Marketplace Rules
Discussion in 'Site Suggestions' started by T4RFTMFW, Sep 11, 2015.
Thread Status:
Not open for further replies.
  1. Sep 22, 2015 at 7:17 PM
    #61
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    if he can stick his helicopter up there they are clean?
  2. Sep 22, 2015 at 7:19 PM
    #62
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    In other news, how do you remove previous bumps?
  3. Sep 22, 2015 at 7:20 PM
    #63
    TeamSarcasm
    The better coast
    quote them saying [BUMP][/BUMP] and that will remove them.
  4. Sep 22, 2015 at 7:23 PM
    #64
    Josh828
    Josh
    Avery NC
  5. Sep 22, 2015 at 7:23 PM
    #65
    Josh828
    Josh
    Avery NC
    It didn't work :pray:
    T4RFTMFW[OP] likes this.
  6. Sep 22, 2015 at 7:29 PM
    #66
    Josh828
    Josh
    Avery NC
    Or it did work! I thought you could make the old bumps go away entirely....
    Or it didn't work and a mod worked some sorcery, lots of them floating around :spy:
  7. Sep 22, 2015 at 7:38 PM
    #67
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    sometimes they delete and ban on accident. :D
  8. Sep 22, 2015 at 7:53 PM
    #68
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Consult your Doctor.
    Josh828[QUOTED] and T4RFTMFW[OP] like this.
  9. Sep 22, 2015 at 7:54 PM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its never an "accident" :cool:
    T4RFTMFW[QUOTED][OP] likes this.
  10. Sep 23, 2015 at 2:12 AM
    #70
    DrFunker
    DrFunker Well-Known Member
    :anonymous:
  11. Sep 23, 2015 at 3:38 AM
    #71
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    When is this B/S/T action going live? Or is it already live? 'Bout time people have to follow the rules 'round these here parts.
  12. Sep 23, 2015 at 5:38 AM
    #72
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  13. Sep 23, 2015 at 5:42 AM
    #73
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  14. Sep 23, 2015 at 7:32 AM
    #74
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Thanks for the constructive comment.... :rolleyes:
  15. Sep 23, 2015 at 10:06 AM
    #75
    T4RFTMFW
    About as constructive as asking why I care.
    Douche canoe.
  16. Sep 23, 2015 at 10:42 AM
    #76
    Squeaky Penguin
    Brett
    I get called out for pointing out the other side of the argument? Really? No way can there be two sides to an issue... :rolleyes:
    I'm sorry you seem to have taken offense to my comment, and feel the need to call names, but I was in fact merely pointing out the flip side. I had no intention of being rude, did you?
    And at that, I'll leave well enough alone. The rules have been ammended so it's water under the bridge. Makes no difference to me either if you must know, just don't see the need for more rules.
    Carry on,
  17. Sep 23, 2015 at 11:01 AM
    #77
    JimBeam
    JB
    2015 Tundra
    Can we maybe stop with the name calling etc?
  18. Sep 23, 2015 at 11:10 AM
    #78
    T4RFTMFW
    The problem is, is if I'm trying sell my shocks and I take a picture of a shock bolted into my truck, I'm not getting the whole picture regardless of whether or not the shock is 100% in frame. Nobody is. At any point during the removal of an item it can become damaged, it can be found to be in disrepair (the shock doesn't rebound once it's off the truck, leaks oil, whatever) and it leaves a seller in a position to continue a transaction selling parts that aren't actually functional.
    There are a significant amount of ads in the marketplace from new members who have only joined the forum to list their item(s) for sale. So, if they aren't planning on sticking around the forum and don't care about a reputation or anything else - what is to prevent them from posting an item (like a shock I mentioned above) still installed on a vehicle, and then upon removal of a bad shock figure screw it, someone already paid me, I'll send it to them anyway and pretend it was fine, or I'll just disappear altogether.
    There is little need to protect a seller on this forum's marketplace, and a significant need to protect the buyer. A rule of "items need to be removed from the vehicle and pictured to show condition" is pretty black and white, and if done honestly and in accordance to said rules, will make things less risky for someone sending hundreds of dollars across the internet to what is often a complete stranger.
    I don't see a point in leaving things to chance to that extent, and it also follows the "needs pictures of actual items for sale" rule.
    There will always be scammers, and this forum will have them also.. the marketplace should be a place that makes it as difficult as possible for them to exist here, even if it's the one time they use it.
  19. Sep 23, 2015 at 11:17 AM
    #79
    T4RFTMFW
    I was joking, Jefe. It didn't translate well.
  20. Sep 23, 2015 at 11:20 AM
    #80
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    That's...ridiculous.
Thread Status:
