Manual Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Dec 25, 2011.
  1. Jan 3, 2012 at 1:54 PM
    #41
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    what oil did you end up using
  2. Jan 3, 2012 at 4:48 PM
    #42
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Fixed
  3. Jan 3, 2012 at 5:54 PM
    #43
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    I ended up using http://www.schaefferoil.com/ (293 supreme gear lube synthetic plus gear lube 75w-90). Because i was in a farming community their wasnt much to choose from.
  4. Jan 3, 2012 at 6:19 PM
    #44
    saugus
    saugus Well-Known Member
    Did you replace the crush washers and not over torque them? They don't need much.
  5. Jan 3, 2012 at 8:13 PM
    #45
    MonkeyProof
    SoCal- SGV
  6. Jan 3, 2012 at 11:43 PM
    #46
    Manwithoutaplan
    ID
    No but I got to drive the combine
  7. Jan 8, 2012 at 5:28 PM
    #47
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Never changed my tranny oil on my own. Searched around on here and only found auto tranny DIY. Is it the same? If not can someone point me to a DIY?
    Planning on using redline mt-90.
    Thanks in advance guys!
  8. Jan 8, 2012 at 6:45 PM
    #48
    Manwithoutaplan
    ID
    That is what this thread is for it easy to empty but pain to put it, back in. make sure you have a pump, to get the oi back in.
  9. Jan 8, 2012 at 7:09 PM
    #49
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yeah, I'm going to try to get over to the auto store or home depot or something to grab a pump and some hose. Is the change same as the auto tranny or is it slightly different??
    Thanks!!
  10. Jan 8, 2012 at 8:39 PM
    #50
    Manwithoutaplan
    ID
    i believe so. Just make sure you dont trq down the bolt to much. IF you want i can take pictures of the fill plug and drain plug on the manual transmission. [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]
    [/FONT]
    [/FONT]
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold][/FONT][/FONT]
  11. Jan 8, 2012 at 8:45 PM
    #51
    Manwithoutaplan
    ID
  12. Jan 8, 2012 at 8:53 PM
    #52
    IndianTaco
    IndianTaco Well-Known Member
    case 7120 thats a great combine!
  13. Jan 8, 2012 at 8:55 PM
    #53
    Manwithoutaplan
    ID
  14. Jan 8, 2012 at 9:05 PM
    #54
    Manwithoutaplan
    ID
    i wonder what kinda of gear oil that uses :D
  15. Jan 8, 2012 at 9:22 PM
    #55
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    It's a simple drain and fill until oil comes out of the fill hole. :cool:
  16. Jan 8, 2012 at 9:23 PM
    #56
    Manwithoutaplan
    ID
    exactly
  17. Jan 8, 2012 at 9:36 PM
    #57
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yeah I wouldn't mind that man, if you have a chance that would be greatly appreciated! Thank you very much for the help
  18. Jan 8, 2012 at 9:40 PM
    #58
    Manwithoutaplan
    ID
    will do. I will get them tommorrow.
  19. Jan 8, 2012 at 10:47 PM
    #59
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Excellent, thank you so much!!
  20. Jan 8, 2012 at 11:08 PM
    #60
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
