Manual Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Manwithoutaplan, Dec 25, 2011.
  1. Aug 15, 2013 at 10:35 AM
    #101
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
  2. Feb 14, 2015 at 9:12 PM
    #102
    Pigpen
    Dan
    Northwest Montana
    Does MT 90 not work well in cold Climates? I'm not far from changing MT/ Tcase fluids
  3. Feb 15, 2015 at 8:21 AM
    #103
    Pigpen
    Dan
    Northwest Montana
    Weekend bump for MT 90 in cold climates
  4. Jul 28, 2018 at 10:22 PM
    #104
    biker666
    biker666 DisMember
    Oz
    Emerald City
    2007 5lug 2.7 AC 5MT RWD
    LED head, cabin and reverse lamps
    I am about to find out. Changing to RL MT90 from who knows what (2nd owner). It gets cold here too. From my experience, synthetic motor oil works very well in extreme cold, I am hoping the gear lube does as well.
    At The Helm likes this.
  5. Jul 28, 2018 at 10:31 PM
    #105
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    I’ve been running MT90 for two winters here in Northern Nevada, no issues at all.
  6. Jul 28, 2018 at 10:34 PM
    #106
    biker666
    biker666 DisMember
    Oz
    Emerald City
    Thanx for the confirmation, Morgan. :)
  7. Jul 29, 2018 at 6:00 AM
    #107
    Brewnmn
    Brewnmn Well-Known Member
    2014 4X4 Reg Cab
    I’m running Redline in the tranny, transfer case, and differentials up here in Minnesota. The MT-90 GL-4 in the transmission made a noticeable difference in shifting cold and warm. The huge improvement was putting the 75W-90 Gl-5 in the transfer case. With the stock oil I had that loud clunk when shifting into 4 wheel drive. Now with the Redline I can’t even tell it’s shifting. It’s so smooth I had to get under the truck to verify the transfer case engaged.
