Marlin rclt HD kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dosbente, May 9, 2025.
  1. May 9, 2025 at 5:56 PM
    Dosbente
    Dosbente [OP] Member
    Dan
    '23 TRD OR
    Trying to research this kit a little bit, it seems you gain either 5.5" or 7" width in the front end. Is anything done to the rear to match? This would bug me alot if I was to do it (I'm not gonna do it but I'm curios)
  2. May 9, 2025 at 6:15 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Dirt Lifestyle installed this kit a while back. It was a good watch...
    Front
    https://youtu.be/04WkUSRzYSk?si=h9GQBhl7xzIrf-6Y
    Rear
    https://youtu.be/zkU6lmbAOwc?si=nl4b8zftOgFlYo6c
    I think most people doing this sort of upgrade are designing custom rear suspensions and using axles from other, larger trucks. This is discussed at the end of the first video.
  3. May 9, 2025 at 6:16 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    At the absolute very least, you're running this with mid-travel rear suspension, a shock relocate, and wheel spacers (in the interim while you prep your long travel rear).
  4. May 9, 2025 at 6:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. May 9, 2025 at 7:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Yes it’s an IFS replacement only. Why is the difference in front/rear axle widths your biggest worry?
  6. May 9, 2025 at 9:19 PM
    Dosbente
    Dan
    '23 TRD OR
    I wouldn't say it's a worry, Im asking like whats common practice for equalling out the rear after you do the front. It all adds to the total cost. And now I know - you spend another 3 - 4k
  7. May 9, 2025 at 9:28 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    With the cost of the rclt and still having to then buy the steering rack, shocks, and CV’s, I’d be looking into a cost analysis against 74weld portals where you get front/rear portals, brake kit, and new rear axles, not to mention a built in regear. And avoid the headache of the rclt install.
  8. May 9, 2025 at 9:43 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Or, you know... getting a purpose built rock buggy. At some point, doing this to a Tacoma is just forcing a square peg in a round hole.
  9. May 9, 2025 at 10:15 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    Agree.
    71tattooguy and Bertw192[QUOTED] like this.
  10. May 9, 2025 at 11:59 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    This^
    Wish I had just stayed at a simple lift kit and 33s
    Ricardo13x and Bertw192[QUOTED] like this.
  11. May 10, 2025 at 4:26 AM
    545 Well-Known Member
    2015 Access Cab
    I did a long travel on another vehicle, went +3” each side in the front, so +6” total
    Added 1.5” spacers in the rear, so +3” total in the rear
    You can tell the difference, but it’s not noticeable
    Dosbente[OP] likes this.
  12. May 10, 2025 at 6:51 AM
    Dosbente
    Dan
    '23 TRD OR
    "bUilD a rOcK bUgGy"
    Shut up
  13. May 10, 2025 at 6:53 AM
    Dosbente
    Dan
    '23 TRD OR
    Go back then.
  14. May 10, 2025 at 7:06 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Build a buggy / SAS
  15. May 10, 2025 at 7:07 AM
    02hilux
    Planet: EARTH
    As mentioned, some will stick with wheel spacers while majority will probably end up with custom housing. Honestly, if you’re building a custom housing, I recommend upgrading your rear and to a FF9.5 from a 80 series with 30s or 100 series 32s or F9.
    The RCLT will probably run ~$15k w/ tax & ship, add another ~$5 for labor if you can’t do the work. Additional, complete custom rear housing going rate are ~$5-7k plus custom suspension for another ~$5k.
    What is your intended use? Rock crawler, I rather go Martec
  16. May 10, 2025 at 8:28 AM
    Oreo Cat
    Truck is too far gone now, would cost more money and time to undo everything at this point
  17. May 10, 2025 at 8:55 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    :duh:
    ... No!... YOU shut up...
    :jerkoff:
    71tattooguy likes this.
  18. May 10, 2025 at 12:50 PM
    gudujarlson
    Minnesota
    I get it, but what is your reason for making the rear wider? Is it aesthetics or performance? Why are you asking about the width as opposed to other factors? You could go with a 3 link rear or maybe just a shock relocation to get more performance. I’m unsure if width is buying you much, but I’ve never done a deep dive on this.
  19. May 10, 2025 at 12:58 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    It costs to Floss. I’ll see if my bro responds I’ll tag him in this thread. he has a second GEN fully built spared no expense. The thing is sick on 37’s RCLT. @TacoEspecial Mark!!!!!
  20. May 18, 2025 at 6:11 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Fyi, my truck is still under budget.
    When I added the 2.75 RCLT kit I also went to a dana 60 in the rear.
    I went with what ecgs recommended for the width which was adding 5" to stock width.
    Something about your rear wants to come around when its not set up right ... ...
