchronizers should allow first gear this way.
    I still havnt come up with a fix for the sticky shifter in 6th gear . Working on it .
    nagorb, RedBeard1 and nevadabugle like this.
  19. Mar 1, 2016 at 4:48 AM
    #59
    motomaster132003
    Interesting. Thanks for the explanation about why first gear will only allow you to go in if you are traveling 10mph or less. However, in the last 2000 miles of driving the new truck I have realized that since the gearing is nice and low, I really don't need to use 1st gear to slow down, and that 2nd gear is more then adequate.
    I am looking forward to what you come up with about the shifter sticking. It will do it in 3rd, 4th, 5th, and 6th. It also did it once in 2nd gear when I was in 4 Low for an extended period of time climbing a steep section. If you need any additional information feel free to PM me or post your questions here.
    Last night I was on a back road in 5th gear at 50 mph, and it stuck really bad. After putting in the clutch and letting the rpms drop, it was like hitting a wall. While pushing on the shifter I would let the clutch out and then put the clutch back in to see if there was any difference in the resistance on the shifter. The resistance was the same, however with the clutch out I could feel, but not hear a slight grind through the shifter. As soon as I would put the clutch in to try to free up the shifter, the grind that I could feel would go away, so I'm not sure if that rules out a bad bleed job on the master and slave or not.
    Seems odd that I'm not able to just pop it out of 5th with the RPMs at idle without using the clutch without getting a grind.
  20. Mar 1, 2016 at 6:10 AM
    #60
    gearcruncher
    Just went through all the posts from the start of the thread .
    From your explanations , the most likely issue is a bad bleed , hydraulic clutch component issues .
    Your hydraulic clutch is not fully removing the powerflow from the engine . By the time you do manage to get the transmission shifter out of 6th , you are too late for a rev match to downshift to 5th gear and suffer the symptoms of reverse powerflow .
