Marks on clear coat
Discussion in 'Detailing' started by Bettyblue, Nov 3, 2014.
  1. Nov 3, 2014 at 3:22 PM
    Bettyblue
    Bettyblue [OP] Member
    Kelly
    Texas
    Tundra Ext Cab
    Just purchased a 2004 Xtra Cab. The previous owner appears to have driven through some gravel or something that marked up the clear coat on the door. They look like water spots but are actually small marks on the clear coat. I'm curious if anyone else has had this problem and if so, what product is recommended to remove or reduce them? Thank you in advance!
  2. Nov 3, 2014 at 4:44 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    clay bar
  3. Nov 3, 2014 at 4:44 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    x2
  4. Nov 3, 2014 at 7:46 PM
    Bettyblue
    Kelly
    Texas
    Tundra Ext Cab
    Thanks gentlemen....any particular brand you've used and recommend?
  5. Nov 3, 2014 at 9:42 PM
    winL
    winL Well-Known Member
    Bay Area, CA
    PreRunner
    Leer 100R Cap, OEM Hood Protector, Bilstein 5100's @0, Wheeler's 3leaf AAL no TSB, Replaced oem OL, OME 885, Pioneer AVIC-D2
    Just try the meguiars clay with detailer first. If the water spots are hard on there, you'll need to polish after the clay. IF that doesn't work, rubbing compound is your friend. And do wax afterwards. Hell of a lot of work. Good luck.
  6. Nov 7, 2014 at 1:08 PM
    Chaloots
    Chaloots Well-Known Member
  7. Nov 16, 2014 at 10:53 PM
    ezee2404
    ezee2404 New Member
    Evan
    missouri
    Bone Stock sr5
    No mods yet but I'm working on that
    Wet sand with 2500 grit until flat, buff with compound at low speed, then polish. Won't take you 5 minutes.
