Massive camber issue! 96 5 lug prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5lugger95, Sep 25, 2013.
Thread Status:
Not open for further replies.
  1. Sep 26, 2013 at 7:53 AM
    hondarider215
    hondarider215 Well-Known Member
    Wes
    Socal
    KR Tacoma
    KR Fabrication front and rear bumper ICON 2.5 c/o's All pro leafs Maxtrac Fox rear resi shocks Lr uca 17" methods
    Thats not even close to what he has
  2. Sep 26, 2013 at 7:59 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I know...
  3. Sep 26, 2013 at 8:04 AM
    hondarider215
    Wes
    Socal
    KR Tacoma
    Oh I see what your doing.....:stirthepot:
  4. Sep 26, 2013 at 8:35 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    That doesn't mean it isn't the frame when you jack the truck up even at the LCA you are removing all load on the UCA. It's either the UCA bushings, wheel bearings, or frame flex.
    You should start fresh man I never advise extended stock arms or plate them to death this is pretty haggard.
    This is what you should shoot for
  5. Sep 26, 2013 at 9:09 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Coilovers imply that the spring is mounted to the shock, it appears from the pictures (to me at least) that they aren't connected but that the shock still lives inside the spring.
  6. Sep 26, 2013 at 9:16 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    and you know this maaan!
    I'm glad I don't work out of the garage anymore haha
  7. Sep 26, 2013 at 9:18 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    :eek:I noticed the wack UCA when he posted the pic, then realized this is a homemade death trap, so many things that are wrong, just really wrong...
    Like others have stated, I would refuse a ride...with that kind of extra strain something is bending under load...wondering if the OP has wheeled this hard yet, I have my doubts about the first jump, large bump/boulder/crevasse etc...
    OMG:eek:
    Guerrilla likes this.
  8. Sep 26, 2013 at 9:24 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Initial Coil spring suspension had the coil mounted next to the shock (ie the "not a coil over" pic). Any suspension with a coil mounted over the shock (ie stock suspension) is a "coil over" suspension. That pic can be dissieving due to the bump stops mounted inside the coil.
    Either way, I was initially just trying to be a small dick, not make this a discussion... :)
    On topic, OP i think your issue is your springs are sagging; stiffer springs should help. Im hesitant to give this advice as the REAL issue is your setup is ghetto. You ever jump this? I hope not...
  9. Sep 26, 2013 at 9:40 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    you should jump it. everything will line up after :spy:
    Mully and Matic like this.
  10. Sep 26, 2013 at 9:46 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    That is the sketchiest LT job I have ever seen and why would you not get proper parts for it, fabtech for coilovers seems sketchy as well
  11. Sep 26, 2013 at 9:47 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Am I late? :popcorn:
    My truck is 7" wider...google "Long Travel" and let the knowledge flow.
    Or hell...just check out the DEDICATED SECTION on TW here:
    http://www.tacomaworld.com/forum/long-travel-suspension/
  12. Sep 26, 2013 at 10:03 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  13. Sep 26, 2013 at 10:07 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    dear god
  14. Sep 26, 2013 at 10:14 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    Top notch
  15. Sep 26, 2013 at 10:24 AM
    #35
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    unless youre a professional, youre not going to see if youre frame is fucked. if you havent carfaxed it, do that too. more than likely previous owner crashed it, fucked up the front end, then used the existing parts to create the mongoloid lt kit you now have. buying a proven kit probably wont help if your frame is fucked.
  16. Sep 26, 2013 at 10:28 AM
    #36
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I've seen better kits from ZZR
  17. Sep 26, 2013 at 10:31 AM
    #37
    IbeamsFTW
    IbeamsFTW Well-Known Member
  18. Sep 26, 2013 at 10:38 AM
    #38
    magikbean562
    greg
    socal
    pinto
    33" mudders
    found your reason there champ
  19. Sep 26, 2013 at 10:41 AM
    #39
    magikbean562
    greg
    socal
    pinto
    33" mudders
    heres why the kits so fucked, he built it himself
  20. Sep 26, 2013 at 10:45 AM
    #40
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    where are those quotes commin from? links me to different threads
Thread Status:
