Manual Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Dec 25, 2011.
  1. Dec 26, 2011 at 8:49 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    this stuff..seems as tho everyone raves about redline for manual trannys..expensive per quart but worth it if you ask me. learned all about it today when checking various oils and what not via google.
    http://www.redlineoil.com/product.aspx?pid=46&pcid=7
  2. Dec 26, 2011 at 8:50 PM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    I have always had good luck useing Redline mt-90 in Toyotas
  3. Dec 26, 2011 at 8:51 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    ok thanks for the info. DO they sell this stuff at OReilly's or SHucks??? DID you get your Gears fixed???
  4. Dec 26, 2011 at 8:53 PM
    MonkeyProof
    SoCal- SGV
    im sending out A 3RD tomorrow and gonna try order gears and trying to set them myself for the other..we'll see
  5. Dec 26, 2011 at 8:56 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Go synthetic, has much better protection, and you can let it go a lot longer than normal gear oil.
    I used Amsoil Severe gear in 75w-90 and it was amazing how much it smoothed out the tranny and T-case. I ended up putting Mobile 1 in the Diffs because Napa was closed...any synthetic gear oil you use will end up serving you just fine.
  6. Dec 26, 2011 at 8:56 PM
    RockRescue
    Oregon
    2007 TRD Sport
    Napa should have Redline . Not to go off topic But Monkey Have you thought about haveing your Gears Cryoed From Longfield ?
  7. Dec 26, 2011 at 8:57 PM
    Manwithoutaplan
    ID
    ahh so you leaping around in 4wd drive :D j/k
  8. Dec 26, 2011 at 8:57 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Some feel synthetic is too "slippery" causing notchy shifting. That's why the MT-90 is supposedly good, syn and not notchy.
    I have valvoline syn in mine. I like it fine.
    Syn or Dino depends on your preference and your wallet as well I'd expect.
  9. Dec 26, 2011 at 8:59 PM
    Manwithoutaplan
    ID
    dont mind spending little more coin for my transmission.
  10. Dec 26, 2011 at 9:01 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    MT-90 then :thumbsup:
  11. Dec 26, 2011 at 9:05 PM
    Manwithoutaplan
    ID
    i was looking into that with the local autoparts store. Does walmart have this stuff??
  12. Dec 26, 2011 at 9:07 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  13. Dec 26, 2011 at 9:08 PM
    RockRescue
    Oregon
    2007 TRD Sport
    I have never seen it at Walmart . Redline is kinda like Amsoil not everyone carries it . Any performance shop should have it .
  14. Dec 26, 2011 at 9:12 PM
    MonkeyProof
    SoCal- SGV
    i thought about it:p..to take the ring gear off of the carrier and then slap everything back together. and just drive around front wheel drive..but i dont want to burn out the bearings since i doubt there will be enough gear oil splashing around to properly lube the pinion bearing. maybe a quick trail fix to get off the trail.
    quick little story,...this was a few years ago.
    we were on a hard technical trail up north, it was a trrail that we should not have been on in the first place being IFS. my buddy busted his rear on his FJ..took us well over 18+ hours to get back to the main highway. brandonh, dtrujillo63, and myself took turns pulling him while strapped daisychain style to get him out. if i knew back then what i know now..i would have taking the 3rd apart to get the ring gear off and put everything back together without the ring gear. he couldnt go over 10mph without making to much bind in the driveline. all the broken pieces kept getting caught up inside and was binding..making LOUD clunks, clangs, pings.. every noise imaginable coming from inside the axle housing. such an epic journey!:D
  15. Dec 26, 2011 at 9:17 PM
    #35
    Manwithoutaplan
    ID
    dang. I will have to remeber that for future off roading trip.
  16. Jan 3, 2012 at 11:51 AM
    #36
    Manwithoutaplan
    ID
    man what a pain in the ass to get the oil back in :facepalm:
  17. Jan 3, 2012 at 12:04 PM
    #37
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    hand pump
  18. Jan 3, 2012 at 1:36 PM
    #38
    Manwithoutaplan
    ID
    like a penis pump :D
  19. Jan 3, 2012 at 1:47 PM
    #39
    Manwithoutaplan
    ID
    little late
  20. Jan 3, 2012 at 1:54 PM
    #40
    Manwithoutaplan
    ID
