Map lights not working
Discussion in 'Lighting' started by cheyhigashiguchi, Sep 7, 2021.
  1. Sep 7, 2021 at 11:02 PM
    cheyhigashiguchi
    cheyhigashiguchi [OP] Well-Known Member
    2002 double cab tacoma 4x4 conversion
    Hey guys need a little help here
    All of my interior lights work except for my map lights,I’ve recently had led lights in there but it stopped working so I tried to change it but nothing and samething with fuses all fuses are good. What else could be causing this problem?
  2. Sep 7, 2021 at 11:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Just to confirm, your door/dome light does work?
  3. Sep 7, 2021 at 11:12 PM
    cheyhigashiguchi
    yes correct
  4. Sep 7, 2021 at 11:21 PM
    TnShooter
    Deogee
    STOCK
    Ok, this should mean you have power from the Body ECU.
    Since it also powers the Dome/Door.
    The switch on the Map light provides a ground.
    Therefore, you have 2 options.
    Pull the plug at the map light and check for power.
    Or carefully probe the bulb socket for power. See if you have power to one of the terminals of the socket.
    If, so check to see of you have a good Ground with the switch in the ON position.
  5. Sep 7, 2021 at 11:32 PM
    cheyhigashiguchi
    alright will do tomorrow, if there is no power or ground,what does that mean
  6. Sep 7, 2021 at 11:38 PM
    TnShooter
    Deogee
    STOCK
    No power means there is a break or loss of connection in the wire between the dome and map light splice.
    No ground means the switch is bad. Or the ground for the switch is bad.
  7. Sep 7, 2021 at 11:49 PM
    cheyhigashiguchi
    alright thank you I’ll check all this tomorrow and update what happens
    TnShooter[QUOTED] likes this.
  8. Nov 14, 2021 at 4:59 PM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    I'm resurrecting this thread because I am having a similar problem.
    2015 DCSB.
    I removed the overhead console to install a Meso switch panel. When I put it all back together, the map lights no longer work; neither side.
    Both map lights were replaced with LEDs a couple years ago. The dome light works OK. I did doublecheck to see if I plugged in the wire connector above the roof console and it is connected.
    I had to do some cutting of the plastic with a Dremel tool and a small cordless saber saw. Could the excess vibrations have somehow damaged the LEDs? (Grasping at straws here).
    TIA.
  9. Nov 14, 2021 at 5:55 PM
    TnShooter
    Deogee
    STOCK
    I remember something like this.
    The guy said the connector was “dirty”.
    Check the White Wire for Power.
    And the White/Black for ground.
    See here for a great post that caribe makaira did on it.
    https://www.tacomaworld.com/threads/map-lights-come-go.693898/#post-24525750
  10. Nov 15, 2021 at 5:53 PM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I
    If I'm not mistaken, the three slots between the lights are the microphone for the Bluetooth connection to your phone, right?
  11. Nov 15, 2021 at 6:06 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    If you removed the LED bulbs at some point before the no work scenario, flip them around. The are polarity happy.
  12. Nov 15, 2021 at 7:28 PM
    TnShooter
    Deogee
    STOCK
    According to this post, Yes.
    That is the factory mic.
    https://www.tacomaworld.com/threads/factory-mic-help.371153/
    I have a 2007 model.
    It doesn’t have a mic.
  13. Nov 16, 2021 at 3:14 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Thanks. The dome light still works and since the map lights are on the same fuse, I know it's not the fuse.
    I'm pretty sure the mic works; I'll double check it later today.
    It's beginning to smell like the LED bulbs worked themselves loose when I was cutting on the console to install the Meso panel.
    When the weather warms up later today I'll have another look at it.
  14. Nov 16, 2021 at 3:14 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    I haven't touched them, but thanks.
  15. Nov 16, 2021 at 6:44 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    OK. I'm a dumbass. o_O
    I removed the console again and realized there are not one but TWO cables that needed to be reconnected. :facepalm:The Bluetooth mic cable was reconnected, but the map lights cable was not.
    They are both plugged in now and life is good.:yay:
    Tacospike likes this.
