Map lights and Dome lights won’t go off
Discussion in 'MESO Customs' started by Tony77, Jun 20, 2021.
  1. Jan 9, 2022 at 11:04 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Join the club. Mine's still not fixed. The dealer wants my truck for a whole day to consult with Toyota Engineers to determine the issue. I showed them the Meso picture and offered the explanation known but my service writer seems a little slow.
    @Tony77 Hey, did your issue go through dealer diagnosis to track down the problem or did you just buy that console and threw it in? Dealer parts dept quoted me full retail at well over $500 but your route was just over $300 as you said. I'm trying to decide which avenue is more painless. I think buying the console is but I still have to go back because their "fixing" of my TPMS issue is no longer fixed. It lasted a day. o_O I don't have a lot of trust in this shop.
  2. Jan 9, 2022 at 5:27 PM
    Tony77
    Tony77 [OP] Well-Known Member
    Anthony
    NNJ
    2020 TRD OR 4X4
    I just bought the overhead console and installed. It seemed to me that Meso had a real handle on what happened, that the issue was in the overhead console with the shorting of the trace wire. I almost attempted his outlined repair but I was worried I would screw it up. I can solder copper plumbing lines but not much experience with electronics.
    GrizzledBastard likes this.
  3. Jan 9, 2022 at 7:46 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    @Tony77 Given my circumstances appear to be identical to yours, I'm thinking I may split the case and see if I can fix it. Worse case, I buy a console from Sparks or wherever I can get it on the cheap. Did you save yours? I'll buy it if you have it still and want to get rid of it. ;)
  4. Mar 6, 2022 at 11:52 AM
    Tony77
    Anthony
    NNJ
    2020 TRD OR 4X4
    How did you make out? Get it solved?
  5. Mar 22, 2022 at 12:11 PM
    BrokeKayaker
    BrokeKayaker Slava Ukrania!
    Ouachita Mountains
    2022 TRD OR DCLB Army Green
    Truck year/model in sig <---
    I think I may have this problem and I disconnected my battery first!
    1. disconnected battery
    2. installed new ultimate maps
    3. reattached battery, all good, maps light up!
    4. Disconnected battery again,
    5. replaced dome with dual color dome.
    6. Plugged battery back in, but dome won’t light.
    7. Disconnected battery again, and flipped dome connector.
    8. Plugged battery back in, still no light.
    Maps are still good.
    grab multimeter at this point.
    Tested resistance on fuse, good. Removed fuse, Maps go out. replace fuse, Maps turn back on. Dome still off, so fuse is good.
    I’m getting 3 ohms resistance on my old incandescent dome light, none from my New LED dome light. I’m also not measuring any voltage from the dome socket. The old incandescent dome light now will not light when in the socket.
    :confused::mad: Any ideas?
    UPDATE:
    I'm going to leave this up in case someone else runs into this. My rocker switch was in the middle position throughout this. I got an idea from reading this thread that maybe I need to change position. So I switched it over to "on" and measured voltage on the outlet again. Viola! current. So, next, I disco'd the battery and installed the dual dome again. Reconnected battery and bingo. Working fine now. Also working fine when the rocker is back in the middle now. LOL. Go figure.
    Hope this helps someone.
    MK_Taco likes this.
  6. Mar 22, 2022 at 1:10 PM
    Tony77
    Anthony
    NNJ
    2020 TRD OR 4X4
    Glad you solved it.
  7. Jun 26, 2022 at 12:16 PM
    comafern
    comafern New Member
    S. Carolina
    2022 Grey Tacoma SR5
    Is there a video anywhere of the overhead disassembly? Not removing from the truck but taking it apart to get to the circuit board.
    Thanks
  8. Jun 27, 2022 at 6:07 AM
    Tacospike
    Two Trucks
    For the Maps or dome? or both?
  9. Jun 27, 2022 at 7:15 AM
    comafern
    comafern New Member
    S. Carolina
    i just wanna take the overhead console assembly where the map lights go so I can get to the circuit board like @MESO shows in their post on this thread. I’m having trouble with the plastic welds and popping it open.
  10. Jun 28, 2022 at 10:36 AM
    Tacospike
    Two Trucks
    I haven't seen a video for that.
    But from the picture on the first page on those plastic welds, I would use a dremel. It worked great for me when I had to remove plastic welds from my Tundra (Different project). Using a blade might only cut the surface weld where there is more bond underneath that location.
  11. Jun 28, 2022 at 9:34 PM
    akmrk
    akmrk Member
    Anthony
    Davis, CA
    2021 Tacoma TRD OR 4x4
    Let's not talk about it
    I had a similar issue when I installed my meso map lights except the SOS button circuit got fried and I need a new overhead console. Does anyone know the part number for the overhead console with the sunroof buttons?
  12. Jun 29, 2022 at 6:24 AM
    Tacospike
    Two Trucks
    2020 TOYOTA TACOMA OVERHEAD ROOF CONSOLE BLACK SUNROOF Power Rear Back Glass | eBay
    I found this but when I tried looking up the PN on Google not much came up. Might be a start though
  13. Jun 29, 2022 at 6:46 PM
    akmrk
    akmrk Member
    Anthony
    Davis, CA
    Thanks for your help! I looked through some diagrams and the dealer confirmed the correct PN is 6365004160C0. This is the overhead console that has crawl control, locker switch, SOS, and moonroof controls if anyone else needs it.
    Tacospike[QUOTED] likes this.
  14. Mar 29, 2023 at 11:08 PM
    damotoy2021
    damotoy2021 Member
    Damien
    2021 toyota Tacoma
    I’m having a issue because I took out my dome light and some reason after I took out my dome light and it blew a fuse i replaced the fuse but now my dome switch doesn’t work and it stays on
  15. Mar 30, 2023 at 11:47 PM
    #35
    damotoy2021
    damotoy2021 Member
    Damien
    2021 toyota Tacoma
    Is the third cargo light connected to the dome light? I’m looking for a overhead console with no sunroof only the sos light
  16. Jan 27, 2024 at 6:25 PM
    #36
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    so I just installed the ultimate map lights and they are constantly on. The on/off/door switch works for the dome light still.
    would this still be the case for the fix. The map lights were working fine before installing the led map lights.
  17. Jan 29, 2024 at 7:34 PM
    #37
    2ski4life7
    Seattle WA
    okay I reinstalled the normal lights and they function fine.
    would this still mean the board is shorted? I can make this fix easy but it doesn’t make sense to me why it would be shorted if the normal bulbs operate fine?
  18. Feb 4, 2024 at 5:12 PM
    #38
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    This thread, and a few others talking about problems with LED swaps that don't involve the dome light, has convinced (scared) me into making a decision to never risk swapping the conventional bulbs with LEDs anywhere in the truck. I was really only considering changing the rediculous 1980's Dome light bulb: It's truly a joke. But it seems like it's literally a roll of the dice on whether you survive it or not. A possible $350 penalty on a new circuit board for swapping out a 50 cent bulb??
    I can live with the lame 10w OEM bulb. :pccoffee:
  19. Sep 9, 2025 at 8:34 AM
    #39
    loveysteeze
    loveysteeze Member
    Denzel
    2022 Lunar Rock Tacoma TRD Off-Road
    Hi there, having the same issue and thinking about just buying a new overhead console for $500. Pretty sure the circuit board in my overhead console is fried too because the lights stay on when my truck is off, and when the rocker is completely off only one of the lights stays on.
    Was it an easy swap, removing the old console and putting in the new one? Was everything working perfectly after install? Thanks in advance!
  20. Sep 10, 2025 at 3:40 AM
    #40
    Tony77
    Anthony
    NNJ
    2020 TRD OR 4X4
    It has been awhile since I did it but I don’t remember it being to difficult. Everything worked perfectly as soon as the board was replaced. All has been good with the Meso leds still working properly.
