Manual Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Dec 25, 2011.
  1. Feb 5, 2012 at 2:58 PM
    #81
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    What size sockets do I need?
  2. Feb 5, 2012 at 3:31 PM
    #82
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I used a 15/16 box end, it fits almost exactly (actually better than) the 24mm metric size.
  3. Feb 5, 2012 at 3:47 PM
    #83
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Redline MT-90 [​IMG]Next.
  4. Feb 26, 2012 at 9:11 PM
    #84
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    Can u use redline in ur tranfser case and diffs.
  5. Feb 26, 2012 at 9:28 PM
    #85
    badger
    badger Well-Known Member
    07 SR5
    Redline makes specific lubricants for transmissions and differentials. The MT-90 can be used in the Tcase, but not the diffs. They sell another oil for that.
    Mt-90 or one of their other transmission oils is the only thing that should go in the transmission. It's not a matter of lubrication quality. There are other good oils, but nothing makes these trannies shift as well as Redline. I would use the MT -90 unless you see temps well below zero. Then one of the lighter options they have might be better.
  6. Feb 26, 2012 at 9:38 PM
    #86
    Manwithoutaplan
    ID
    Ok well 0 degrees is not a problem where I live.
  7. Feb 27, 2012 at 8:54 AM
    #87
    Manwithoutaplan
    ID
    Ok cool thx for the respond so man.
  8. Oct 7, 2012 at 6:05 PM
    #88
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Can I use the same Pump that I used for the differential fluid 75-90? Or should I buy a new one?
  9. Oct 7, 2012 at 7:11 PM
    #89
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    I used the same pump.. Can't see any harm in using what little is left in the hose.
  10. Oct 7, 2012 at 8:17 PM
    #90
    badger
    07 SR5
    It's fine, just pump the remaining diff oil out. The Redline bottles though have a very small neck. Most of the pumps you find won't thread onto it. they still work, but they are a little clumsy because they are just sitting in the bottle.
  11. Oct 10, 2012 at 11:18 PM
    #91
    Drunknsloth
    Retribution
    South West
    So I tried doing the oil change, when I took out the fill plug, some fluid came out. Then I drained it.
    When I went to fill it back up, I was unable to get a full 1.8 quarts in that the manual recommends before fluid started coming out the fill hole. Is that okay, or should I jack up the driver side and add more fluid?
  12. Oct 10, 2012 at 11:38 PM
    #92
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Was it level with the fill hole? If so run it as is.
    You could run it a couple days and then pull the plug when it's cold and check it. Top it off if need be.
  13. Oct 10, 2012 at 11:40 PM
    #93
    Drunknsloth
    Retribution
    South West
    Yep, I'm just worried because there was a bunch of fluid that came out when I took out the fill plug, meaning it probably had the full 1.8 in there originally.
  14. Oct 10, 2012 at 11:44 PM
    #94
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You were on level ground right?
    How much of the 1.8 did it take?
    I'll assume you drained it warm?
    Could be it was hot and expanded, could be they overfilled it to begin with, could be you were on a slope, could be you didn't get it drained fully.
    I wouldn't worry about it if it took a decent amount, check it again when it's cold. If you only got a quart in there I'd be worried but I wouldn't stress if not.
    You checked with a flash light to see it was level with the fill hole?
  15. Oct 10, 2012 at 11:50 PM
    #95
    Drunknsloth
    Retribution
    South West
    I'd say maybe 1.6, I did drain it warm. I was pretty sure I drained it fully, I let it sit for a couple hours and my garage is pretty level. I did not use a flash light because I assumed that if it was coming out of the fill hole it was full.
    Yeah I'll probably check it in a couple days cold.
  16. Oct 10, 2012 at 11:59 PM
    #96
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    1.6 isn't something I'd be concerned about, but it'd be fine to check it in a few days, cold.
    It is good to look in the hole (if you can, sometimes you can't) just to make sure something isn't obstructing the fluid but at 1.6 I'm going to say it was full and not that something backed it up.
    Just my .02
  17. Oct 11, 2012 at 12:03 AM
    #97
    Drunknsloth
    Retribution
    South West
    Yeah, I'm probably just over thinking it. Looking through the hole might be hard since the steering shaft (if I remember correctly, I'm to lazy to go back out and check under the truck) and the exhaust is in the way.
  18. Oct 11, 2012 at 12:10 AM
    #98
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah, front driveline, you're right. At any rate stick your finger in the hole and feel, should be sitting right below the bottom edge of the hole. Could always use a mirror too.
  19. Oct 11, 2012 at 12:14 AM
    #99
    Drunknsloth
    Retribution
    South West
    Man, I must be tired, should have thought of the mirror, and of course it can't be the steering shaft... :facepalm:
  20. Oct 11, 2012 at 12:20 AM
    #100
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    :p
