MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Mar 30, 2014 at 7:04 PM
    #7081
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Guess it's time to do some spring maintenance. What else isn't in that book that is suppose to be done at 50k or under.
  2. Mar 30, 2014 at 7:07 PM
    #7082
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    I do.
  3. Mar 30, 2014 at 7:07 PM
    #7083
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Shocks don't show up either but I've heard 50k for shocks
  4. Mar 30, 2014 at 7:08 PM
    #7084
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Also with wheeling and everything what else is recommended to change out earlier then normal?
  5. Mar 30, 2014 at 7:11 PM
    #7085
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  6. Mar 30, 2014 at 7:16 PM
    #7086
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
  7. Mar 30, 2014 at 7:19 PM
    #7087
    Lespaulkid01
    Lespaulkid01 I prefer the term "beer researcher".
    MoCo, Maryland
    2013 Double Cab TRD Sport, Pyrite Mica
    tool chest, vent visors, tuffy bed box, scangauge, Bilstein 5100's, OME 885x springs, Wheeler's HD AAL, LED map, dome, and reverse lights, Bestop Supertop.
    Really? That sounds low to me. I could be wrong though!
  8. Mar 30, 2014 at 7:19 PM
    #7088
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I had a link to the service intervals for the 2,7 but now I cannot find it. Old age setting in.
  9. Mar 30, 2014 at 7:20 PM
    #7089
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Thanks. I'm gonna have to check my throttle body too maybe it's getting stuck?
  10. Mar 30, 2014 at 7:22 PM
    #7090
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    So far no issues for me at 60K. I throw in a bottle of Red Line fuel system cleaner every oil change.
  11. Mar 30, 2014 at 7:29 PM
    #7091
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I use seafoam and/or Lucas fuel injector cleaner every oil change or so. Still need to do plugs and driveline but they are getting done before the end of may. My brakes will be done this week; the stock stuff only lasted 36,250 and they are pretty weak....
    Tractorman likes this.
  12. Mar 30, 2014 at 7:45 PM
    #7092
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    I took mine to the dealership so far... I'm going to start bringing Lucas with me and tell them to mix it. I only have three more services with them
  13. Mar 30, 2014 at 7:45 PM
    #7093
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Guess I should start getting my hands dirty this spring lol
  14. Mar 31, 2014 at 3:24 AM
    #7094
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Is the Lucas product added to the gas tank? Do you like it?
    I have used Seafoam in the past on a different vehicle, it worked well but a lot of smoke. I did a direct injection method into the throttle body to clean the valves as well.
    If you do not have a garage you are more than welcome to come on over one day. I live in Bowie about 40 miles away from you.
  15. Mar 31, 2014 at 4:29 AM
    #7095
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    It will depend on how much you put your truck through. I use my truck for hunting and camping all year, so it sees a lot of dust/mud/rocks. This is just what I do:
    At 5k intervals I check/change:
    Engine Oil
    Cabin Air Filter
    Engine Air Filter
    I do these every 30k:
    Gear Oils (both diffs, t-case)
    Clean Throttle Body and MAF sensor.
    And these every 60k:
    Spark Plugs
    Engine Coolant
    Transmission Fluid
    Things I just check periodically:
    Brakes and Fluid
    Power Steering
    Propeller shaft bolt torque
    Ball joints, dust covers, boots
    Anything Toyota or dealer says lasts "forever" should probably be serviced at 60k-100k...
    All of these can easily be done at home. ATF and gear oils are really the only expensive ones because of the cost of fluids.
  16. Mar 31, 2014 at 5:04 AM
    #7096
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    You must be hard on your brakes
  17. Mar 31, 2014 at 5:20 AM
    #7097
    AR15xAR10
    Lucas Fuel injector cleaner goes in the gas tank yes. It works fine.
    I've only ever put seafoam in the gas tank so the smoke deal hasn't really happened to me. Other than when i've run it through carbureted motorcycles.
  18. Mar 31, 2014 at 5:21 AM
    #7098
    AR15xAR10
    The first 24,910 miles were not by me. I got the truck with only about 1/3 pad life left
  19. Mar 31, 2014 at 11:56 AM
    #7099
    ClayCrusher
    ClayCrusher Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
  20. Mar 31, 2014 at 12:01 PM
    #7100
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
    looks good man. Like a more refined ARB
