Manwithoutaplan Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Manwithoutaplan, Jun 11, 2010.
  1. Apr 23, 2015 at 8:36 AM
    #4241
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I copied it from your sig. Not my fault if you can't abbreviate correctly.
  2. Apr 23, 2015 at 8:37 AM
    #4242
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    Ic an A. :notsure: if there something wrong with your copying skills.
  3. Apr 23, 2015 at 8:46 AM
    #4243
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Where is this missing a?
  4. Apr 23, 2015 at 8:48 AM
    #4244
    Manwithoutaplan
    ID
    you sneeky guy :spy:
  5. Apr 23, 2015 at 8:53 AM
    #4245
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  6. Apr 23, 2015 at 10:22 AM
    #4246
    2012tacolover
    2012tacolover Well-Known Member
    Norm
    CA/AL
    White PreRunner TRD Sport DCSB
    Tinted Windows, Black Nerf Bars, LED Dome & Map Lights, Snugtop Xtra-Vision, WeatherTech Digitalfit front and rear, trimmed Front Mud Flaps, BFG A/T KO's, Matt123 White Skid, Devil Horn Emblem Wet Okole front and rear seat covers! Future Stuff: Lift and new Wheels! :)
    Man your truck is looking sweet!
  7. Apr 23, 2015 at 10:26 AM
    #4247
    Manwithoutaplan
    ID
    yea getting ready for moab. Damn thing is freakin money pit right now :annoyed:
  8. Apr 23, 2015 at 10:31 AM
    #4248
    ThomasMore66
    Dallas/Fort Worth & Durango
    You need more lights.
  9. Apr 23, 2015 at 10:34 AM
    #4249
    Manwithoutaplan
    ID
    funny guy lol
  10. Apr 23, 2015 at 10:35 AM
    #4250
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Dude, awesome job! That is exactly what I want to do with mine, but I'm terrible at electrical and not really understanding exactly what you did. Can you elaborate please?
  11. Apr 23, 2015 at 10:38 AM
    #4251
    ThomasMore66
    I really like the looks of the 6" lift. But then I couldn't get in my parking garage at work or my garage at home. It would probably guarantee my 5' wife never rode with me.
  12. Apr 23, 2015 at 10:38 AM
    #4252
    Manwithoutaplan
    ID
    Okay, you need to go to an auto parts store and buy a realy like the one in the diagram. It's just a standard four prong relay. On the bottom of the relay, the posts will be numbered exactly like the one in the diagram.
    You will also need to buy a three position switch. The red wire in the diagram that goes to the "auto" position on the switch. is coming from the factory revers light wire. This wire will become "hot" (it will show 12 volts on a volt meter, or it will light up a test light) ONLY when the Jeep is in reverse and your back up lights are on.
    Next, you need to run a wire from the battery, thru a fuse, and then to the bottom position (ON) on your three place switch. You also need to run a separate fused wire from your battery to the #30 post on your relay.
    Next, run a wire from the middle pole on your switch to the #86 post on your relay. Now, run a wire from a good solid ground (from the - post on your battery, or from your frame, or from your engine block) to the #85 post on the relay.
    Now it's time to mount your lights. Mount them where ever you want to, and ground them to the frame. Run the power wire's to both lights (you can splice them together) to the #87 post on the relay.
    Now you're done! And it should work. When you place the switch in the middle position, the lights are off and won't come on. Place the switch in the "auto" position and the lights should come on whenever you place the transmission in reverse. You can also place the switch in the "on" position and have them on whenever you want to.
    23717d1165266382t-aux-reverse-light-wiri_469192386f3c30c82317f6d39e702063c75814f7.jpg
    Here is what i read from someone else post on a jeep site.
    I need to find a better switch though the one i have is pretty weak looking.
  13. Apr 23, 2015 at 10:38 AM
    #4253
    Manwithoutaplan
    ID
    Stay with a 3 inch lift. The 6 inch is pretty weak.
  14. Apr 23, 2015 at 10:41 AM
    #4254
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Its so weak he didnt even drive it at Hungry Valley!!! lolol jk, jk
  15. Apr 23, 2015 at 10:42 AM
    #4255
    Manwithoutaplan
    ID
    wow you had to go there. :p
  16. Apr 23, 2015 at 10:56 AM
    #4256
    Pistol Pete
    Eric
    Oklahoma
    Thanks! :thumbsup:
  17. Apr 23, 2015 at 10:58 AM
    #4257
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Hahahaha yup! I was bummed, I wanted a ride in it! Help see the potential of my little 4 banger. Also to see what the expensive suspension is all about! lol
  18. Apr 23, 2015 at 10:58 AM
    #4258
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I have Skygear's fuse panel with relays. I'll have to see how to go about doing this with that configuration.
  19. Apr 23, 2015 at 11:04 AM
    #4259
    Manwithoutaplan
    ID
    How come you did not buy Nathans NSA panel kit ?
  20. Apr 23, 2015 at 11:04 AM
    #4260
    Manwithoutaplan
    ID
    It is not that exciting.
